OS Name/Version: Ubuntu 24.04 LTS x64
Product Name/Version: AMP Release “Phobos” v2.6.0.6, built 20/11/2024 20:57
Problem Description: Team Fortress 2 64bit Linux Metamod and Sourcemod don’t work
- Step 1 Install AMP on a 64bit Linux OS
- Step 2 Install Team Fortress 2 64bit
- Step 3 Set Metamod and Sourcemod to valid versions/builds and set them to enabled
- Step 4 Test Metamod and Sourcemod commands, they will not work even though both are enabled and valid
Installed the 32bit version of Team Fortress 2 on the same system with the exact same settings as a new instance and both Metamod and Sourcemod work correctly and respond on the console without issue.
