OS Name/Version: Windows Server 2019 Standard (Desktop Experience)
Product Name/Version: AMP Release “Triton” v2.3.2.12, built 05/05/2022 18:13
I’ve just installed AMP (which was not as smooth as it should have been, but that’s a separate issue), and thus have a clean install base. I have been able to get a Minecraft instance working perfectly - so I know that the main AMP base is working as expected.
However, I am not able to get a Left 4 Dead 2 application to start - the instance will, but not the server part of it.
Install AMP
Add new Instance called Left 4 Dead 2 with the application drop down of Left 4 Dead 2
Wait for install
Start instance
Manage the instance
Update - and wait
Press Start under instance dashboard
Watch the CPU and Memory spike, then drop, spike then drop…repeat ad nausea
I have tried deleting and recreating the instance, made sure it is bound to an IP and not to 0.0.0.0. This has not helped.
AMPLOG is included below. I’ve tried the good old Google but that has not been of any help either.
Hope somebody can help me with this…I fear I may go grey(er) otherwise.
[01:35:48] [System:admin Activity] : Starting the application.
[01:35:49] [System:admin Warning] : The application stopped unexpectedly. Exit code -532265403
[01:35:51] [System:admin Warning] : The application stopped unexpectedly. Exit code -532265403
[01:35:52] [System:admin Warning] : The application stopped unexpectedly. Exit code -532265403
[01:35:53] [System:admin Warning] : The application stopped unexpectedly. Exit code -532265403
05/19/2022 - 01:35:55: Preventing spawning
05/19/2022 - 01:35:55: Log file closed
05/19/2022 - 01:35:55: Log file started (file "logs\L192_168_002_244_27015_202205190135_002.log") (game "D:\AMPDatastore\Instances\Left4Dead2\srcds\222860\left4dead2") (version "8490")
05/19/2022 - 01:35:55: Loading map "c1m1_hotel"
05/19/2022 - 01:35:55: server cvars start
05/19/2022 - 01:35:55: "sv_maxspeed" = "320"
05/19/2022 - 01:35:55: "sv_rollangle" = "0"
05/19/2022 - 01:35:55: "tauntfrequency" = "1"
05/19/2022 - 01:35:55: "r_AirboatViewZHeight" = "0.0"
05/19/2022 - 01:35:55: "sv_cheats" = "0"
05/19/2022 - 01:35:55: "r_VehicleViewDampen" = "1"
05/19/2022 - 01:35:55: "mp_allowNPCs" = "1"
05/19/2022 - 01:35:55: "god" = "0"
05/19/2022 - 01:35:55: "mp_tournament" = "0"
05/19/2022 - 01:35:55: "buddha" = "0"
05/19/2022 - 01:35:55: "mp_flashlight" = "1"
05/19/2022 - 01:35:55: "mp_maxrounds" = "0"
05/19/2022 - 01:35:55: "sv_tags" = ""
05/19/2022 - 01:35:55: "sv_stepsize" = "18"
05/19/2022 - 01:35:55: "mp_teamlist" = "hgrunt;scientist"
05/19/2022 - 01:35:55: "sv_alltalk" = "0"
05/19/2022 - 01:35:55: "mp_footsteps" = "1"
05/19/2022 - 01:35:55: "survivor_limit" = "4"
05/19/2022 - 01:35:55: "sv_noclipaccelerate" = "5"
05/19/2022 - 01:35:55: "sv_wateraccelerate" = "10"
05/19/2022 - 01:35:55: "mp_autocrosshair" = "1"
05/19/2022 - 01:35:55: "mp_stalemate_enable" = "0"
05/19/2022 - 01:35:55: "sv_rollspeed" = "200"
05/19/2022 - 01:35:55: "sv_airaccelerate" = "10"
05/19/2022 - 01:35:55: "mp_teams_unbalance_limit" = "1"
05/19/2022 - 01:35:55: "mp_timelimit" = "0"
05/19/2022 - 01:35:55: "mp_fadetoblack" = "0"
05/19/2022 - 01:35:55: "sv_noclipfriction" = "4"
05/19/2022 - 01:35:55: "sv_waterfriction" = "1"
05/19/2022 - 01:35:55: "sv_steamgroup" = ""
05/19/2022 - 01:35:55: "coop" = "0"
05/19/2022 - 01:35:55: "nextlevel" = ""
05/19/2022 - 01:35:55: "sv_stopspeed" = "75"
05/19/2022 - 01:35:55: "sv_specaccelerate" = "5"
05/19/2022 - 01:35:55: "deathmatch" = "1"
05/19/2022 - 01:35:55: "tv_enable" = "0"
05/19/2022 - 01:35:55: "mp_falldamage" = "0"
05/19/2022 - 01:35:55: "mp_freezetime" = "6"
05/19/2022 - 01:35:55: "sv_voiceenable" = "1"
05/19/2022 - 01:35:55: "sv_bounce" = "0"
05/19/2022 - 01:35:55: "tf_arena_max_streak" = "5"
05/19/2022 - 01:35:55: "r_AirboatViewDampenFreq" = "7.0"
05/19/2022 - 01:35:55: "mp_disable_respawn_times" = "0"
05/19/2022 - 01:35:55: "mp_weaponstay" = "0"
05/19/2022 - 01:35:55: "mp_friendlyfire" = "1"
05/19/2022 - 01:35:55: "sv_noclipspeed" = "5"
05/19/2022 - 01:35:55: "r_JeepViewDampenDamp" = "1.0"
05/19/2022 - 01:35:55: "mp_c4timer" = "45"
05/19/2022 - 01:35:55: "r_AirboatViewDampenDamp" = "1.0"
05/19/2022 - 01:35:55: "mp_stalemate_at_timelimit" = "0"
05/19/2022 - 01:35:55: "sv_footsteps" = "1"
05/19/2022 - 01:35:55: "mp_limitteams" = "2"
05/19/2022 - 01:35:55: "tv_relaypassword" = ""
05/19/2022 - 01:35:55: "tf_arena_round_time" = "0"
05/19/2022 - 01:35:55: "mp_teamplay" = "0"
05/19/2022 - 01:35:55: "r_JeepViewDampenFreq" = "7.0"
05/19/2022 - 01:35:55: "sv_specnoclip" = "1"
05/19/2022 - 01:35:55: "sv_friction" = "4"
05/19/2022 - 01:35:55: "mp_autoteambalance" = "1"
05/19/2022 - 01:35:55: "sv_contact" = ""
05/19/2022 - 01:35:55: "director_afk_timeout" = "45"
05/19/2022 - 01:35:55: "mp_roundtime" = "5"
05/19/2022 - 01:35:55: "mp_fraglimit" = "0"
05/19/2022 - 01:35:55: "mp_forcerespawn" = "1"
05/19/2022 - 01:35:55: "decalfrequency" = "10"
05/19/2022 - 01:35:55: "sv_accelerate" = "5"
05/19/2022 - 01:35:55: "mp_winlimit" = "0"
05/19/2022 - 01:35:55: "sv_gravity" = "800"
05/19/2022 - 01:35:55: "sv_password" = ""
05/19/2022 - 01:35:55: "r_JeepViewZHeight" = "10.0"
05/19/2022 - 01:35:55: "tf_arena_preround_time" = "10"
05/19/2022 - 01:35:55: "tv_password" = ""
05/19/2022 - 01:35:55: "sv_specspeed" = "3"
05/19/2022 - 01:35:55: server cvars end
[01:35:55] [srcds:admin Info] : Setting up RCON...
[01:35:55] [System:admin Warning] : The application stopped unexpectedly. Exit code -532265403
Thank you for the detailed post. Do other srcds based games exhibit the same problem? Could you try setting up a CS:GO server to see if it has the same problem?
Hi Mark,
Thanks for getting back to me.
I have just tried to start a Left 4 Dead 1 and CS:GO server, the end result is the same. I’ve included the CS:GO log below.
[14:03:28] [System:admin Activity] : Starting the application.
[14:03:44] [System:admin Warning] : The application stopped unexpectedly. Exit code -532265403
[14:03:46] [System:admin Warning] : The application stopped unexpectedly. Exit code -532265403
[14:03:48] [System:admin Warning] : The application stopped unexpectedly. Exit code -532265403
05/19/2022 - 14:03:52: Log file closed
05/19/2022 - 14:03:52: Log file started (file "logs\L192_168_002_244_27019_202205191403_000.log") (game "D:\AMPDatastore\Instances\CSGO\srcds\740\csgo") (version "8580")
05/19/2022 - 14:03:52: Loading map "cs_office"
05/19/2022 - 14:03:52: server cvars start
05/19/2022 - 14:03:52: "cash_player_killed_teammate" = "-300"
05/19/2022 - 14:03:52: "sv_maxspeed" = "320"
05/19/2022 - 14:03:52: "cash_player_respawn_amount" = "0"
05/19/2022 - 14:03:52: "cash_team_winner_bonus_consecutive_rounds" = "0"
05/19/2022 - 14:03:52: "cash_team_rescued_hostage" = "0"
05/19/2022 - 14:03:52: "cash_team_win_by_defusing_bomb" = "3250"
05/19/2022 - 14:03:52: "sv_rollangle" = "0"
05/19/2022 - 14:03:52: "r_AirboatViewZHeight" = "0.0"
05/19/2022 - 14:03:52: "sv_cheats" = "0"
05/19/2022 - 14:03:52: "r_VehicleViewDampen" = "1"
05/19/2022 - 14:03:52: "mp_allowNPCs" = "1"
05/19/2022 - 14:03:52: "mp_tournament" = "0"
05/19/2022 - 14:03:52: "sv_vote_issue_pause_match_spec_only" = "0"
05/19/2022 - 14:03:52: "sv_spec_hear" = "1"
05/19/2022 - 14:03:52: "cash_player_interact_with_hostage" = "150"
05/19/2022 - 14:03:52: "mp_flashlight" = "0"
05/19/2022 - 14:03:52: "mp_maxrounds" = "0"
05/19/2022 - 14:03:52: "sv_tags" = ""
05/19/2022 - 14:03:52: "sv_stepsize" = "18"
05/19/2022 - 14:03:52: "mp_teamlist" = "hgrunt;scientist"
05/19/2022 - 14:03:52: "sv_alltalk" = "0"
05/19/2022 - 14:03:52: "mp_footsteps" = "1"
05/19/2022 - 14:03:52: "sv_noclipaccelerate" = "5"
05/19/2022 - 14:03:52: "sv_accelerate_debug_speed" = "0"
05/19/2022 - 14:03:52: "sv_wateraccelerate" = "10"
05/19/2022 - 14:03:52: "mp_autocrosshair" = "1"
05/19/2022 - 14:03:52: "mp_stalemate_enable" = "0"
05/19/2022 - 14:03:52: "cash_team_elimination_bomb_map" = "3250"
05/19/2022 - 14:03:52: "cash_player_get_killed" = "0"
05/19/2022 - 14:03:52: "mp_roundtime_defuse" = "0"
05/19/2022 - 14:03:52: "sv_autobuyammo" = "0"
05/19/2022 - 14:03:52: "sv_rollspeed" = "200"
05/19/2022 - 14:03:52: "sv_airaccelerate" = "12"
05/19/2022 - 14:03:52: "mp_teams_unbalance_limit" = "1"
05/19/2022 - 14:03:52: "sv_show_team_equipment_prohibit" = "0"
05/19/2022 - 14:03:52: "mp_timelimit" = "5"
05/19/2022 - 14:03:52: "cash_team_loser_bonus" = "1400"
05/19/2022 - 14:03:52: "sv_deadtalk" = "0"
05/19/2022 - 14:03:52: "cash_player_rescued_hostage" = "1000"
05/19/2022 - 14:03:52: "sv_waterfriction" = "1"
05/19/2022 - 14:03:52: "sv_competitive_official_5v5" = "0"
05/19/2022 - 14:03:52: "sv_steamgroup" = ""
05/19/2022 - 14:03:52: "cash_player_killed_enemy_default" = "300"
05/19/2022 - 14:03:52: "coop" = "0"
05/19/2022 - 14:03:52: "mp_respawnwavetime" = "10.0"
05/19/2022 - 14:03:52: "sv_teamid_overhead" = "1"
05/19/2022 - 14:03:52: "tv_enable1" = "0"
05/19/2022 - 14:03:52: "nextlevel" = ""
05/19/2022 - 14:03:52: "sv_stopspeed" = "80"
05/19/2022 - 14:03:52: "sv_specaccelerate" = "5"
05/19/2022 - 14:03:52: "deathmatch" = "1"
05/19/2022 - 14:03:52: "tv_enable" = "0"
05/19/2022 - 14:03:52: "mp_falldamage" = "0"
05/19/2022 - 14:03:52: "mp_teammates_are_enemies" = "0"
05/19/2022 - 14:03:52: "mp_roundtime_hostage" = "0"
05/19/2022 - 14:03:52: "mp_freezetime" = "6"
05/19/2022 - 14:03:52: "sv_accelerate_use_weapon_speed" = "1"
05/19/2022 - 14:03:52: "sv_voiceenable" = "1"
05/19/2022 - 14:03:52: "sv_teamid_overhead_always_prohibit" = "0"
05/19/2022 - 14:03:52: "sv_bounce" = "0"
05/19/2022 - 14:03:52: "r_AirboatViewDampenFreq" = "7.0"
05/19/2022 - 14:03:52: "mp_disable_respawn_times" = "0"
05/19/2022 - 14:03:52: "mp_weaponstay" = "0"
05/19/2022 - 14:03:52: "mp_hostagepenalty" = "10"
05/19/2022 - 14:03:52: "tv_advertise_watchable" = "0"
05/19/2022 - 14:03:52: "mp_friendlyfire" = "0"
05/19/2022 - 14:03:52: "sv_noclipspeed" = "5"
05/19/2022 - 14:03:52: "cash_team_hostage_interaction" = "500"
05/19/2022 - 14:03:52: "sv_allchat" = "1"
05/19/2022 - 14:03:52: "cash_team_win_by_time_running_out_bomb" = "3250"
05/19/2022 - 14:03:52: "mp_buy_during_immunity" = "0"
05/19/2022 - 14:03:52: "cash_player_killed_enemy_factor" = "1"
05/19/2022 - 14:03:52: "r_JeepViewDampenDamp" = "1.0"
05/19/2022 - 14:03:52: "mp_c4timer" = "40"
05/19/2022 - 14:03:52: "r_AirboatViewDampenDamp" = "1.0"
05/19/2022 - 14:03:52: "sv_competitive_minspec" = "1"
05/19/2022 - 14:03:52: "sv_max_allowed_net_graph" = "1"
05/19/2022 - 14:03:52: "mp_stalemate_at_timelimit" = "0"
05/19/2022 - 14:03:52: "sv_footsteps" = "1"
05/19/2022 - 14:03:52: "mp_limitteams" = "2"
05/19/2022 - 14:03:52: "sv_vote_issue_kick_allowed" = "1"
05/19/2022 - 14:03:52: "cash_team_survive_guardian_wave" = "1000"
05/19/2022 - 14:03:52: "tv_relaypassword" = ""
05/19/2022 - 14:03:52: "mp_teamplay" = "0"
05/19/2022 - 14:03:52: "cash_team_terrorist_win_bomb" = "3500"
05/19/2022 - 14:03:52: "cash_team_elimination_hostage_map_t" = "1000"
05/19/2022 - 14:03:52: "r_JeepViewDampenFreq" = "7.0"
05/19/2022 - 14:03:52: "sv_specnoclip" = "1"
05/19/2022 - 14:03:52: "sv_friction" = "5.2"
05/19/2022 - 14:03:52: "cash_team_win_by_time_running_out_hostage" = "3250"
05/19/2022 - 14:03:52: "cash_player_bomb_planted" = "300"
05/19/2022 - 14:03:52: "mp_autoteambalance" = "1"
05/19/2022 - 14:03:52: "sv_contact" = ""
05/19/2022 - 14:03:52: "sv_vote_kick_ban_duration" = "15"
05/19/2022 - 14:03:52: "cash_player_bomb_defused" = "300"
05/19/2022 - 14:03:52: "mp_roundtime" = "5"
05/19/2022 - 14:03:52: "sv_kick_ban_duration" = "15"
05/19/2022 - 14:03:52: "cash_team_planted_bomb_but_defused" = "800"
05/19/2022 - 14:03:52: "cash_player_killed_hostage" = "-1000"
05/19/2022 - 14:03:52: "sv_vote_issue_loadbackup_allowed" = "1"
05/19/2022 - 14:03:52: "nextmode" = ""
05/19/2022 - 14:03:52: "mp_fraglimit" = "0"
05/19/2022 - 14:03:52: "cash_team_bonus_shorthanded" = "0"
05/19/2022 - 14:03:52: "mp_forcerespawn" = "1"
05/19/2022 - 14:03:52: "mp_buy_anywhere" = "0"
05/19/2022 - 14:03:52: "sv_accelerate" = "5.5"
05/19/2022 - 14:03:52: "mp_winlimit" = "0"
05/19/2022 - 14:03:52: "sv_gravity" = "800"
05/19/2022 - 14:03:52: "sv_password" = ""
05/19/2022 - 14:03:52: "cash_team_elimination_hostage_map_ct" = "2000"
05/19/2022 - 14:03:52: "cash_team_win_by_hostage_rescue" = "3500"
05/19/2022 - 14:03:52: "sv_vote_issue_loadbackup_spec_only" = "0"
05/19/2022 - 14:03:52: "r_JeepViewZHeight" = "10.0"
05/19/2022 - 14:03:52: "cash_team_loser_bonus_consecutive_rounds" = "500"
05/19/2022 - 14:03:52: "cash_player_damage_hostage" = "-30"
05/19/2022 - 14:03:52: "cash_team_hostage_alive" = "0"
05/19/2022 - 14:03:52: "tv_password" = ""
05/19/2022 - 14:03:52: "sv_specspeed" = "3"
05/19/2022 - 14:03:52: server cvars end
[14:03:52] [srcds:admin Info] : Setting up RCON...
05/19/2022 - 14:03:59: Started map "cs_office" (CRC "-446407886")
05/19/2022 - 14:03:59: server_cvar: "cash_player_bomb_defused" "0"
05/19/2022 - 14:03:59: server_cvar: "cash_player_bomb_planted" "0"
05/19/2022 - 14:03:59: server_cvar: "cash_player_damage_hostage" "0"
05/19/2022 - 14:03:59: server_cvar: "cash_player_interact_with_hostage" "0"
05/19/2022 - 14:03:59: server_cvar: "cash_player_killed_enemy_default" "0"
05/19/2022 - 14:03:59: server_cvar: "cash_player_killed_enemy_factor" "0"
05/19/2022 - 14:03:59: server_cvar: "cash_player_killed_hostage" "0"
05/19/2022 - 14:03:59: server_cvar: "cash_player_killed_teammate" "0"
05/19/2022 - 14:03:59: server_cvar: "cash_player_rescued_hostage" "0"
05/19/2022 - 14:03:59: server_cvar: "cash_team_elimination_bomb_map" "0"
05/19/2022 - 14:03:59: server_cvar: "cash_team_elimination_hostage_map_t" "0"
05/19/2022 - 14:03:59: server_cvar: "cash_team_elimination_hostage_map_ct" "0"
05/19/2022 - 14:03:59: server_cvar: "cash_team_hostage_interaction" "0"
05/19/2022 - 14:03:59: server_cvar: "cash_team_loser_bonus" "0"
05/19/2022 - 14:03:59: server_cvar: "cash_team_loser_bonus_consecutive_rounds" "0"
05/19/2022 - 14:03:59: server_cvar: "cash_team_planted_bomb_but_defused" "0"
05/19/2022 - 14:03:59: server_cvar: "cash_team_terrorist_win_bomb" "0"
05/19/2022 - 14:03:59: server_cvar: "cash_team_win_by_defusing_bomb" "0"
05/19/2022 - 14:03:59: server_cvar: "cash_team_win_by_hostage_rescue" "0"
05/19/2022 - 14:03:59: server_cvar: "cash_team_win_by_time_running_out_bomb" "0"
05/19/2022 - 14:03:59: server_cvar: "cash_team_win_by_time_running_out_hostage" "0"
05/19/2022 - 14:03:59: server_cvar: "mp_buy_anywhere" "1"
05/19/2022 - 14:03:59: server_cvar: "mp_buy_during_immunity" "1"
05/19/2022 - 14:03:59: server_cvar: "mp_freezetime" "0"
05/19/2022 - 14:03:59: server_cvar: "mp_friendlyfire" "1"
05/19/2022 - 14:03:59: server_cvar: "mp_roundtime" "10"
05/19/2022 - 14:03:59: server_cvar: "mp_timelimit" "10"
05/19/2022 - 14:03:59: server_cvar: "sv_deadtalk" "1"
[14:04:08] [System:admin Warning] : The application stopped unexpectedly. Exit code -532265403
[14:04:10] [System:admin Warning] : The application stopped unexpectedly. Exit code -532265403
[14:04:13] [System:admin Warning] : The application stopped unexpectedly. Exit code -532265403
[14:04:15] [System:admin Warning] : The application stopped unexpectedly. Exit code -532265403
[14:04:17] [System:admin Warning] : The application stopped unexpectedly. Exit code -532265403
[14:04:19] [System:admin Warning] : The application stopped unexpectedly. Exit code -532265403
Sanity checks, is the selected map valid for the server type? And has a GSLT token been specified for the servers in the settings?
ok, so I fell a little silly - but only a little.
So I did not have a GSLT - that has been sorted - had no idea I would need one, but I don’t think it’s using it anyway as the Steam page shows it has never logged in. Anyway, moving on.
While I was able to get the server VERY briefly to allow connections it still falls back into the same loop.
Map name is valid, though interestingly it only has a single map in the drop down list (refreshing the list has no effect) - I’ll worry about that later.
The frustrating thing about this though is that if I manually start the srcds.exe program it runs just fine - and I can get a working server. It just won’t play nice via AMP.
[14:28:33] [Core:Anonymous Activity] : Authentication attempt for user admin from 192.168.2.244
[14:28:34] [Core:Anonymous Activity] : Authentication success
[14:28:37] [System:admin Activity] : Starting the application.
05/19/2022 - 14:28:39: Preventing spawning
05/19/2022 - 14:28:39: Log file closed
05/19/2022 - 14:28:39: Log file started (file "logs\L192_168_002_244_27015_202205191428_000.log") (game "D:\AMPDatastore\Instances\Left4Dead2\srcds\222860\left4dead2") (version "8490")
05/19/2022 - 14:28:39: Loading map "c1m1_hotel"
05/19/2022 - 14:28:39: server cvars start
05/19/2022 - 14:28:39: "sv_maxspeed" = "320"
05/19/2022 - 14:28:39: "sv_rollangle" = "0"
05/19/2022 - 14:28:39: "tauntfrequency" = "1"
05/19/2022 - 14:28:39: "r_AirboatViewZHeight" = "0.0"
05/19/2022 - 14:28:39: "sv_cheats" = "0"
05/19/2022 - 14:28:39: "r_VehicleViewDampen" = "1"
05/19/2022 - 14:28:39: "mp_allowNPCs" = "1"
05/19/2022 - 14:28:39: "god" = "0"
05/19/2022 - 14:28:39: "mp_tournament" = "0"
05/19/2022 - 14:28:39: "buddha" = "0"
05/19/2022 - 14:28:39: "mp_flashlight" = "1"
05/19/2022 - 14:28:39: "mp_maxrounds" = "0"
05/19/2022 - 14:28:39: "sv_tags" = ""
05/19/2022 - 14:28:39: "sv_stepsize" = "18"
05/19/2022 - 14:28:39: "mp_teamlist" = "hgrunt;scientist"
05/19/2022 - 14:28:39: "sv_alltalk" = "0"
05/19/2022 - 14:28:39: "mp_footsteps" = "1"
05/19/2022 - 14:28:39: "survivor_limit" = "4"
05/19/2022 - 14:28:39: "sv_noclipaccelerate" = "5"
05/19/2022 - 14:28:39: "sv_wateraccelerate" = "10"
05/19/2022 - 14:28:39: "mp_autocrosshair" = "1"
05/19/2022 - 14:28:39: "mp_stalemate_enable" = "0"
05/19/2022 - 14:28:39: "sv_rollspeed" = "200"
05/19/2022 - 14:28:39: "sv_airaccelerate" = "10"
05/19/2022 - 14:28:39: "mp_teams_unbalance_limit" = "1"
05/19/2022 - 14:28:39: "mp_timelimit" = "0"
05/19/2022 - 14:28:39: "mp_fadetoblack" = "0"
05/19/2022 - 14:28:39: "sv_noclipfriction" = "4"
05/19/2022 - 14:28:39: "sv_waterfriction" = "1"
05/19/2022 - 14:28:39: "sv_steamgroup" = ""
05/19/2022 - 14:28:39: "coop" = "0"
05/19/2022 - 14:28:39: "nextlevel" = ""
05/19/2022 - 14:28:39: "sv_stopspeed" = "75"
05/19/2022 - 14:28:39: "sv_specaccelerate" = "5"
05/19/2022 - 14:28:39: "deathmatch" = "1"
05/19/2022 - 14:28:39: "tv_enable" = "0"
05/19/2022 - 14:28:39: "mp_falldamage" = "0"
05/19/2022 - 14:28:39: "mp_freezetime" = "6"
05/19/2022 - 14:28:39: "sv_voiceenable" = "1"
05/19/2022 - 14:28:39: "sv_bounce" = "0"
05/19/2022 - 14:28:39: "tf_arena_max_streak" = "5"
05/19/2022 - 14:28:39: "r_AirboatViewDampenFreq" = "7.0"
05/19/2022 - 14:28:39: "mp_disable_respawn_times" = "0"
05/19/2022 - 14:28:39: "mp_weaponstay" = "0"
05/19/2022 - 14:28:39: "mp_friendlyfire" = "1"
05/19/2022 - 14:28:39: "sv_noclipspeed" = "5"
05/19/2022 - 14:28:39: "r_JeepViewDampenDamp" = "1.0"
05/19/2022 - 14:28:39: "mp_c4timer" = "45"
05/19/2022 - 14:28:39: "r_AirboatViewDampenDamp" = "1.0"
05/19/2022 - 14:28:39: "mp_stalemate_at_timelimit" = "0"
05/19/2022 - 14:28:39: "sv_footsteps" = "1"
05/19/2022 - 14:28:39: "mp_limitteams" = "2"
05/19/2022 - 14:28:39: "tv_relaypassword" = ""
05/19/2022 - 14:28:39: "tf_arena_round_time" = "0"
05/19/2022 - 14:28:39: "mp_teamplay" = "0"
05/19/2022 - 14:28:39: "r_JeepViewDampenFreq" = "7.0"
05/19/2022 - 14:28:39: "sv_specnoclip" = "1"
05/19/2022 - 14:28:39: "sv_friction" = "4"
05/19/2022 - 14:28:39: "mp_autoteambalance" = "1"
05/19/2022 - 14:28:39: "sv_contact" = ""
05/19/2022 - 14:28:39: "director_afk_timeout" = "45"
05/19/2022 - 14:28:39: "mp_roundtime" = "5"
05/19/2022 - 14:28:39: "mp_fraglimit" = "0"
05/19/2022 - 14:28:39: "mp_forcerespawn" = "1"
05/19/2022 - 14:28:39: "decalfrequency" = "10"
05/19/2022 - 14:28:39: "sv_accelerate" = "5"
05/19/2022 - 14:28:39: "mp_winlimit" = "0"
05/19/2022 - 14:28:39: "sv_gravity" = "800"
05/19/2022 - 14:28:39: "sv_password" = ""
05/19/2022 - 14:28:39: "r_JeepViewZHeight" = "10.0"
05/19/2022 - 14:28:39: "tf_arena_preround_time" = "10"
05/19/2022 - 14:28:39: "tv_password" = ""
05/19/2022 - 14:28:39: "sv_specspeed" = "3"
[14:28:39] [srcds:admin Info] : Setting up RCON...
05/19/2022 - 14:28:39: server cvars end
05/19/2022 - 14:28:39: Started map "c1m1_hotel" (CRC "-1242577269")
05/19/2022 - 14:28:40: CDirector::RunScript, scriptedmode, level: 1
05/19/2022 - 14:28:40: CDirector::RunScript, director_base, level: 0
05/19/2022 - 14:28:41: Preventing spawning
05/19/2022 - 14:28:41: CDirector::RunScript, scriptedmode, level: 1
05/19/2022 - 14:28:41: CDirector::RunScript, director_base, level: 0
05/19/2022 - 14:28:41: server_cvar: "sv_maxspeed" "1000.000000"
05/19/2022 - 14:28:41: World triggered "Round_Start"
[14:28:41] [srcds:admin Info] : RCON connection successful.
[14:28:42] [srcds:admin Info] : RCON connection successful.
[14:28:43] [srcds:admin Info] : RCON connection successful.
[14:28:44] [srcds:admin Info] : RCON connection successful.
[14:29:10] [System:admin Warning] : The application stopped unexpectedly. Exit code 255
05/19/2022 - 14:29:11: Preventing spawning
[14:29:11] [System:admin Warning] : The application stopped unexpectedly. Exit code -532265403
05/19/2022 - 14:29:13: Preventing spawning
05/19/2022 - 14:29:13: Log file closed
05/19/2022 - 14:29:13: Log file started (file "logs\L192_168_002_244_27015_202205191429_000.log") (game "D:\AMPDatastore\Instances\Left4Dead2\srcds\222860\left4dead2") (version "8490")
05/19/2022 - 14:29:13: Loading map "c1m1_hotel"
05/19/2022 - 14:29:13: server cvars start
05/19/2022 - 14:29:13: "sv_maxspeed" = "320"
05/19/2022 - 14:29:13: "sv_rollangle" = "0"
05/19/2022 - 14:29:13: "tauntfrequency" = "1"
05/19/2022 - 14:29:13: "r_AirboatViewZHeight" = "0.0"
05/19/2022 - 14:29:13: "sv_cheats" = "0"
05/19/2022 - 14:29:13: "r_VehicleViewDampen" = "1"
05/19/2022 - 14:29:13: "mp_allowNPCs" = "1"
05/19/2022 - 14:29:13: "god" = "0"
05/19/2022 - 14:29:13: "mp_tournament" = "0"
05/19/2022 - 14:29:13: "buddha" = "0"
05/19/2022 - 14:29:13: "mp_flashlight" = "1"
05/19/2022 - 14:29:13: "mp_maxrounds" = "0"
05/19/2022 - 14:29:13: "sv_tags" = ""
05/19/2022 - 14:29:13: "sv_stepsize" = "18"
05/19/2022 - 14:29:13: "mp_teamlist" = "hgrunt;scientist"
05/19/2022 - 14:29:13: "sv_alltalk" = "0"
05/19/2022 - 14:29:13: "mp_footsteps" = "1"
05/19/2022 - 14:29:13: "survivor_limit" = "4"
05/19/2022 - 14:29:13: "sv_noclipaccelerate" = "5"
05/19/2022 - 14:29:13: "sv_wateraccelerate" = "10"
05/19/2022 - 14:29:13: "mp_autocrosshair" = "1"
05/19/2022 - 14:29:13: "mp_stalemate_enable" = "0"
05/19/2022 - 14:29:13: "sv_rollspeed" = "200"
05/19/2022 - 14:29:13: "sv_airaccelerate" = "10"
05/19/2022 - 14:29:13: "mp_teams_unbalance_limit" = "1"
05/19/2022 - 14:29:13: "mp_timelimit" = "0"
05/19/2022 - 14:29:13: "mp_fadetoblack" = "0"
05/19/2022 - 14:29:13: "sv_noclipfriction" = "4"
05/19/2022 - 14:29:13: "sv_waterfriction" = "1"
05/19/2022 - 14:29:13: "sv_steamgroup" = ""
05/19/2022 - 14:29:13: "coop" = "0"
05/19/2022 - 14:29:13: "nextlevel" = ""
05/19/2022 - 14:29:13: "sv_stopspeed" = "75"
05/19/2022 - 14:29:13: "sv_specaccelerate" = "5"
05/19/2022 - 14:29:13: "deathmatch" = "1"
05/19/2022 - 14:29:13: "tv_enable" = "0"
05/19/2022 - 14:29:13: "mp_falldamage" = "0"
05/19/2022 - 14:29:13: "mp_freezetime" = "6"
05/19/2022 - 14:29:13: "sv_voiceenable" = "1"
05/19/2022 - 14:29:13: "sv_bounce" = "0"
05/19/2022 - 14:29:13: "tf_arena_max_streak" = "5"
05/19/2022 - 14:29:13: "r_AirboatViewDampenFreq" = "7.0"
05/19/2022 - 14:29:13: "mp_disable_respawn_times" = "0"
05/19/2022 - 14:29:13: "mp_weaponstay" = "0"
05/19/2022 - 14:29:13: "mp_friendlyfire" = "1"
05/19/2022 - 14:29:13: "sv_noclipspeed" = "5"
05/19/2022 - 14:29:13: "r_JeepViewDampenDamp" = "1.0"
05/19/2022 - 14:29:13: "mp_c4timer" = "45"
05/19/2022 - 14:29:13: "r_AirboatViewDampenDamp" = "1.0"
05/19/2022 - 14:29:13: "mp_stalemate_at_timelimit" = "0"
05/19/2022 - 14:29:13: "sv_footsteps" = "1"
05/19/2022 - 14:29:13: "mp_limitteams" = "2"
05/19/2022 - 14:29:13: "tv_relaypassword" = ""
05/19/2022 - 14:29:13: "tf_arena_round_time" = "0"
05/19/2022 - 14:29:13: "mp_teamplay" = "0"
05/19/2022 - 14:29:13: "r_JeepViewDampenFreq" = "7.0"
05/19/2022 - 14:29:13: "sv_specnoclip" = "1"
05/19/2022 - 14:29:13: "sv_friction" = "4"
05/19/2022 - 14:29:13: "mp_autoteambalance" = "1"
05/19/2022 - 14:29:13: "sv_contact" = ""
05/19/2022 - 14:29:13: "director_afk_timeout" = "45"
05/19/2022 - 14:29:13: "mp_roundtime" = "5"
05/19/2022 - 14:29:13: "mp_fraglimit" = "0"
05/19/2022 - 14:29:13: "mp_forcerespawn" = "1"
05/19/2022 - 14:29:13: "decalfrequency" = "10"
05/19/2022 - 14:29:13: "sv_accelerate" = "5"
05/19/2022 - 14:29:13: "mp_winlimit" = "0"
05/19/2022 - 14:29:13: "sv_gravity" = "800"
05/19/2022 - 14:29:13: "sv_password" = ""
05/19/2022 - 14:29:13: "r_JeepViewZHeight" = "10.0"
05/19/2022 - 14:29:13: "tf_arena_preround_time" = "10"
05/19/2022 - 14:29:13: "tv_password" = ""
05/19/2022 - 14:29:13: "sv_specspeed" = "3"
05/19/2022 - 14:29:13: server cvars end
[14:29:13] [srcds:admin Info] : Setting up RCON...
[14:29:13] [System:admin Warning] : The application stopped unexpectedly. Exit code -532265403
05/19/2022 - 14:29:15: Preventing spawning
05/19/2022 - 14:29:15: Log file closed
05/19/2022 - 14:29:15: Log file started (file "logs\L192_168_002_244_27015_202205191429_001.log") (game "D:\AMPDatastore\Instances\Left4Dead2\srcds\222860\left4dead2") (version "8490")
05/19/2022 - 14:29:15: Loading map "c1m1_hotel"
05/19/2022 - 14:29:15: server cvars start
05/19/2022 - 14:29:15: "sv_maxspeed" = "320"
05/19/2022 - 14:29:15: "sv_rollangle" = "0"
05/19/2022 - 14:29:15: "tauntfrequency" = "1"
05/19/2022 - 14:29:15: "r_AirboatViewZHeight" = "0.0"
05/19/2022 - 14:29:15: "sv_cheats" = "0"
05/19/2022 - 14:29:15: "r_VehicleViewDampen" = "1"
05/19/2022 - 14:29:15: "mp_allowNPCs" = "1"
05/19/2022 - 14:29:15: "god" = "0"
05/19/2022 - 14:29:15: "mp_tournament" = "0"
05/19/2022 - 14:29:15: "buddha" = "0"
05/19/2022 - 14:29:15: "mp_flashlight" = "1"
05/19/2022 - 14:29:15: "mp_maxrounds" = "0"
05/19/2022 - 14:29:15: "sv_tags" = ""
05/19/2022 - 14:29:15: "sv_stepsize" = "18"
05/19/2022 - 14:29:15: "mp_teamlist" = "hgrunt;scientist"
05/19/2022 - 14:29:15: "sv_alltalk" = "0"
05/19/2022 - 14:29:15: "mp_footsteps" = "1"
05/19/2022 - 14:29:15: "survivor_limit" = "4"
05/19/2022 - 14:29:15: "sv_noclipaccelerate" = "5"
05/19/2022 - 14:29:15: "sv_wateraccelerate" = "10"
05/19/2022 - 14:29:15: "mp_autocrosshair" = "1"
05/19/2022 - 14:29:15: "mp_stalemate_enable" = "0"
05/19/2022 - 14:29:15: "sv_rollspeed" = "200"
05/19/2022 - 14:29:15: "sv_airaccelerate" = "10"
05/19/2022 - 14:29:15: "mp_teams_unbalance_limit" = "1"
05/19/2022 - 14:29:15: "mp_timelimit" = "0"
[14:29:15] [System:admin Warning] : The application stopped unexpectedly. Exit code -532265403
05/19/2022 - 14:29:16: Preventing spawning
05/19/2022 - 14:29:16: Log file closed
05/19/2022 - 14:29:16: Log file started (file "logs\L192_168_002_244_27015_202205191429_002.log") (game "D:\AMPDatastore\Instances\Left4Dead2\srcds\222860\left4dead2") (version "8490")
05/19/2022 - 14:29:16: Loading map "c1m1_hotel"
05/19/2022 - 14:29:16: server cvars start
05/19/2022 - 14:29:16: "sv_maxspeed" = "320"
05/19/2022 - 14:29:16: "sv_rollangle" = "0"
05/19/2022 - 14:29:16: "tauntfrequency" = "1"
05/19/2022 - 14:29:16: "r_AirboatViewZHeight" = "0.0"
05/19/2022 - 14:29:16: "sv_cheats" = "0"
05/19/2022 - 14:29:16: "r_VehicleViewDampen" = "1"
05/19/2022 - 14:29:16: "mp_allowNPCs" = "1"
05/19/2022 - 14:29:16: "god" = "0"
05/19/2022 - 14:29:16: "mp_tournament" = "0"
05/19/2022 - 14:29:16: "buddha" = "0"
05/19/2022 - 14:29:16: "mp_flashlight" = "1"
05/19/2022 - 14:29:16: "mp_maxrounds" = "0"
05/19/2022 - 14:29:16: "sv_tags" = ""
05/19/2022 - 14:29:16: "sv_stepsize" = "18"
05/19/2022 - 14:29:16: "mp_teamlist" = "hgrunt;scientist"
05/19/2022 - 14:29:16: "sv_alltalk" = "0"
05/19/2022 - 14:29:16: "mp_footsteps" = "1"
05/19/2022 - 14:29:16: "survivor_limit" = "4"
05/19/2022 - 14:29:16: "sv_noclipaccelerate" = "5"
05/19/2022 - 14:29:16: "sv_wateraccelerate" = "10"
05/19/2022 - 14:29:16: "mp_autocrosshair" = "1"
05/19/2022 - 14:29:16: "mp_stalemate_enable" = "0"
05/19/2022 - 14:29:16: "sv_rollspeed" = "200"
05/19/2022 - 14:29:16: "sv_airaccelerate" = "10"
05/19/2022 - 14:29:16: "mp_teams_unbalance_limit" = "1"
05/19/2022 - 14:29:16: "mp_timelimit" = "0"
05/19/2022 - 14:29:16: "mp_fadetoblack" = "0"
05/19/2022 - 14:29:16: "sv_noclipfriction" = "4"
05/19/2022 - 14:29:16: "sv_waterfriction" = "1"
05/19/2022 - 14:29:16: "sv_steamgroup" = ""
05/19/2022 - 14:29:16: "coop" = "0"
05/19/2022 - 14:29:16: "nextlevel" = ""
05/19/2022 - 14:29:16: "sv_stopspeed" = "75"
05/19/2022 - 14:29:16: "sv_specaccelerate" = "5"
05/19/2022 - 14:29:16: "deathmatch" = "1"
05/19/2022 - 14:29:16: "tv_enable" = "0"
[14:29:16] [System:admin Warning] : The application stopped unexpectedly. Exit code -532265403
05/19/2022 - 14:29:18: Preventing spawning
05/19/2022 - 14:29:18: Log file closed
[14:29:18] [System:admin Warning] : The application stopped unexpectedly. Exit code -532265403
05/19/2022 - 14:29:19: Preventing spawning
05/19/2022 - 14:29:19: Log file closed
[14:29:19] [System:admin Warning] : The application stopped unexpectedly. Exit code -532265403
05/19/2022 - 14:29:21: Preventing spawning
05/19/2022 - 14:29:21: Log file closed
05/19/2022 - 14:29:21: Log file started (file "logs\L192_168_002_244_27015_202205191429_004.log") (game "D:\AMPDatastore\Instances\Left4Dead2\srcds\222860\left4dead2") (version "8490")
05/19/2022 - 14:29:21: Loading map "c1m1_hotel"
05/19/2022 - 14:29:21: server cvars start
05/19/2022 - 14:29:21: "sv_maxspeed" = "320"
05/19/2022 - 14:29:21: "sv_rollangle" = "0"
05/19/2022 - 14:29:21: "tauntfrequency" = "1"
05/19/2022 - 14:29:21: "r_AirboatViewZHeight" = "0.0"
05/19/2022 - 14:29:21: "sv_cheats" = "0"
05/19/2022 - 14:29:21: "r_VehicleViewDampen" = "1"
05/19/2022 - 14:29:21: "mp_allowNPCs" = "1"
05/19/2022 - 14:29:21: "god" = "0"
05/19/2022 - 14:29:21: "mp_tournament" = "0"
05/19/2022 - 14:29:21: "buddha" = "0"
05/19/2022 - 14:29:21: "mp_flashlight" = "1"
05/19/2022 - 14:29:21: "mp_maxrounds" = "0"
05/19/2022 - 14:29:21: "sv_tags" = ""
05/19/2022 - 14:29:21: "sv_stepsize" = "18"
05/19/2022 - 14:29:21: "mp_teamlist" = "hgrunt;scientist"
05/19/2022 - 14:29:21: "sv_alltalk" = "0"
05/19/2022 - 14:29:21: "mp_footsteps" = "1"
05/19/2022 - 14:29:21: "survivor_limit" = "4"
05/19/2022 - 14:29:21: "sv_noclipaccelerate" = "5"
05/19/2022 - 14:29:21: "sv_wateraccelerate" = "10"
05/19/2022 - 14:29:21: "mp_autocrosshair" = "1"
05/19/2022 - 14:29:21: "mp_stalemate_enable" = "0"
05/19/2022 - 14:29:21: "sv_rollspeed" = "200"
05/19/2022 - 14:29:21: "sv_airaccelerate" = "10"
05/19/2022 - 14:29:21: "mp_teams_unbalance_limit" = "1"
05/19/2022 - 14:29:21: "mp_timelimit" = "0"
05/19/2022 - 14:29:21: "mp_fadetoblack" = "0"
05/19/2022 - 14:29:21: "sv_noclipfriction" = "4"
05/19/2022 - 14:29:21: "sv_waterfriction" = "1"
05/19/2022 - 14:29:21: "sv_steamgroup" = ""
05/19/2022 - 14:29:21: "coop" = "0"
05/19/2022 - 14:29:21: "nextlevel" = ""
05/19/2022 - 14:29:21: "sv_stopspeed" = "75"
05/19/2022 - 14:29:21: "sv_specaccelerate" = "5"
05/19/2022 - 14:29:21: "deathmatch" = "1"
05/19/2022 - 14:29:21: "tv_enable" = "0"
05/19/2022 - 14:29:21: "mp_falldamage" = "0"
05/19/2022 - 14:29:21: "mp_freezetime" = "6"
05/19/2022 - 14:29:21: "sv_voiceenable" = "1"
05/19/2022 - 14:29:21: "sv_bounce" = "0"
05/19/2022 - 14:29:21: "tf_arena_max_streak" = "5"
05/19/2022 - 14:29:21: "r_AirboatViewDampenFreq" = "7.0"
05/19/2022 - 14:29:21: "mp_disable_respawn_times" = "0"
05/19/2022 - 14:29:21: "mp_weaponstay" = "0"
05/19/2022 - 14:29:21: "mp_friendlyfire" = "1"
05/19/2022 - 14:29:21: "sv_noclipspeed" = "5"
05/19/2022 - 14:29:21: "r_JeepViewDampenDamp" = "1.0"
05/19/2022 - 14:29:21: "mp_c4timer" = "45"
05/19/2022 - 14:29:21: "r_AirboatViewDampenDamp" = "1.0"
05/19/2022 - 14:29:21: "mp_stalemate_at_timelimit" = "0"
05/19/2022 - 14:29:21: "sv_footsteps" = "1"
05/19/2022 - 14:29:21: "mp_limitteams" = "2"
05/19/2022 - 14:29:21: "tv_relaypassword" = ""
05/19/2022 - 14:29:21: "tf_arena_round_time" = "0"
05/19/2022 - 14:29:21: "mp_teamplay" = "0"
05/19/2022 - 14:29:21: "r_JeepViewDampenFreq" = "7.0"
05/19/2022 - 14:29:21: "sv_specnoclip" = "1"
05/19/2022 - 14:29:21: "sv_friction" = "4"
05/19/2022 - 14:29:21: "mp_autoteambalance" = "1"
05/19/2022 - 14:29:21: "sv_contact" = ""
05/19/2022 - 14:29:21: "director_afk_timeout" = "45"
05/19/2022 - 14:29:21: "mp_roundtime" = "5"
05/19/2022 - 14:29:21: "mp_fraglimit" = "0"
05/19/2022 - 14:29:21: "mp_forcerespawn" = "1"
[14:29:21] [System:admin Warning] : The application stopped unexpectedly. Exit code -532265403
05/19/2022 - 14:29:21: "decalfrequency" = "10"
05/19/2022 - 14:29:21: "sv_accelerate" = "5"
05/19/2022 - 14:29:21: "mp_winlimit" = "0"
05/19/2022 - 14:29:21: "sv_gravity" = "800"
05/19/2022 - 14:29:21: "sv_password" = ""
05/19/2022 - 14:29:21: "r_JeepViewZHeight" = "10.0"
05/19/2022 - 14:29:21: "tf_arena_preround_time" = "10"
05/19/2022 - 14:29:21: "tv_password" = ""
05/19/2022 - 14:29:21: "sv_specspeed" = "3"
05/19/2022 - 14:29:21: server cvars end
[14:29:21] [System:admin Warning] : Tried to start RCON but server is not in the correct state (Server is in PreStart state, expected 'Starting')
05/19/2022 - 14:29:22: Preventing spawning
[14:29:22] [System:admin Warning] : The application stopped unexpectedly. Exit code -532265403
05/19/2022 - 14:29:24: Preventing spawning
05/19/2022 - 14:29:24: Log file closed
05/19/2022 - 14:29:24: Log file started (file "logs\L192_168_002_244_27015_202205191429_005.log") (game "D:\AMPDatastore\Instances\Left4Dead2\srcds\222860\left4dead2") (version "8490")
05/19/2022 - 14:29:24: Loading map "c1m1_hotel"
05/19/2022 - 14:29:24: server cvars start
05/19/2022 - 14:29:24: "sv_maxspeed" = "320"
05/19/2022 - 14:29:24: "sv_rollangle" = "0"
05/19/2022 - 14:29:24: "tauntfrequency" = "1"
05/19/2022 - 14:29:24: "r_AirboatViewZHeight" = "0.0"
05/19/2022 - 14:29:24: "sv_cheats" = "0"
05/19/2022 - 14:29:24: "r_VehicleViewDampen" = "1"
05/19/2022 - 14:29:24: "mp_allowNPCs" = "1"
05/19/2022 - 14:29:24: "god" = "0"
05/19/2022 - 14:29:24: "mp_tournament" = "0"
05/19/2022 - 14:29:24: "buddha" = "0"
05/19/2022 - 14:29:24: "mp_flashlight" = "1"
05/19/2022 - 14:29:24: "mp_maxrounds" = "0"
05/19/2022 - 14:29:24: "sv_tags" = ""
05/19/2022 - 14:29:24: "sv_stepsize" = "18"
05/19/2022 - 14:29:24: "mp_teamlist" = "hgrunt;scientist"
05/19/2022 - 14:29:24: "sv_alltalk" = "0"
05/19/2022 - 14:29:24: "mp_footsteps" = "1"
05/19/2022 - 14:29:24: "survivor_limit" = "4"
05/19/2022 - 14:29:24: "sv_noclipaccelerate" = "5"
05/19/2022 - 14:29:24: "sv_wateraccelerate" = "10"
05/19/2022 - 14:29:24: "mp_autocrosshair" = "1"
05/19/2022 - 14:29:24: "mp_stalemate_enable" = "0"
05/19/2022 - 14:29:24: "sv_rollspeed" = "200"
05/19/2022 - 14:29:24: "sv_airaccelerate" = "10"
05/19/2022 - 14:29:24: "mp_teams_unbalance_limit" = "1"
05/19/2022 - 14:29:24: "mp_timelimit" = "0"
05/19/2022 - 14:29:24: "mp_fadetoblack" = "0"
05/19/2022 - 14:29:24: "sv_noclipfriction" = "4"
05/19/2022 - 14:29:24: "sv_waterfriction" = "1"
05/19/2022 - 14:29:24: "sv_steamgroup" = ""
05/19/2022 - 14:29:24: "coop" = "0"
05/19/2022 - 14:29:24: "nextlevel" = ""
05/19/2022 - 14:29:24: "sv_stopspeed" = "75"
05/19/2022 - 14:29:24: "sv_specaccelerate" = "5"
05/19/2022 - 14:29:24: "deathmatch" = "1"
[14:29:24] [System:admin Warning] : The application stopped unexpectedly. Exit code -532265403
05/19/2022 - 14:29:24: "tv_enable" = "0"
05/19/2022 - 14:29:24: "mp_falldamage" = "0"
05/19/2022 - 14:29:24: "mp_freezetime" = "6"
05/19/2022 - 14:29:24: "sv_voiceenable" = "1"
05/19/2022 - 14:29:24: "sv_bounce" = "0"
05/19/2022 - 14:29:24: "tf_arena_max_streak" = "5"
05/19/2022 - 14:29:24: "r_AirboatViewDampenFreq" = "7.0"
05/19/2022 - 14:29:24: "mp_disable_respawn_times" = "0"
05/19/2022 - 14:29:24: "mp_weaponstay" = "0"
05/19/2022 - 14:29:24: "mp_friendlyfire" = "1"
05/19/2022 - 14:29:24: "sv_noclipspeed" = "5"
05/19/2022 - 14:29:24: "r_JeepViewDampenDamp" = "1.0"
05/19/2022 - 14:29:24: "mp_c4timer" = "45"
05/19/2022 - 14:29:24: "r_AirboatViewDampenDamp" = "1.0"
05/19/2022 - 14:29:24: "mp_stalemate_at_timelimit" = "0"
05/19/2022 - 14:29:24: "sv_footsteps" = "1"
05/19/2022 - 14:29:24: "mp_limitteams" = "2"
05/19/2022 - 14:29:24: "tv_relaypassword" = ""
05/19/2022 - 14:29:24: "tf_arena_round_time" = "0"
05/19/2022 - 14:29:24: "mp_teamplay" = "0"
05/19/2022 - 14:29:24: "r_JeepViewDampenFreq" = "7.0"
05/19/2022 - 14:29:24: "sv_specnoclip" = "1"
05/19/2022 - 14:29:24: "sv_friction" = "4"
05/19/2022 - 14:29:24: "mp_autoteambalance" = "1"
05/19/2022 - 14:29:24: "sv_contact" = ""
05/19/2022 - 14:29:24: "director_afk_timeout" = "45"
05/19/2022 - 14:29:24: "mp_roundtime" = "5"
05/19/2022 - 14:29:24: "mp_fraglimit" = "0"
05/19/2022 - 14:29:25: Preventing spawning
05/19/2022 - 14:29:25: Log file closed
05/19/2022 - 14:29:25: Log file started (file "logs\L192_168_002_244_27015_202205191429_006.log") (game "D:\AMPDatastore\Instances\Left4Dead2\srcds\222860\left4dead2") (version "8490")
05/19/2022 - 14:29:25: Loading map "c1m1_hotel"
05/19/2022 - 14:29:25: server cvars start
05/19/2022 - 14:29:25: "sv_maxspeed" = "320"
05/19/2022 - 14:29:25: "sv_rollangle" = "0"
05/19/2022 - 14:29:25: "tauntfrequency" = "1"
05/19/2022 - 14:29:25: "r_AirboatViewZHeight" = "0.0"
05/19/2022 - 14:29:25: "sv_cheats" = "0"
05/19/2022 - 14:29:25: "r_VehicleViewDampen" = "1"
05/19/2022 - 14:29:25: "mp_allowNPCs" = "1"
05/19/2022 - 14:29:25: "god" = "0"
05/19/2022 - 14:29:25: "mp_tournament" = "0"
05/19/2022 - 14:29:25: "buddha" = "0"
05/19/2022 - 14:29:25: "mp_flashlight" = "1"
05/19/2022 - 14:29:25: "mp_maxrounds" = "0"
05/19/2022 - 14:29:25: "sv_tags" = ""
05/19/2022 - 14:29:25: "sv_stepsize" = "18"
05/19/2022 - 14:29:25: "mp_teamlist" = "hgrunt;scientist"
05/19/2022 - 14:29:25: "sv_alltalk" = "0"
05/19/2022 - 14:29:25: "mp_footsteps" = "1"
05/19/2022 - 14:29:25: "survivor_limit" = "4"
05/19/2022 - 14:29:25: "sv_noclipaccelerate" = "5"
05/19/2022 - 14:29:25: "sv_wateraccelerate" = "10"
05/19/2022 - 14:29:25: "mp_autocrosshair" = "1"
05/19/2022 - 14:29:25: "mp_stalemate_enable" = "0"
05/19/2022 - 14:29:25: "sv_rollspeed" = "200"
05/19/2022 - 14:29:25: "sv_airaccelerate" = "10"
05/19/2022 - 14:29:25: "mp_teams_unbalance_limit" = "1"
05/19/2022 - 14:29:25: "mp_timelimit" = "0"
05/19/2022 - 14:29:25: "mp_fadetoblack" = "0"
05/19/2022 - 14:29:25: "sv_noclipfriction" = "4"
05/19/2022 - 14:29:25: "sv_waterfriction" = "1"
05/19/2022 - 14:29:25: "sv_steamgroup" = ""
05/19/2022 - 14:29:25: "coop" = "0"
05/19/2022 - 14:29:25: "nextlevel" = ""
05/19/2022 - 14:29:25: "sv_stopspeed" = "75"
05/19/2022 - 14:29:25: "sv_specaccelerate" = "5"
05/19/2022 - 14:29:25: "deathmatch" = "1"
05/19/2022 - 14:29:25: "tv_enable" = "0"
05/19/2022 - 14:29:25: "mp_falldamage" = "0"
05/19/2022 - 14:29:25: "mp_freezetime" = "6"
05/19/2022 - 14:29:25: "sv_voiceenable" = "1"
05/19/2022 - 14:29:25: "sv_bounce" = "0"
05/19/2022 - 14:29:25: "tf_arena_max_streak" = "5"
05/19/2022 - 14:29:25: "r_AirboatViewDampenFreq" = "7.0"
05/19/2022 - 14:29:25: "mp_disable_respawn_times" = "0"
05/19/2022 - 14:29:25: "mp_weaponstay" = "0"
05/19/2022 - 14:29:25: "mp_friendlyfire" = "1"
05/19/2022 - 14:29:25: "sv_noclipspeed" = "5"
05/19/2022 - 14:29:25: "r_JeepViewDampenDamp" = "1.0"
05/19/2022 - 14:29:25: "mp_c4timer" = "45"
05/19/2022 - 14:29:25: "r_AirboatViewDampenDamp" = "1.0"
05/19/2022 - 14:29:25: "mp_stalemate_at_timelimit" = "0"
05/19/2022 - 14:29:25: "sv_footsteps" = "1"
05/19/2022 - 14:29:25: "mp_limitteams" = "2"
05/19/2022 - 14:29:25: "tv_relaypassword" = ""
05/19/2022 - 14:29:25: "tf_arena_round_time" = "0"
05/19/2022 - 14:29:25: "mp_teamplay" = "0"
05/19/2022 - 14:29:25: "r_JeepViewDampenFreq" = "7.0"
05/19/2022 - 14:29:25: "sv_specnoclip" = "1"
05/19/2022 - 14:29:25: "sv_friction" = "4"
05/19/2022 - 14:29:25: "mp_autoteambalance" = "1"
05/19/2022 - 14:29:25: "sv_contact" = ""
05/19/2022 - 14:29:25: "director_afk_timeout" = "45"
05/19/2022 - 14:29:25: "mp_roundtime" = "5"
05/19/2022 - 14:29:25: "mp_fraglimit" = "0"
05/19/2022 - 14:29:25: "mp_forcerespawn" = "1"
05/19/2022 - 14:29:25: "decalfrequency" = "10"
05/19/2022 - 14:29:25: "sv_accelerate" = "5"
05/19/2022 - 14:29:25: "mp_winlimit" = "0"
05/19/2022 - 14:29:25: "sv_gravity" = "800"
[14:29:25] [System:admin Warning] : The application stopped unexpectedly. Exit code -532265403
05/19/2022 - 14:29:25: "sv_password" = ""
05/19/2022 - 14:29:25: "r_JeepViewZHeight" = "10.0"
05/19/2022 - 14:29:25: "tf_arena_preround_time" = "10"
05/19/2022 - 14:29:25: "tv_password" = ""
05/19/2022 - 14:29:25: "sv_specspeed" = "3"
05/19/2022 - 14:29:25: server cvars end
[14:29:25] [System:admin Warning] : Tried to start RCON but server is not in the correct state (Server is in PreStart state, expected 'Starting')
05/19/2022 - 14:29:27: Preventing spawning
[14:29:27] [System:admin Warning] : The application stopped unexpectedly. Exit code -532265403
05/19/2022 - 14:29:28: Preventing spawning
[14:29:28] [System:admin Warning] : The application stopped unexpectedly. Exit code -532265403
05/19/2022 - 14:29:30: Preventing spawning
05/19/2022 - 14:29:30: Log file closed
05/19/2022 - 14:29:30: Log file started (file "logs\L192_168_002_244_27015_202205191429_007.log") (game "D:\AMPDatastore\Instances\Left4Dead2\srcds\222860\left4dead2") (version "8490")
05/19/2022 - 14:29:30: Loading map "c1m1_hotel"
05/19/2022 - 14:29:30: server cvars start
05/19/2022 - 14:29:30: "sv_maxspeed" = "320"
05/19/2022 - 14:29:30: "sv_rollangle" = "0"
05/19/2022 - 14:29:30: "tauntfrequency" = "1"
05/19/2022 - 14:29:30: "r_AirboatViewZHeight" = "0.0"
05/19/2022 - 14:29:30: "sv_cheats" = "0"
05/19/2022 - 14:29:30: "r_VehicleViewDampen" = "1"
05/19/2022 - 14:29:30: "mp_allowNPCs" = "1"
05/19/2022 - 14:29:30: "god" = "0"
05/19/2022 - 14:29:30: "mp_tournament" = "0"
05/19/2022 - 14:29:30: "buddha" = "0"
05/19/2022 - 14:29:30: "mp_flashlight" = "1"
05/19/2022 - 14:29:30: "mp_maxrounds" = "0"
05/19/2022 - 14:29:30: "sv_tags" = ""
05/19/2022 - 14:29:30: "sv_stepsize" = "18"
05/19/2022 - 14:29:30: "mp_teamlist" = "hgrunt;scientist"
05/19/2022 - 14:29:30: "sv_alltalk" = "0"
05/19/2022 - 14:29:30: "mp_footsteps" = "1"
05/19/2022 - 14:29:30: "survivor_limit" = "4"
05/19/2022 - 14:29:30: "sv_noclipaccelerate" = "5"
05/19/2022 - 14:29:30: "sv_wateraccelerate" = "10"
05/19/2022 - 14:29:30: "mp_autocrosshair" = "1"
05/19/2022 - 14:29:30: "mp_stalemate_enable" = "0"
05/19/2022 - 14:29:30: "sv_rollspeed" = "200"
05/19/2022 - 14:29:30: "sv_airaccelerate" = "10"
05/19/2022 - 14:29:30: "mp_teams_unbalance_limit" = "1"
05/19/2022 - 14:29:30: "mp_timelimit" = "0"
05/19/2022 - 14:29:30: "mp_fadetoblack" = "0"
05/19/2022 - 14:29:30: "sv_noclipfriction" = "4"
05/19/2022 - 14:29:30: "sv_waterfriction" = "1"
05/19/2022 - 14:29:30: "sv_steamgroup" = ""
05/19/2022 - 14:29:30: "coop" = "0"
05/19/2022 - 14:29:30: "nextlevel" = ""
05/19/2022 - 14:29:30: "sv_stopspeed" = "75"
05/19/2022 - 14:29:30: "sv_specaccelerate" = "5"
05/19/2022 - 14:29:30: "deathmatch" = "1"
05/19/2022 - 14:29:30: "tv_enable" = "0"
05/19/2022 - 14:29:30: "mp_falldamage" = "0"
05/19/2022 - 14:29:30: "mp_freezetime" = "6"
05/19/2022 - 14:29:30: "sv_voiceenable" = "1"
05/19/2022 - 14:29:30: "sv_bounce" = "0"
05/19/2022 - 14:29:30: "tf_arena_max_streak" = "5"
05/19/2022 - 14:29:30: "r_AirboatViewDampenFreq" = "7.0"
[14:29:30] [System:admin Warning] : The application stopped unexpectedly. Exit code -532265403
[14:29:31] [System:admin Warning] : The application stopped unexpectedly. Exit code -532265403
[14:29:32] [System:admin Warning] : The application stopped unexpectedly. Exit code -532265403
[14:29:34] [System:admin Warning] : The application stopped unexpectedly. Exit code -532265403
Can you try converting AMP to not run as a service? You’ll need to shut down AMP fully and use the GUI to do this then make a new instance.
I guess I can.
How does one go about doing this?
ok, that works - kind of.
Putting aside the fact that it exploded when trying to remove the existing L4D2 instance (as it was owned by Network Service) and had to be cleaned up manually.
It created an instance, installed and updated correctly - I could even connect to the server. However, in the UI popup (as it is now running in UI mode) it was not able to connect to the steam library and was running in LAN mode only.
I thought that maybe running the service in either local server (with desktop interaction) or with a dedicated user might be better - but nope AMP prevents that.
Is there any way to get source dedicated servers to work properly with Service mode? UI mode isn’t really an option - and sort of defeats the purpose of running a server.
Mike
19 May 2022 14:59
10
Not all source servers can run as services on Windows because they try to use desktop specific APIs/paths which crashes them. It’s part of why Windows isn’t really used for hosting them. If it’s in LAN only mode though that usually means there’s a problem with the GSLT token. You can use a dedicated user but AMP must not have admin rights. If AMP detects that it has admin rights then it shuts down.
The ‘cheat’ way around sometimes works - basically you use the Windows Scheduler to run ampinstmgr startall on boot with the “Run whether the user is logged in or not” flag enabled - but sometimes this can have the same result. This of course requires that you have a separate AMP user and aren’t running as Administrator.
Failing that, the standing advice is to either set up a Linux VM inside Hyper-V, or to switch to Linux entirely for Source based servers.
The other thing to try (assuming you have a dedicated AMP user) is using AMPs startup script generation to verify that it is specifically running as a service that is breaking things. AMP can generate a batch script that’s the exact equivalent of what AMP is trying to launch for debugging purposes: Diagnosing AMP issues · CubeCoders/AMP Wiki · GitHub
This makes sense - I’d rather not try and force AMP’s hand by trying to trick it - that could just cause more issues further down the road.
I can easily throw together a Linux based VM - got enough resource to do that. The Windows server is mainly for Space Engineers, running that on Linux is far from ideal - maybe one day Keen will make a Linux DS for it…can keep dreaming.
My only concern with this is that I have already had to install AMP twice on the same Windows server - it went horribly wrong the first time! I enter my license key in the install GUI, then it asks again in the web GUI…and apparently the key has already been used 3 of the 5 times (it’s probably 4 of 5 now)! So I am concerned that it will fail to register properly
But only way to know for sure is to try it out. If it tells me that my license is not valid/used too much I’ll log a separate ticket for that.
Mike
19 May 2022 15:39
12
Ah don’t worry about that, the licence system was built to accommodate the situation where there’s a bunch of chopping and changing because of testing etc.
So sadly running an AMP install on a Debain 11 (inside an ESXi 6.5 virtual machine) is also not working quite right.
When starting the application I get the below log generated. But the application just sits at starting - and yes the log that seems to be truncated is exactly what is in the file.
Which is frustrating as at least under Windows (in GUI mode) it would start and show console details.
L 05/19/2022 - 19:26:29: Log file started (file "logs/L000_000_000_000_27015_202205191926_000.log") (game "/home/amp/.ampdata/instances/Left4Dead2/srcds/222860/left4dead2") (version "8491")
L 05/19/2022 - 19:26:29: Loading map "c1m1_hotel"
L 05/19/2022 - 19:26:29: server cvars start
L 05/19/2022 - 19:26:29: "sv_maxspeed" = "320"
L 05/19/2022 - 19:26:29: "sv_rollangle" = "0"
L 05/19/2022 - 19:26:29: "tauntfrequency" = "1"
L 05/19/2022 - 19:26:29: "r_AirboatViewZHeight" = "0.0"
L 05/19/2022 - 19:26:29: "sv_cheats" = "0"
L 05/19/2022 - 19:26:29: "r_VehicleViewDampen" = "1"
L 05/19/2022 - 19:26:29: "mp_allowNPCs" = "1"
L 05/19/2022 - 19:26:29: "god" = "0"
L 05/19/2022 - 19:26:29: "mp_tournament" = "0"
L 05/19/2022 - 19:26:29: "buddha" = "0"
L 05/19/2022 - 19:26:29: "mp_maxrounds" = "0"
L 05/19/2022 - 19:26:29: "mp_flashlight" = "1"
L 05/19/2022 - 19:26:29: "sv_tags" = ""
L 05/19/2022 - 19:26:29: "sv_stepsize" = "18"
L 05/19/2022 - 19:26:29: "sv_alltalk" = "0"
L 05/19/2022 - 19:26:29: "mp_teamlist" = "hgrunt;scientist"
L 05/19/2022 - 19:26:29: "mp_footsteps" = "1"
L 05/19/2022 - 19:26:29: "survivor_limit" = "4"
L 05/19/2022 - 19:26:29: "sv_noclipaccelerate" = "5"
L 05/19/2022 - 19:26:29: "sv_wateraccelerate" = "10"
L 05/19/2022 - 19:26:29: "mp_stalemate_enable" = "0"
L 05/19/2022 - 19:26:29: "mp_autocrosshair" = "1"
L 05/19/2022 - 19:26:29: "sv_rollspeed" = "200"
L 05/19/2022 - 19:26:29: "sv_airaccelerate" = "10"
L 05/19/2022 - 19:26:29: "mp_teams_unbalance_limit" = "1"
L 05/19/2022 - 19:26:29: "mp_timelimit" = "0"
L 05/19/2022 - 19:26:29: "mp_fadetoblack" = "0"
L 05/19/2022 - 19:26:29: "sv_noclipfriction" = "4"
L 05/19/2022 - 19:26:29: "sv_waterfriction" = "1"
L 05/19/2022 - 19:26:29: "sv_steamgroup" = ""
L 05/19/2022 - 19:26:29: "coop" = "0"
L 05/19/2022 - 19:26:29: "nextlevel" = ""
L 05/19/2022 - 19:26:29: "sv_stopspeed" = "75"
L 05/19/2022 - 19:26:29: "sv_specaccelerate" = "5"
L 05/19/2022 - 19:26:29: "deathmatch" = "1"
L 05/19/2022 - 19:26:29: "tv_enable" = "0"
L 05/19/2022 - 19:26:29: "mp_freezetime" = "6"
L 05/19/2022 - 19:26:29: "mp_falldamage" = "0"
L 05/19/2022 - 19:26:29: "sv_voiceenable" = "1"
L 05/19/2022 - 19:26:29: "sv_bounce" = "0"
L 05/19/2022 - 19:26:29: "tf_arena_max_streak" = "5"
L 05/19/2022 - 19:26:29: "r_AirboatViewDampenFreq" = "7.0"
L 05/19/2022 - 19:26:29: "mp_disable_respawn_times" = "0"
L 05/19/2022 - 19:26:29: "mp_weaponstay" = "0"
L 05/19/2022 - 19:26:29: "mp_friendlyfire" = "1"
L 05/19/2022 - 19:26:29: "sv_noclipspeed" = "5"
L 05/19/2022 - 19:26:29: "mp_c4timer" = "45"
L 05/19/2022 - 19:26:29: "r_JeepViewDampenDamp" = "1.0"
L 05/19/2022 - 19:26:29: "r_AirboatViewDampenDamp" = "1.0"
L 05/19/2022 - 19:26:29: "mp_stalemate_at_timelimit" = "0"
L 05/19/2022 - 19:26:29: "mp_limitteams" = "2"
L 05/19/2022 - 19:26:29: "sv_footsteps" = "1"
L 05/19/2022 - 19:26:29: "tv_relaypassword" = ""
L 05/19/2022 - 19:26:29: "tf_arena_round_time" = "0"
L 05/19/2022 - 19:26:29: "mp_teamplay" = "0"
L 05/19/2022 - 19:26:29: "r_JeepViewDampenFreq" = "7.0"
L 05/19/2022 - 19:26:29: "sv_specnoclip" = "1"
L 05/19/2022 - 19:26:29: "sv_friction" = "4"
L 05/19/2022 - 19:26:29: "mp_autoteambalance" = "1"
L 05/19/2022 - 19:26:29: "sv_contact" = ""
L 05/19/2022 - 19:26:29: "director_afk_timeout" = "45"
L 05/19/2022 - 19:26:29: "mp_roundtime" = "5"
L 05/19/2022 - 19:26:29: "mp_fraglimit" = "0"
L 05/19/2022 - 19:26:29: "mp_forcerespawn" = "1"
L 05/19/2022 - 19:26:29: "decalfrequency" = "10"
L 05/19/2022 - 19:26:29: "sv_accelerate" = "5"
L 05/19/2022 - 19:26:29: "mp_winlimit" = "0"
L 05/19/2022 - 19:26:29: "sv_gravity" = "800"
L 05/19/2022 - 19:26:29: "sv_password" = ""
L 05/19/2022 - 19:26:29: "r_JeepViewZHeight" = "10.0"
L 05/19/2022 - 19:26:29: "tf_arena_preround_time" = "10"
L 05/19/2022 - 19:26:29: "tv_password" = ""
L 05/19/2022 - 19:26:29: "sv_specspeed" = "3"
L 05/19/2022 - 19:26:29: server cvars end
L 05/19/2022 - 19:26:30: Started map "c1m1_hotel" (CRC "-1242577269")
L 05/19/2022 - 19:26:32: CDirector::RunScript, scriptedmode, level: 1
L 05/19/2022 - 19:26:32: CDirector::RunScript, director_base, level: 0
L 05/19/2022 - 19:
Mike
21 May 2022 09:05
14
Sanity check again that GLST is setup and that the IP binding is valid? (Not 0.0.0.0)
Also use ampinstmgr ports to see if it’s actually listening at that point and try connecting.
Hi Mike,
thanks for getting back to me.
So I double checked the GSLT - it’s correct
I changed the server (under Instance → Configuration → Source Server Settings) as this was on 0.0.0.0 (how I missed this I don’t know)
Now the server starts…which is great.
However I can’t connect from the outside world. I have the router set to port forward what is required, but no matter what it just won’t connect. Looking at the server console it shows nothing (no attempt made to connect), but if I use the internal IP it instantly starts logging details - as expected.
I am thinking this is probably a Linux network firewall issue? If so, how do I go about ‘fixing’ this? Sadly I’m a C#/Windows guys and my Linux knowledge is rather limited.
Mike
21 May 2022 16:57
16
If you can connect from a different device on the same network then it’s not a Firewall issue.
Not all routers support hairpin NAT (Or don’t have it enabled by default), so you won’t be able to connect using your external IP while inside your network.
First try seeing if your router does support hairpin NAT and if that can be turned on. Failing that the next experiment is connecting to your external IP from a different network (Tethering to your phone for example)
Hi Mike,
I’ve got it all sorted. Alas my router is a bit of junk - lets face it most of them provided by ISP’s are cheap and nasty, they just put a ‘nice’ plastic face on generic Thompson hardware. Anyway…
I know it does the correct NAT as other systems have no problem, but it turns out that despite telling it to forward the correct ports to the correct IP it decided it was time for Tea and biscuits. The old turn off and back on woke it back up and it suddenly realised the port forwarding table had been updated. Should have tried this first!
Thanks for all of your help, not sure I would have persevered otherwise!
Mike
21 May 2022 17:27
18
You’re welcome, if you could kindly mark the post as solved
