OS Name/Version:
Linux amp 6.1.0-18-amd64 #1 SMP PREEMPT_DYNAMIC Debian 6.1.76-1 (2024-02-01) x86 _64
Product Name/Version: (Always use the full version number - not ‘Latest’) AMP
Update to the current patch not possible, installation hangs (see screenshot)
If I try it manually via the CLI, I get the following errors in the output
root@amp:~# sudo su -l amp
CubeCoders AMP
amp@amp
~ ampinstmgr upgradeall
[Info] AMP Instance Manager v2.5 built 14/03/2024 15:36
[Info] Stopping instance ADS01…
[Info] Requesting soft-stop…
[Info] Waiting for instance to stop…
[Info] Instance ADS01 has stopped.
[Info] Stopping instance BMC101…
[Info] Instance BMC101 has stopped.
[Info] Stopping instance SonsOfTheForest01…
AMP_SonsOfTheForest01
[Info] Instance SonsOfTheForest01 has stopped.
[Info] Stopping instance TeamSpeak301…
AMP_TeamSpeak301
[Info] Instance TeamSpeak301 has stopped.
[Info] Upgrading instance ADS01
[/home/amp/.ampdata/Versions/Mainline/20240322.1/AMP_x86_64.zip]
End-of-central-directory signature not found. Either this file is not
a zipfile, or it constitutes one disk of a multi-part archive. In the
latter case the central directory and zipfile comment will be found on
the last disk(s) of this archive.
unzip: cannot find zipfile directory in one of /home/amp/.ampdata/Versions/Mainline/20240322.1/AMP_x86_64.zip or
/home/amp/.ampdata/Versions/Mainline/20240322.1/AMP_x86_64.zip.zip, and cannot find /home/amp/.ampdata/Versions/Mainline/20240322.1/AMP_x86_64.zip.ZIP, period.
[Error] Download or unpack failed. Please check your network connection and try again.
[Error] Unzip return code was 9
[Error] Upgrade failed: Unzip return code was 9
[Info] Upgrading instance BMC101
[Info] Upgrading instance SonsOfTheForest01
[Info] Upgrading instance TeamSpeak301
- Step 1
- Step 2
- Step 3
Actions taken to resolve so far: Manual attempt to update via CLI, Article followed, unfortunately also without success: Unable to upgrade from 2.3.4.4
