Hello. I can make instance, update it, and add to server manager in client, but when i try to create new game the server get crash and reboot ![]()
Any one have similar problems?
Now try update Debian 11 → 12
I got the same update issue as everyone else. I had never used satisfactory on AMP prior and after adding the first instance I was caught in the Success! App '1690800' fully installed. quit loop. I deleted the instance, and updated “instance deployment” by going to instance deployment>Instance Manamgement>Fetch Latest. Then I created a new one just as I had 10 minutes prior and now the server seems to be up. I did notice the port requirements for the server changed. Now it only requires 2228 and 7777.
Had the same problem. My templates would not update. Found this post and that fixed it for me.
