tdue21
December 17, 2023, 2:18pm
1
OS Name/Version: Windows 11 Professional
Product Name/Version: AMP - 2.4.6.6 - 20231005.1
I am unable to create new users for managing a server.
I currently have 3 users, including the admin user.
I started out with the AMP Standard license, but quickly realized that it was not adequate, so I upgraded to AMP Advanced.
I am pretty sure I used the correct upgrade method: Configuration → New Instance Defaults → Re-run setup.
When I try to add a new user, I go to the Configuration → User Management → New User.
I enter a user name and click Ok.
The dialog closes but nothing more happens.
The Audit Log has this to show:
To be perfectly honest, I simply don’t know what to write here.
Restarted AMP several times.
Restarted server instances several time.
Trying adding different users.
I have not tried re-running setup or re-installing, as I have a couple of live servers which I don’t want to disrupt if it can be avoided.
Mike
December 17, 2023, 7:12pm
2
Go to configuration > new instance defaults > re-run setup and re-enter your Professional licence key.
tdue21
December 26, 2023, 11:38am
3
It did not do anything. I even got the license to resend so I was sure, it was the right one.
What I did:
Stopped all instances.
Went to Configuration->New Instance Defaults and clicked Re-run setup.
Entered the license key.
Went through the wizard.
Restarted AMP.
Tried creating a user. No luck .
Inserted the license key in the Configuration->New Instance Defaults->License Key and clicked Reactivate Local Instances .
Tried creating a new user. No luck .
Mike
December 26, 2023, 11:39am
4
I just noticed you’re on an outdated version of AMP. Update first please.
tdue21
December 26, 2023, 11:51am
5
I seem to be unable to update?
I’ve run the yellow-orange Update from the front-page.
I’ve run it from Support and Updates.
I’ve stopped the instances and I’ve let the instances run.
But no matter, it will not update…
What gives?
EDIT: I was able to update all my instances, except the main instance.
That one refuses to cooperate.
Mike
December 26, 2023, 11:59am
6
Do it from the command line - ampinstmgr upgradeall
tdue21
December 26, 2023, 12:07pm
7
I got all instances updated.
I have re-run setup again.
But I am still not able to create new users.
Mike
December 26, 2023, 12:12pm
8
Do ampinstmgr reactivate ADS01
tdue21
December 26, 2023, 12:16pm
9
That didn’t work… Got this error:
And running as Admin didn’t make any difference either
Mike
December 26, 2023, 12:23pm
10
Is ampinstmgr itself up-to-date? Check with ampinstmgr version
tdue21
December 26, 2023, 12:24pm
11
No, I just realized that. All instances are 2.4.6.10, but the ampinstmgr itself is still 2.4.6.6.
EDIT:
I found this: How to update AMP to the latest version
So, I downloaded the latest msi and ran it (no upgrade option, btw.).
So now my ampinstmgr is 2.4.6.10, but I get the same error
Mike
December 26, 2023, 1:45pm
12
If you’re still having this problem after upgrading, try this: Something not working on Windows? Try the following:
tdue21
December 27, 2023, 5:17pm
13
It is still the same. I have followed the instructions to the letter.
But I am not able to create a new user beyond the 3 I already have, including admin.
Am I looking at a complete wipe and reinstallation?
Mike
December 27, 2023, 6:29pm
14
Having done that you need to do ampinstmgr reactivate ADS01 again.
tdue21
December 27, 2023, 8:15pm
15
I did that. It changed nothing. I am still not able to create new users
Mike
December 27, 2023, 8:32pm
16
What message/error do you get? Also do the logs show that AMP is activated?
tdue21
December 27, 2023, 8:42pm
17
That’s the thing. I don’t get any message or errors. The dialog for entering the user name just closes when I have entered the name and clicks OK.
In the Audit Log I can see this:
I don’t know where to find the log files?
The data table from Support and Updates the main instance:
OS
Windows
Platform
Windows 11 Pro
System Type
x86_64
CPU Model
AMD Ryzen 5 4500 6-Core Processor
CPU Layout
1S/6C/12T
Installed RAM
65407
Virtualization
None
Module
ADSModule
Module Application
Application Deployment
Loaded Plugins
FileManagerPlugin, EmailSenderPlugin, WebRequestPlugin, LocalFileBackupPlugin, CommonCorePlugin
Application Name
AMPService
Application Version
2.4.6.10
Codename
Decadeus
Tools Version
2.4.6.10
Release Stream
Mainline
Build Spec
Release
Build Date
06/12/2023 17:17
InstanceID
a329c9ef-e247-4ffe-a95c-19901e14449c
Last Executable
C:\AMPDatastore\Instances\ARKCarnalCorruption01\AMP.exe
Last Arguments
+Core.Webserver.Port 8086 +Core.Webserver.IPBinding 127.0.0.1 +Core.AMP.InstanceID -- -- +FileManagerPlugin.SFTP.SFTPPortNumber 2229 +GenericModule.App.Ports.$GamePort 7777 +GenericModule.App.Ports.$PeerPort 7778 +GenericModule.App.Ports.$QueryPort 27016 +GenericModule.App.Ports.$RCONPort 25575
Last Process ID
644
Mike
December 27, 2023, 8:50pm
18
C:\AMPDatastore\Instances\ADS01\AMPLogs
tdue21
December 27, 2023, 8:54pm
19
Ah, lovely There is this:
[17:23:49] [AMPService Info] : Starting AMPService version 2.4.6.10 (Decadeus), built 06/12/2023 17:17
[17:23:49] [AMPService Info] : Stream: Mainline / Release - built by CUBECODERS/buildbot on CCL-DEV
[17:23:49] [GSMyAdmin Info] : Purging old audit logs (this may take a moment)...
[17:23:49] [GSMyAdmin Warning] : Current time zone is set to Rom, normaltid - It is recommended you switch to UTC+0 to avoid time-zone related issues
[17:23:49] [AMPService Info] : OS: Windows / x86_64
[17:23:49] [AMPService Info] : CPU: AMD Ryzen 5 4500 6-Core Processor (6C/12T)
[17:23:49] [AMPService Info] : RAM: 65407MB
[17:23:49] [AMPService Info] : AMP Instance ID: a329c9ef-e247-4ffe-a95c-19901e14449c
[17:23:49] [GSMyAdmin Warning] : Assembly Newtonsoft.Json was loaded for Core via fallback handler, check plugin dependencies.
[17:23:49] [GSMyAdmin Info] : Loaded ADSModule version 1.0.0.0 by CubeCoders Limited
[17:23:49] [GSMyAdmin Info] : Loaded FileManagerPlugin by CubeCoders Limited
[17:23:49] [GSMyAdmin Info] : Loaded EmailSenderPlugin by CubeCoders Limited
[17:23:49] [GSMyAdmin Info] : Loaded WebRequestPlugin by CubeCoders Limited
[17:23:49] [GSMyAdmin Info] : Loaded LocalFileBackupPlugin by CubeCoders Limited
[17:23:49] [GSMyAdmin Info] : Loaded CommonCorePlugin by CubeCoders Limited
[17:23:49] [GSMyAdmin Info] : ADSModule requests dependency InstanceManagerPlugin...
[17:23:49] [GSMyAdmin Info] : Loaded InstanceManagerPlugin by CubeCoders Limited
[17:23:49] [GSMyAdmin Info] : ADSModule requests dependency SystemUserManagerPlugin...
[17:23:49] [GSMyAdmin Info] : Loaded SystemUserManagerPlugin by CubeCoders Limited
[17:23:49] [GSMyAdmin Info] : Licence Present: AMP Standard Edition
[17:23:49] [GSMyAdmin Info] : Licence Present: AMP Advanced Edition
[17:23:50] [GSMyAdmin Info] : Loaded steamcmdplugin by CubeCoders Limited
[17:23:51] [Core Info] : Metrics server started OK on port 12820
[17:23:51] [ADS Info] : ADS startup complete in 1231ms
[17:23:51] [ADS Info] : Updating remote source CubeCoders/AMPTemplates
[17:23:51] [FileManager Notice] : Using keypair with fingerprint UW8Jj0Q4ez4wHvQFvd4VhXlQj2OquDuBYBbi6/DpW7c=
[17:23:51] [FileManager Info] : SFTP Server started on 0.0.0.0:2223
[17:23:51] [GSMyAdmin Info] : Websockets are enabled.
[17:23:52] [GSMyAdmin Info] : Webserver started on http://0.0.0.0:8080
[17:23:52] [Webserver Info] : RouterTimer@10Hz with 2 jobs started
[17:23:52] [GSMyAdmin Info] : Checking for AMP updates...
[17:23:52] [GSMyAdmin Info] : Startup mode is StartApplication.
[17:23:52] [GSMyAdmin Info] : AMP is up to date.
Mike
December 27, 2023, 9:37pm
20
Right, create the new user at the ADS level and check the log again.
