Terraria cannot use command
I successfully opened the Terraria instance, but I cannot use the command in the Console
@CubeCoders-Bot
Hey there! :video_game: If you’re having trouble using commands in the Terraria Console through AMP, the first step is to check if the server is actually running and accepting commands. You can view the console by right-clicking on the Terraria instance in AMP and selecting “View Console” to see if any errors pop up there.
Sometimes, the console might not respond if the server hasn’t fully started up or if there are permission issues. Let me know if you see any unusual messages or warnings when you do that!
There is no error in the Console, and there is no response when entering commands.
No errors, huh? :thinking: That’s sneaky. Let’s make sure the console is actually linked up properly. Occasionally, AMP might not have the right perms or settings for the console to receive input. Here’s what to check next:
  1. In the Terraria instance settings, look for any console-related settings by using the Search box in the top right corner of AMP.
  2. Make sure the console feature is enabled and properly configured.
Give it a look and see if there’s anything fishy there! If everything seems right, we might need to consider the Terraria server settings themselves. Let me know!
I turned on the Console Passthrough option and restarted the instance. There was no error in the Console, and there was no response to the input commands.
19:45:20
Settling liquids 42%
Settling liquids 43%
Settling liquids 44%
Settling liquids 45%
Settling liquids 46%
Settling liquids 47%
Settling liquids 48%
Settling liquids 49%
Settling liquids 50%
Terraria Server v1.4.4.9
Listening on port 28002
Type ‘help’ for a list of commands.
: Server started
That all looks pretty normal for a Terraria server startup. :glowing_star: Since “Console Passthrough” is on and there are no errors, let’s try something else:
Check if the Terraria server itself is configured to accept commands. Sometimes the issue can come from within the game server settings rather than AMP. In AMP, under the Terraria settings, see if there are any options related to remote commands or permissions.
Also, make sure any in-game admin settings are properly configured. Sometimes external commands are blocked unless a specific admin role or token is used.
If all of those look good and commands still aren’t working, we might be dealing with a more elusive problem. Let me know how it goes!
When starting an instance without using AMP, you can use commands through command prompt characters. Is there something wrong with AMP?
AMP should typically handle commands through the console without any additional hassle, so it’s odd that you’re having this issue. :thinking:
Let’s double-check a few things:
  1. Permissions: Make sure the AMP instance user has the proper permissions to execute commands on the Terraria server. If the game server itself has config settings for remote administration, those should match up or allow AMP to manage them.
  2. Instance Logs: Within AMP, use the “View Logs” option for the instance to see if anything weird is logged when you try to enter commands. There might be a hidden clue there!
  3. Server Console: If possible, try using the Terraria server’s own console interface directly (not through AMP) as a test, just to see if the issue persists there as well.
If these don’t resolve it, there might be an AMP configuration that’s clashing, and we might need to dig into the specific AMP logs or settings further. Let me know what you find!
[11:58:34] [Program Info/1] : Starting AMP version 2.5.1.6 (Callisto), built 16/08/2024 03:11
[11:58:34] [Program Info/1] : Stream: Mainline / Release - built by CUBECODERS/buildbot on CCL-DEV
[11:58:34] [Core Warning/1] : Current time zone is set to 台北標準時間 - It is recommended you switch to UTC+0 to avoid time-zone related issues
[11:58:34] [Program Info/1] : OS: Windows / x86_64
[11:58:34] [Program Info/1] : CPU: AMD Ryzen Threadripper 7960X 24-Cores (24C/48T)
[11:58:34] [Program Info/1] : RAM: 261642MB
[11:58:34] [Program Info/1] : AMP Instance ID: 0690140e-3fd0-47b6-a1e3-635f39d03bdf
[11:58:35] [Loader Info/1] : Loaded GenericModule version 1.0.0.0 by CubeCoders Limited
[11:58:35] [Core Info/1] : Metrics publishing is enabled at udp://localhost:12820.
[11:58:35] [Loader Info/1] : Loaded FileManagerPlugin by CubeCoders Limited
[11:58:35] [Loader Info/1] : Loaded EmailSenderPlugin by CubeCoders Limited
[11:58:35] [Loader Info/1] : Loaded WebRequestPlugin by CubeCoders Limited
[11:58:35] [Loader Info/1] : Loaded LocalFileBackupPlugin by CubeCoders Limited
[11:58:35] [Loader Info/1] : Loaded CommonCorePlugin by CubeCoders Limited
[11:58:35] [Loader Info/1] : Loaded AnalyticsPlugin by CubeCoders Limited
[11:58:35] [Loader Info/1] : GenericModule requests dependency steamcmdplugin…
[11:58:35] [Loader Info/1] : Loaded steamcmdplugin by CubeCoders Limited
[11:58:35] [Loader Info/1] : GenericModule requests dependency RCONPlugin…
[11:58:35] [Loader Info/1] : Loaded RCONPlugin by CubeCoders Limited
[11:58:35] [Core Info/1] : Licence Present: AMP Professional Edition - Lifetime Licence
[11:58:35] [FileManager Notice/1] : Using keypair with fingerprint Td+Fqhbqz4xMrNmNq9UKOdXD34t57PDiaNg4ub05uoA=
[11:58:35] [FileManager Info/1] : SFTP Server started on 0.0.0.0:2319
[11:58:35] [Webserver Info/1] : Websockets are enabled.
[11:58:35] [Webserver Info/1] : Webserver started on http://0.0.0.0:29003
[11:58:35] [Webserver Info/14] : RouterTimer@10Hz with 2 jobs started
[11:58:35] [Core Info/10] : Checking for AMP updates…
[11:58:37] [Core Info/11] : AMP is up to date.
[11:58:41] [Core Activity/11] : Authentication attempt for user admin from 127.0.0.1
[11:58:44] [Core Activity/12] : Authentication success
[11:58:44] [Core Warning/12] : Slow method invocation: Login took 2552ms to complete.
[11:58:44] [Core Warning/12] : Slow response: Core.Login took 2557ms to complete.
[11:58:45] [API:admin Activity/12] : Starting the application.
[11:58:45] [Generic:admin Info/12] : Merging config file ./Terraria/serverfiles\terrariaserverconfig.txt (KVP format) using Unicode (UTF-8) encoding.
Resetting game objects 1%
Resetting game objects 2%
Resetting game objects 3%
Resetting game objects 4%
Resetting game objects 5%
Resetting game objects 6%
Resetting game objects 7%
Resetting game objects 8%
Resetting game objects 9%
Resetting game objects 10%
Resetting game objects 11%
Resetting game objects 12%
Resetting game objects 13%
Resetting game objects 14%
Resetting game objects 15%
Resetting game objects 16%
Resetting game objects 17%
Resetting game objects 18%
Resetting game objects 19%
Resetting game objects 20%
Resetting game objects 21%
Resetting game objects 22%
Resetting game objects 23%
Resetting game objects 24%
Resetting game objects 25%
Resetting game objects 26%
Resetting game objects 27%
Resetting game objects 28%
Resetting game objects 29%
Resetting game objects 30%
Resetting game objects 31%
Resetting game objects 32%
Resetting game objects 33%
Resetting game objects 34%
Resetting game objects 35%
Resetting game objects 36%
Resetting game objects 37%
Resetting game objects 38%
Resetting game objects 39%
Resetting game objects 40%
Resetting game objects 41%
Resetting game objects 42%
Resetting game objects 43%
Resetting game objects 44%
Resetting game objects 45%
Resetting game objects 46%
Resetting game objects 47%
Resetting game objects 48%
Resetting game objects 49%
Resetting game objects 50%
Resetting game objects 51%
Resetting game objects 52%
Resetting game objects 53%
Resetting game objects 54%
Resetting game objects 55%
Resetting game objects 56%
Resetting game objects 57%
Resetting game objects 58%
Resetting game objects 59%
Resetting game objects 60%
Resetting game objects 61%
Resetting game objects 62%
Resetting game objects 63%
Resetting game objects 64%
Resetting game objects 65%
Resetting game objects 66%
Resetting game objects 67%
Resetting game objects 68%
Resetting game objects 69%
Resetting game objects 70%
Resetting game objects 71%
Resetting game objects 72%
Resetting game objects 73%
Resetting game objects 74%
Resetting game objects 75%
Resetting game objects 76%
Resetting game objects 77%
Resetting game objects 78%
Resetting game objects 79%
Resetting game objects 80%
Resetting game objects 81%
Resetting game objects 82%
Resetting game objects 83%
Resetting game objects 84%
Resetting game objects 85%
Resetting game objects 86%
Resetting game objects 87%
Resetting game objects 88%
Resetting game objects 89%
Resetting game objects 90%
Resetting game objects 91%
Resetting game objects 92%
Resetting game objects 93%
Resetting game objects 94%
Resetting game objects 95%
Resetting game objects 96%
Resetting game objects 97%
Resetting game objects 98%
Resetting game objects 99%
Resetting game objects 100%
Loading world data: 1%
Loading world data: 2%
Loading world data: 3%
Loading world data: 4%
Loading world data: 5%
Loading world data: 6%
Loading world data: 7%
Loading world data: 8%
Loading world data: 9%
Loading world data: 10%
Loading world data: 11%
Loading world data: 12%
Loading world data: 13%
Loading world data: 14%
Loading world data: 15%
Loading world data: 16%
Loading world data: 17%
Loading world data: 18%
Loading world data: 19%
Loading world data: 20%
Loading world data: 21%
Loading world data: 22%
Loading world data: 23%
Loading world data: 24%
Loading world data: 25%
Loading world data: 26%
Loading world data: 27%
Loading world data: 28%
Loading world data: 29%
Loading world data: 30%
Loading world data: 31%
Loading world data: 32%
Loading world data: 33%
Loading world data: 34%
Loading world data: 35%
Loading world data: 36%
Loading world data: 37%
Loading world data: 38%
Loading world data: 39%
Loading world data: 40%
Loading world data: 41%
Loading world data: 42%
Loading world data: 43%
Loading world data: 44%
Loading world data: 45%
Loading world data: 46%
Loading world data: 47%
Loading world data: 48%
Loading world data: 49%
Loading world data: 50%
Loading world data: 51%
Loading world data: 52%
Loading world data: 53%
Loading world data: 54%
Loading world data: 55%
Loading world data: 56%
Loading world data: 57%
Loading world data: 58%
Loading world data: 59%
Loading world data: 60%
Loading world data: 61%
Loading world data: 62%
Loading world data: 63%
Loading world data: 64%
Loading world data: 65%
Loading world data: 66%
Loading world data: 67%
Loading world data: 68%
Loading world data: 69%
Loading world data: 70%
Loading world data: 71%
Loading world data: 72%
Loading world data: 73%
Loading world data: 74%
Loading world data: 75%
Loading world data: 76%
Loading world data: 77%
Loading world data: 78%
Loading world data: 79%
Loading world data: 80%
Loading world data: 81%
Loading world data: 82%
Loading world data: 83%
Loading world data: 84%
Loading world data: 85%
Loading world data: 86%
Loading world data: 87%
Loading world data: 88%
Loading world data: 89%
Loading world data: 90%
Loading world data: 91%
Loading world data: 92%
Loading world data: 93%
Loading world data: 94%
Loading world data: 95%
Loading world data: 96%
Loading world data: 97%
Loading world data: 98%
Loading world data: 99%
Loading world data: 100%
Settling liquids 1%
Settling liquids 2%
Settling liquids 3%
Settling liquids 4%
Settling liquids 5%
Settling liquids 6%
Settling liquids 7%
Settling liquids 8%
Settling liquids 9%
Settling liquids 10%
Settling liquids 11%
Settling liquids 12%
Settling liquids 13%
Settling liquids 14%
Settling liquids 15%
Settling liquids 16%
Settling liquids 17%
Settling liquids 18%
Settling liquids 19%
Settling liquids 20%
Settling liquids 21%
Settling liquids 22%
Settling liquids 23%
Settling liquids 24%
Settling liquids 25%
Settling liquids 26%
Settling liquids 27%
Settling liquids 28%
Settling liquids 29%
Settling liquids 30%
Settling liquids 31%
Settling liquids 32%
Settling liquids 33%
Settling liquids 34%
Settling liquids 35%
Settling liquids 36%
Settling liquids 37%
Settling liquids 38%
Settling liquids 39%
Settling liquids 40%
Settling liquids 41%
: Server started
[11:59:02] [API:admin Activity/3] : Sent to console: help
Thanks for sharing that log! :nerd_face: It looks like the server is starting up correctly and AMP is sending commands to the console, but there’s still no response. Here’s something we could try:
RCON Configuration: Sometimes AMP and the game server might use RCON (Remote Console) for command inputs. Check the Terraria server settings in AMP and ensure RCON is enabled and configured correctly. Look for an RCON password setting, and make sure it matches what’s set on the Terraria server side.
In the Terraria instance within AMP:
  1. Use the Search box to locate any RCON settings.
  2. Ensure it’s enabled and that the password is set up properly.
If RCON isn’t the issue, there might be a deeper console input problem that we might need to dig into. Keep me posted!
No results for ‘RCON’
Try using a simpler query with fewer search terms, or try the options below:
Search Knowledge Base
Click to search the knowledge base for ‘RCON’
Search CubeCoders Support
Click to check the official support board for posts about ‘RCON’
Whoops, got a bit tangled in the wires there! :sweat_smile: Let’s double-check what other settings might be impacting the console commands.
Sometimes, AMP handles certain features through other plugins or setups rather than direct RCON. We should ensure that any communication settings between AMP and Terraria are correctly configured. While RCON might not directly appear, the communication channel could be managed somewhere else in the settings.
Let’s try digging into the settings sections related to “Networking” or “Console” within the AMP Terraria instance settings. Look for any options that mention enabling remote command input or console passthroughs.
If nothing stands out, we might consider looking into AMP support or documentation for any Terraria-specific quirks. Let me know what you find!
[12:12:01] [Program Info/1] : Starting AMP version 2.5.1.6 (Callisto), built 16/08/2024 03:11
[12:12:01] [Program Info/1] : Stream: Mainline / Release - built by CUBECODERS/buildbot on CCL-DEV
[12:12:01] [Core Warning/1] : Current time zone is set to 台北標準時間 - It is recommended you switch to UTC+0 to avoid time-zone related issues
[12:12:01] [Program Info/1] : OS: Windows / x86_64
[12:12:01] [Program Info/1] : CPU: AMD Ryzen Threadripper 7960X 24-Cores (24C/48T)
[12:12:01] [Program Info/1] : RAM: 261642MB
[12:12:01] [Program Info/1] : AMP Instance ID: 0690140e-3fd0-47b6-a1e3-635f39d03bdf
[12:12:02] [Loader Info/1] : Loaded GenericModule version 1.0.0.0 by CubeCoders Limited
[12:12:02] [Core Info/1] : Metrics publishing is enabled at udp://localhost:12820.
[12:12:02] [Loader Info/1] : Loaded FileManagerPlugin by CubeCoders Limited
[12:12:02] [Loader Info/1] : Loaded EmailSenderPlugin by CubeCoders Limited
[12:12:02] [Loader Info/1] : Loaded WebRequestPlugin by CubeCoders Limited
[12:12:02] [Loader Info/1] : Loaded LocalFileBackupPlugin by CubeCoders Limited
[12:12:02] [Loader Info/1] : Loaded CommonCorePlugin by CubeCoders Limited
[12:12:02] [Loader Info/1] : Loaded AnalyticsPlugin by CubeCoders Limited
[12:12:02] [Loader Info/1] : GenericModule requests dependency steamcmdplugin…
[12:12:02] [Loader Info/1] : Loaded steamcmdplugin by CubeCoders Limited
[12:12:02] [Loader Info/1] : GenericModule requests dependency RCONPlugin…
[12:12:02] [RCON Info/1] : Starting Source RCON Passthru server at 192.168.1.151:7777
[12:12:02] [Loader Info/1] : Loaded RCONPlugin by CubeCoders Limited
[12:12:02] [Core Info/1] : Licence Present: AMP Professional Edition - Lifetime Licence
[12:12:02] [FileManager Notice/1] : Using keypair with fingerprint Td+Fqhbqz4xMrNmNq9UKOdXD34t57PDiaNg4ub05uoA=
[12:12:02] [FileManager Info/1] : SFTP Server started on 0.0.0.0:2319
[12:12:02] [Webserver Info/1] : Websockets are enabled.
[12:12:02] [Webserver Info/1] : Webserver started on http://0.0.0.0:29003
[12:12:02] [Webserver Info/15] : RouterTimer@10Hz with 2 jobs started
[12:12:02] [Core Info/11] : Checking for AMP updates…
[12:12:03] [Core Info/13] : AMP is up to date.
[12:12:37] [Core Activity/13] : Authentication attempt for user admin from 127.0.0.1
[12:12:40] [Core Activity/3] : Authentication success
[12:12:40] [Core Warning/3] : Slow method invocation: Login took 2603ms to complete.
[12:12:40] [Core Warning/3] : Slow response: Core.Login took 2609ms to complete.
[12:13:53] [API:admin Activity/23] : Starting the application.
[12:13:53] [Generic:admin Info/23] : Merging config file ./Terraria/serverfiles\terrariaserverconfig.txt (KVP format) using Unicode (UTF-8) encoding.
Settling liquids 1%
Settling liquids 2%
Settling liquids 3%
Settling liquids 4%
Settling liquids 5%
Settling liquids 6%
Settling liquids 7%
Settling liquids 8%
Settling liquids 9%
: Server started
[12:14:05] [API:admin Activity/23] : Sent to console: “help”
[12:14:16] [API:admin Activity/12] : Sent to console: 'help'
[12:14:21] [API:admin Activity/12] : Sent to console: help
[12:14:23] [API:admin Activity/12] : Sent to console: //help
According to the observation of AMP logs, it seems that is added in front of each command. For example, it should be help, but it becomeshelp` through AMPConsole. The additional symbols cause the command to be invalid. Can this problem be reported?
Aha! :man_detective: It looks like we’ve found a clue in that mysterious backtick (`) before the commands. That’s definitely not supposed to be there and could indeed be causing the commands to misbehave.
It’s worth reporting this to CubeCoders as a potential bug in the AMP interface you’re using. They might have a patch or workaround ready for such issues. Meanwhile, if you need to run commands urgently, you might consider using the Terraria server console directly as a temporary solution.
For the report, include the details about how the command input looks in the logs compared to the intended command. This will help them debug faster.
Feel free to reach out to CubeCoders support with these details and let them know what you’ve found. Hopefully, they’ll get things sorted quickly! If there’s anything else I can assist with while we wait on them, just let me know! :hammer_and_wrench:
@Mike
Could you please solve the problem caused by the symbol exception?
It looks like you’ve got someone specific to help out. If you need me later, feel free to bring me back in! Good luck! :four_leaf_clover:
