Steamcmd issue- Customization with Left 4 Dead 2 - wont let me loginto steamcmd
Application Left 4 Dead 2
as per the steps. I cannot log into steamcmd on l4d2 so canot add workshop items to the instance
  • typed in credentials
  • pressed login and it asked for login again
  • repeated previous steps again
  • credentials work on other instances
Hello good evening, I’m having the same problem, I’ve already reinstalled AMP and servers but without success.
I use AlmaLinux 9.5
i can see the server on the Steam group list and play on it but I cant add custom maps.
Template has been updated to prompt for steam login
This will allow download of workshop items via AMP but you will still need to move/symlink the .vpk files manually to left4dead2/addons
Hello. Tried to update again. No change still stuck on steam login popup
Did you actually update your instance first from the main webpage, so that the template config was updated?
I stopped the instance and then pressed update or do i need to delete and reinstall left 4 dead 2?
Section 4 here: How to update AMP to the latest version
it seems to be updating now. quite a few of the workshop items keep failing though and I also got a state 3 error. could you advise I put a few details on a discord link.
ERROR! Download item 122447941 failed (Failure).workshop_download_item 222860 122450201
Downloading item 122450201 …
ERROR! Download item 122450201 failed (Failure).workshop_download_item 222860 121275675
22:04:49
Downloading item 121275675 …
ERROR! Download item 121275675 failed (Failure).workshop_download_item 222860 381435128
22:04:50
Downloading item 381435128 …
22:04:51
WARNING: setlocale(‘en_US.UTF-8’) failed, using locale: ‘C’. International characters may not work.
22:04:52
UpdateUI: skip show logoSteam Console Client (c) Valve Corporation - version 1738027521
– type ‘quit’ to exit –
Loading Steam API…IPC function call IClientUtils::GetSteamRealm took too long: 48 msec
OK
Logging in using cached credentials.
22:04:53
Logging in user ‘LKUR1284’ [U:1:107867676] to Steam Public…OK
22:04:54
Waiting for client config…OK
Waiting for user info…OK
workshop_download_item 222860 324500451
Downloading item 324500451 …
ERROR! Download item 324500451 failed (Failure).workshop_download_item 222860 180925247
22:04:55
Downloading item 180925247 …
ERROR! Download item 180925247 failed (Failure).workshop_download_item 222860 144943915
