OS Name/Version: Windows 10 Pro N
Product Name/Version: AMP 2.4.4.0
Problem Description: Steam login does not work and states:
password: FAILED (Invalid Password)
Step 1 - Try to update any steam application
Step 2 - Enter password correctly
Step 3 - Get told that the password is incorrect even though it works on non-AMP steamcmd apps.
Actions taken to resolve so far: Re-enter password.
Mike
November 28, 2023, 9:41am
2
You’re on an outdated version of AMP. Please update first.
TABLE
November 29, 2023, 12:44am
4
Very very out of date in that case, you need to first update the instance manager to then be able to update the instances. You’re about 6 months out of date, on the old release system.
[4]
1. Overview
AMP has several components that are updated independently:
Component
Description
AMP instance manager
This is the command line tool used to configure instances
AMP instances
These include ADS (the main instance, which manages other instances) and the instances that run applications like game servers
Generic Module instance configurations
Instances created using the Generic Module have a “template” configuration that tells the Generic Module how to configure the ins…
