Update Failure with Application Deployment - Stick on 2.6.4.2
Product AMPService ‘Phobos’ v2.6.4.2 (Mainline)
Launching amp and it tells me an update is available. However, when I update, and it restarts itself, it doesn’t actually update.
  • Launched Amp
  • Logged in with MFA
  • Tried to apply update
  • Update unsuccessful, reset AMP several times. Nothing.
Hello,
This happens to me also, I have to update manually
Following the update guide is the recommended way: How to update AMP to the latest version
Ya, this is all I do and it works every time
ampinstmgr stopall
ampinstmgr upgradeall
ampinstmgr startall
OS server 2022
If that is all you do, then your AMP Instance Manager will be out-of-date, which will cause issues
