Hello! In a few days Satisfactory 1.0 comes out and makes a ton of tweaks to their dedicated servers. They are changing what ports are being used and changing them to use both TCP and UDP. They are making changes to their application itself allowing it to be ran as a window and console application. They are also changing many of the game settings that can be applied in the AMP config page. When 1.0 comes out on the 10th and I restart the sever so it updates, will everything work automatically? Or will I have to manually change what ports are being used or do I have to wait until AMP themselves modifies the files for the Satisfactory server for it to work with 1.0? Or does it automatically pull the newest dedicated server files from steam or something of the like? If AMP has to manually do it how long does that take? Thanks!
Great Question! I am also interested! If AMP canāt implement it directly, you can start local and then transfer it later.
Thanks, my thoughts exactly.
+1 update will be today still no respons ![]()
Probably? Thereās no way to know that for certain - depends on how much has changed. But I donāt anticipate that youād have to do anything other than hit update within AMP and carry on as normal.
Awesome, thank you very much.
Server is not updating ![]()
I installed the server on a new Instance there it looks like its updated but it can not start anymore
same here, just get a bash and it does not Start at all.
Can confirm the same issue as mentioned above. On start up, verify games files then quits.
āSteamCMD12:01:14
Redirecting stderr to ā/home/amp/Steam/logs/stderr.txtā
Logging directory: ā/home/amp/Steam/logsā
[ 0%] Checking for available updatesā¦
12:01:15
[----] Verifying installationā¦
UpdateUI: skip show logoSteam Console Client (c) Valve Corporation - version 1721172922
ā type āquitā to exit ā
Loading Steam APIā¦OK
force_install_dir ā1690800ā
12:01:16
Connecting anonymously to Steam Publicā¦OK
12:01:17
Waiting for client configā¦OK
Waiting for user infoā¦OK
app_update 1690800 -beta public validate
Update state (0x5) verifying install, progress: 0.46 (19922944 / 4303569976)
12:01:19
Update state (0x5) verifying install, progress: 25.86 (1113060804 / 4303569976)
12:01:21
Update state (0x5) verifying install, progress: 58.18 (2503693837 / 4303569976)
12:01:23
Update state (0x5) verifying install, progress: 90.74 (3905011865 / 4303569976)
Success! App ā1690800ā fully installed.
quit
12:01:24
bashā
yes, can also confirm it closes upon update.
Can confirm the behaviour too, from what i got they made quite big changes to the servers.
Would it be possible that there is a problem with āServer Release Streamā in the SteamCMD and Update" section on AMP? I mean, the list show āPublic/Early Accessā or āExperimentalā. Should there be another option called āReleaseā or something? Iām just trying to find clues too.
Just for more awarenes, Iām having the same issue.
When trying to start, it verifies and updates the game, then the console just says QUIT
My guess is that the new executable is missing a dependency from the Docker container. Does anyone know where the Docker containers live? Are they publicly accessible?
Oh, I found them, and it looks like someone commited a change 23 minutes ago to update the Satisfactory server to 1.0:
Idk how to get that update thoughā¦
Ah, I found it! They posted on Discord about it:
I can confirm that after following those steps, I can make a new instance of the server!
For those without discord:
Satisfactory 1.0 was released today, and we just merged the changes needed to get the latest changes! To get them on your system follow these steps:
For new instances - Search in the top right of AMP for Repo and click the Fetch button and make a new instance.
For existing instances - Update the instance from the main ADS screen and choose to update the Template if prompted. Also update inside the instance to get the latest game version.
Looks like Iām getting an update loop when trying to install 1.0
Update state (0x5) verifying install, progress: 0.19 (8388608 / 4303607233)
18:24:50
Update state (0x5) verifying install, progress: 25.42 (1094060750 / 4303607233)
18:24:52
Update state (0x5) verifying install, progress: 60.32 (2596138794 / 4303607233)
18:24:54
Update state (0x5) verifying install, progress: 95.67 (4117337996 / 4303607233)
Success! App '1690800' fully installed.
quit
18:24:55
bash
18:24:55
SteamCMD
18:24:55
18:24:58
18:24:59
UpdateUI: skip show logoSteam Console Client (c) Valve Corporation - version 1726088194
-- type 'quit' to exit --
Loading Steam API...OK
force_install_dir "1690800"
18:25:18
Waiting for user info...OK
18:25:19
Update state (0x5) verifying install, progress: 0.27 (11534336 / 4303607233)
18:25:21
Update state (0x5) verifying install, progress: 30.28 (1303301051 / 4303607233)
18:25:23
Update state (0x5) verifying install, progress: 65.30 (2810270802 / 4303607233)
18:25:24
18:25:25
quit
18:25:26
bash
18:25:26
SteamCMD
18:25:33
18:25:37
18:25:38
yes getting the same error
