| Initials | Meaning | Description |
| ADS | Application Deployment Service | The AMP module that is responsible for creating and managing other AMP instances. |
| AIM | AMP Instance Manager | The command-line tool ampinstmgr for creating and managing AMP instances on the command line. |
| AMP | Application Management Panel | This software! |
| APIGen | API Generator | An AMP tool that generates code for interacting with the AMP API from other applications |
| FBP | File backup plugin | The AMP plugin that allows for creating/restoring/managing backups |
| FM | File Manager | The AMP plugin that allows uploading/downloading files via the web interface |
| FTS | First Time Setup | The wizard that users are presented the first time they configure AMP. |
| IMP | Instance Manager Plugin | The AMP plugin that contains LIM/RIM and used by ADS/AIM |
| KVP | Key-Value Pair | A configuration file format used by AMP. Uses the syntax of Section.Key=Value |
| LFB | Local File Backup (Plugin) | A stock AMP plugin that handles backups |
| LIM | Local Instance Manager | An internal AMP component common to both ADS and AIM. |
| RCON | Remote CONsole | A common protocol for connecting to and controlling servers. |
| RIM | Remote Instance Manager | An internal AMP component used by ADS to manage remove instances on another ADS instance. |
| RTM | Running Task Manager | An internal AMP component that tracks and manages background tasks. |
| SUM | System User Manager | An internal AMP component/plugin used to query information about OS-level users. |
| VDS | Virtual Directory Service | A component of the file manager for providing fake/virtual directories within the file manager. Usually used as a kind of ‘software-defined symlink’ to show arbitrary external directories inside the file manager. |
