Strange Output at CLI
OS Name/Version: Fedora 41
Product Name/Version: AMP Release “Phobos”
v2.6.0.4, built 06/11/2024 22:37
Problem Description: When I login as the amp users and run commands the following output is displayed before. Not sure how to fix this but it may be JSON related?
amp@fedora:~$  ampinstmgr table
[Info] AMP Instance Manager v2.5.0.10 built 15/05/2024 17:51
[Error] Failed to read instance data: Newtonsoft.Json.JsonReaderException: Error reading JObject from JsonReader. Current JsonReader item is not an object: String. Path '[0].AMPVersion', line 26, position 27.
  at Newtonsoft.Json.Linq.JObject.Load (Newtonsoft.Json.JsonReader reader, Newtonsoft.Json.Linq.JsonLoadSettings settings) [0x00057] in <dd21e08747d94bcebed8b56112226337>:0
  at Newtonsoft.Json.Linq.JObject.Load (Newtonsoft.Json.JsonReader reader) [0x00000] in <dd21e08747d94bcebed8b56112226337>:0
  at InstanceManagerPlugin.LocalInstanceManager+VersionObjectConverter.ReadJson (Newtonsoft.Json.JsonReader reader, System.Type objectType, System.Object existingValue, Newtonsoft.Json.JsonSerializer serializer) [0x0000c] in <61c574b2d57e450997e4805c681984c1>:0
  at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.DeserializeConvertable (Newtonsoft.Json.JsonConverter converter, Newtonsoft.Json.JsonReader reader, System.Type objectType, System.Object existingValue) [0x00055] in <dd21e08747d94bcebed8b56112226337>:0
  at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.SetPropertyValue (Newtonsoft.Json.Serialization.JsonProperty property, Newtonsoft.Json.JsonConverter propertyConverter, Newtonsoft.Json.Serialization.JsonContainerContract containerContract, Newtonsoft.Json.Serialization.JsonProperty containerProperty, Newtonsoft.Json.JsonReader reader, System.Object target) [0x00052] in <dd21e08747d94bcebed8b56112226337>:0
  at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.PopulateObject (System.Object newObject, Newtonsoft.Json.JsonReader reader, Newtonsoft.Json.Serialization.JsonObjectContract contract, Newtonsoft.Json.Serialization.JsonProperty member, System.String id) [0x00280] in <dd21e08747d94bcebed8b56112226337>:0
  at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.CreateObject (Newtonsoft.Json.JsonReader reader, System.Type objectType, Newtonsoft.Json.Serialization.JsonContract contract, Newtonsoft.Json.Serialization.JsonProperty member, Newtonsoft.Json.Serialization.JsonContainerContract containerContract, Newtonsoft.Json.Serialization.JsonProperty containerMember, System.Object existingValue) [0x00161] in <dd21e08747d94bcebed8b56112226337>:0
  at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.CreateValueInternal (Newtonsoft.Json.JsonReader reader, System.Type objectType, Newtonsoft.Json.Serialization.JsonContract contract, Newtonsoft.Json.Serialization.JsonProperty member, Newtonsoft.Json.Serialization.JsonContainerContract containerContract, Newtonsoft.Json.Serialization.JsonProperty containerMember, System.Object existingValue) [0x0006d] in <dd21e08747d94bcebed8b56112226337>:0
  at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.PopulateList (System.Collections.IList list, Newtonsoft.Json.JsonReader reader, Newtonsoft.Json.Serialization.JsonArrayContract contract, Newtonsoft.Json.Serialization.JsonProperty containerProperty, System.String id) [0x00173] in <dd21e08747d94bcebed8b56112226337>:0
  at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.CreateList (Newtonsoft.Json.JsonReader reader, System.Type objectType, Newtonsoft.Json.Serialization.JsonContract contract, Newtonsoft.Json.Serialization.JsonProperty member, System.Object existingValue, System.String id) [0x000dc] in <dd21e08747d94bcebed8b56112226337>:0
  at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.CreateValueInternal (Newtonsoft.Json.JsonReader reader, System.Type objectType, Newtonsoft.Json.Serialization.JsonContract contract, Newtonsoft.Json.Serialization.JsonProperty member, Newtonsoft.Json.Serialization.JsonContainerContract containerContract, Newtonsoft.Json.Serialization.JsonProperty containerMember, System.Object existingValue) [0x0007f] in <dd21e08747d94bcebed8b56112226337>:0
  at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.Deserialize (Newtonsoft.Json.JsonReader reader, System.Type objectType, System.Boolean checkAdditionalContent) [0x000db] in <dd21e08747d94bcebed8b56112226337>:0
  at Newtonsoft.Json.JsonSerializer.DeserializeInternal (Newtonsoft.Json.JsonReader reader, System.Type objectType) [0x00054] in <dd21e08747d94bcebed8b56112226337>:0
  at Newtonsoft.Json.JsonSerializer.Deserialize (Newtonsoft.Json.JsonReader reader, System.Type objectType) [0x00000] in <dd21e08747d94bcebed8b56112226337>:0
  at Newtonsoft.Json.JsonConvert.DeserializeObject (System.String value, System.Type type, Newtonsoft.Json.JsonSerializerSettings settings) [0x0002d] in <dd21e08747d94bcebed8b56112226337>:0
  at Newtonsoft.Json.JsonConvert.DeserializeObject[T] (System.String value, Newtonsoft.Json.JsonSerializerSettings settings) [0x00000] in <dd21e08747d94bcebed8b56112226337>:0
  at InstanceManagerPlugin.LocalInstanceManager.GetLocalInstances (System.String AlternateDefsPath) [0x00096] in <61c574b2d57e450997e4805c681984c1>:0
  • Step 1: SSH into server
  • Step 2: Switch user to amp
  • Step 3: Run any command and the same output will be displayed
Actions taken to resolve so far: Tried looking through setup files, directories and other files to see where this could happen. Can’t seem to find the root issue. I also can’t seem to do anything via CLI either.
Edit: I do see this:
Even though I’ve upgrade to 2.6.0.4
Your ampinstmgr is out of date
Thank you. That fixed it!
