Update Failure with Minecraft - Modpack/Mods not loading
When I installed the server modpack, and configured a bit. Everytime I tried to run a server jar which the only jar that works is the normal 1.12.2 jar which the modpack doesn’t use. So it doesn’t actually allow me to use the mods that I have installed into the server.
  • Install Divine Journey 2 Server Pack
  • Change to the Forge and 1.12.2
  • In the FIles, remove plugins and the Devine Journey 2 zip file after extracting into the server
  • Run the Forge Jar to find out it doesn’t work, which the only Jar it works is the 1.12.2 forge server jar.
See this guide here, you probably forgot to select Java 8, or have misconfigured something else
