Apollo Bot Feedback
If Apollo gave a particularly good or particularly bad response, please let us know here. Include a link to your thread and the bots response and we can look at what mistake it made and refine it for future use.
Connectivity Problem with Valheim - clients cannot connect to my host
Connectivity Problem with Icarus - Server does not fully start up / no connection possible
Minecraft - Server is not starting
Startup Issue with Minecraft - Server stalls randomly under different loads
Configuration with Satisfactory - Installing a second Instance of Satisfactory
Minecraft - I wanted to have plugins but they don't work
AMP is missing the Backup Menu
Startup Issue with Minecraft - The server will not start because of mods
Startup Issue with Application Deployment - Palworld Server Keeps Crashing
Customization with Minecraft - Why cant i uninstall plugins from the server?
Update Failure with Minecraft - Java Update
Application Deployment - Cant delete it even tho its offline
Startup Issue with Application Deployment - I need update java to 21
Startup Issue with Garry's Mod - My server isn't Starting Need Help
Connectivity Problem with ARK: Survival Evolved - Can Not See ASE Externally
Update Failure with ARK: Survival Ascended - Failed startup
Startup Issue with Minecraft - Instance turning off over night and needing a manual start
Startup Issue with Application Deployment - One instance keeps crashing for no reason
Friends outside the network cannot connect
Startup Issue with Minecraft - unable to start the server and check minecraft server log
Connectivity Problem with Minecraft - hello i cant do online-mode false
Minecraft - i cant connection refused getsockopt
Palworld - Cannot connect to Palworld server
Connectivity Problem with Icarus - Server discoverable from external network
Connectivity Problem with Valheim - Cannot Connect to Valheim Server
Update Failure with Stormworks - how to start stromworks server?
Connectivity Problem with Counter-Strike 2 - Can't join server
Can't get players outside local network to join
Palworld - Server seems to shut down often
Startup Issue with Minecraft - Modded Minecraft server fails to start
Startup Issue with Minecraft - Server Keeps crashing after 2 other friends joined
Left 4 Dead 2 Port forwarding
Startup Issue with Minecraft - Unable to Start server bungee
Configuration with Application Deployment - i dont know how to configure a server
Startup Issue with Minecraft - server keeps crashing if there is more then one player
Amp not restarting, not backuping, not updating
Webserver.Port 8081
Webserver.Port 8081
Webserver.Port 8081
Webserver.Port 8081
Webserver.Port 8081
Webserver.Port 8081
Webserver.Port 8081
Webserver.Port 8081
Webserver.Port 8081
Webserver.Port 8081
Webserver.Port 8081
Connectivity Problem with Seven Days To Die - I turned sleeping off , but it still goes idel
Connectivity Problem with V Rising - Can not connect to Vrising server locally or outside network
Rust cannot start on console
Startup Issue with Sons Of The Forest - Port Problems
Startup Issue with Minecraft - We cant start the server, its shows an error
Update Failure with Minecraft - Can not install any Minecraft version
Terraria cannot use command
Connectivity Problem with Minecraft - Game port error
Startup Issue with Minecraft - Server crashes when trying to start it
Project Zomboid Welcome Message
Minecraft - I can't join and it says " no futher infotmation"
Connectivity Problem with Abiotic Factor - External connection
Running into issues installing AMP on Ubuntu server 24.04.1
How to display a background preview for an instance
Connectivity Problem with Valheim - Outside network connections not working
Permissions issue for second datastore
Connectivity Problem with Minecraft - Player cant connect
Minecraft - Server sometimes rebooting by itself
Startup Issue with Minecraft - doesn´t start probably a mod cause but dont know which
UT99 Server can't be found outside LAN
Startup Issue with Minecraft - Server stall on startup, not failing but stuck in startup
Minecraft - IT CRASHES CONSTANTLY WITH THE SAME ERROR
Connectivity Problem with Palworld - No one can connect to ther server
Creating (and starting) an instance on mounted Datastore fails
Connectivity Problem with Minecraft - having trouble port forwarding
Problems encountered during version upgrade
Connectivity Problem with Valheim - Port 2456 not listening with port forwarded
Docker container creation instance process
Connectivity Problem with Minecraft - Can not join the Server
Regarding the option of adding AI to answer questions
AMP Backups menu and Take a backup task missing
Connectivity Problem with Project Zomboid - Friends can't connect to instance at all
Change Docker Container Network
Startup Issue with Minecraft - Cannot start my minecraft server due to storage problems
Startup Issue with Minecraft Bedrock - Unable to run
Hey, i have the game panel, and built a small company for it. Now, i have the server up but the link is not working, wont open anything. And i have updated as well steamCMD. I have double checked a few things yet im stuck
How to remove deleted Datastores from the AMP dashboard?
Connectivity Problem with Minecraft - Cant connect to server ingame
Cannot create new game instance: ADS upgrade required
Connectivity Problem with Minecraft - serwer lagging
Actually I know how to ask, but I don’t know the answer, and I don’t know if the robot’s answer is correct. Still need to officially check whether the answer is correct.
Well, if your server works after you do what the bot says, it was likely correct. Haha
