Startup Issue with Enshrouded - /bin/bash failed with exit code 1
Operating System Linux - Debian GNU/Linux 12 on aarch64
Application Enshrouded
I got the following error once I try to start the server:
cp: cannot stat ‘/home/amp/.ampdata/instances/Enshrouded01/enshrouded/linux32/steamclient.so’: No such file or directory
rm: cannot remove ‘GE-Proton*.*’: No such file or directory
I updated AMP as followed in this guide: How to update AMP to the latest version, however I still have the same error.
  • Press start button
  • Doesn’t work
  • Updated AMP, still doesn’t work
Update 1: The error was resolved by adding steamclient.so in linux32 and linux64 folders. However the server isn’t able to start, giving the error code 245.
Because you are trying to run on an ARM system
It won’t be able to run it on ARM? I already enabled CPx emulation
Actually, it does run, just tried it here
The issue is that your CPx install is broken, likely because some deps were not installed properly. Check the relevant getamp log in /root
Steamcmd is not downloading the server, hence the errors you are seeing
Thanks for the help! I didn’t managed to find the error in the log, but I looked for packages that I could install and following this and this, I managed to get a little bit further. However now it is stuck while downloading SteamCMD, with the following error:
" Box86 with Dynarec v0.3.7 f921c0c built on Nov 18 2024 14:56:09
Looks like steam didn’t shutdown cleanly, scheduling immediate update check
ILocalize::AddFile() failed to load file “public/steambootstrapper_english.txt”.
[ 0%] Checking for available update…". Any ideas on how I could solve that?
