Field
Value
Operating System
Windows - Windows 10 Home on x86_64
Product
AMP ‘Callisto’ v2.5.0.10 (Mainline)
Virtualization
None
Application
Valheim
Module
GenericModule
Running in Container
No
Current State
Stopped
i do this steps and the nothing happens.
Here is the logg file:
[17:58:29] [InstanceManager Info] : Waiting for AMP instance to start…
[17:58:29] [InstanceManager Notice] : AMP instance ValheimPLUS01 is now running.
[17:59:40] [ADS:admin Activity] : Managed remote instance ValheimPLUS01 at http://127.0.0.1:8081/
[17:59:40] [GSMyAdmin:admin Activity] : Authentication token for admin requested by ManageInstance on behalf of admin
[17:59:43] [GSMyAdmin Warning] : Slow method invocation: Servers took 2729ms to complete.
[17:59:43] [GSMyAdmin Warning] : Slow response: ADSModule.Servers took 2730ms to complete.
make instance
change name on the server
press start
I’m having this EXACT problem as well.
Have you hit “Update” inside the instance so it downloads the server?
Is this an existing server or a newly installed server?
Yes, No different. I did try put Valheimplus in but then it only do the updatet and still cant start.
The update to AMP always just freeze, so everytime amp has an updatet i need to reinstall everything so yes this is a «new» installasion.
The “update freeze” you mention I always had that issue IF you try to update it through AMP’s UI (on window at least). The safest/best way to update AMP, and all instances, is if you use the terminal on the remote machine and use the command “ampinstmgr upgradeall” (without quotes).
Also, this thread should be pinned for anybody that comes here asking/troubleshooting updating AMP:
[4]
1. Overview
AMP has several components that are updated independently:
Component
Description
AMP instance manager
This is the command line tool used to configure instances
AMP instances
These include ADS (the main instance, which manages other instances) and the instances that run applications like game servers
Generic Module instance configurations
Instances created using the Generic Module have a “template” configuration that tells the Generic Module how to configure the ins…
