Ads issues after a reboot
OS Name/Version: win 10 pro 22h2
Product Name/Version: AMP 1. 2.6.1.2
Problem Description: instances disappeared from instance tab discord support said to follow the links below. after following I am unable to access the web gui anymore ads01 says its running in services but I cant access anything
AMP is not currently running
Your AMP instance could not be connected to, this likely means that it is not running or is otherwise not responding.
A reconnection will be automatically attempted in 10 seconds.
If you are performing your first-time setup and are seeing this page for more than a minute then something may have gone wrong with the intial setup. Please consult support in this case.
You can restart AMP manually if it has stopped by opening a command prompt and running:
ampinstmgr startall
If AMP has been recently updated, it may be necessary to restart the AMP-ADS01 service via the Services control panel (services.msc)
Still stuck?
We're here to help! Select an option below and we'll help you get running again.
C:\Users\samst>ampinstmgr status
[Info/1] AMP Instance Manager v2.6.1.2 built 25/03/2025 12:57
Instance Name      │ Friendly Name    │ Module     │ IP              │ Port  │ Up
←]8;;http://127.0.0.1:8080/ADS01             ←]8;; │ ADS              │ ADS        │ 0.0.0.0         │ 8080  │ √
←]8;;http://127.0.0.1:8081/FoulplayzMC01     ←]8;; │ Foulplayz-Sur... │ Minecraft  │ 127.0.0.1       │ 8081  │ √
←]8;;http://127.0.0.1:8082/FoulPlayzForge1...←]8;; │ FoulPlayz For... │ Minecraft  │ 127.0.0.1       │ 8082  │ √
←]8;;http://127.0.0.1:8083/foulplayzcs2AWP01 ←]8;; │ foulplayzcs2AWP  │ Generic    │ 127.0.0.1       │ 8083  │
←]8;;http://127.0.0.1:8084/foulplayzrust01   ←]8;; │ foulplayzrust    │ Rust       │ 127.0.0.1       │ 8084  │ √
←]8;;http://127.0.0.1:8085/FoulplayzMCProx...←]8;; │ FoulplayzMCPr... │ Minecraft  │ 127.0.0.1       │ 8085  │ √
←]8;;http://127.0.0.1:8086/BeamMP01          ←]8;; │ BeamMP           │ Generic    │ 127.0.0.1       │ 8086  │ √
←]8;;http://127.0.0.1:8087/FoulplayzTTT01    ←]8;; │ Foulplayz TTT    │ srcds      │ 127.0.0.1       │ 8087  │
←]8;;http://127.0.0.1:8088/FoulplayzPalwor...←]8;; │ Foulplayz Pal... │ Generic    │ 127.0.0.1       │ 8088  │ √
←]8;;http://127.0.0.1:8089/FoulPlayzHUB01    ←]8;; │ FoulPlayz HUB    │ Minecraft  │ 127.0.0.1       │ 8089  │ √
←]8;;http://127.0.0.1:8090/foulplayzprivat...←]8;; │ foulplayz pri... │ Minecraft  │ 127.0.0.1       │ 8090  │ √
←]8;;http://127.0.0.1:8091/AssettoCorsa01    ←]8;; │ Assetto Corsa    │ Generic    │ 127.0.0.1       │ 8091  │ √
←]8;;http://127.0.0.1:8092/Palworldmodded01  ←]8;; │ Palworld modded  │ Generic    │ 127.0.0.1       │ 8092  │ √
Check the ADS instance’s log for more info
ampinstmgr lastlog ADS01
Also don’t forget to check your hard drive’s space
conf files for each instance were corrupted I had to manually rewrite them base on new instances I created
I’d suggest checking your system’s disk space, as that would be the primary cause for files not saving correctly
