Field
Value
Operating System
Product
AMP ‘Callisto’ v2.5.0.8 (Mainline)
Virtualization
Docker
Application
Valheim
Module
GenericModule
Running in Container
Yes
Current State
Failed
Creating of Valheim instance fails during Update Step 2 - Update Saves Directory - Linux with error:
This task could not be completed: Running Update Tasks - - State: 3
/bin/bash failed with exit code 1
Create a new Valheim instance
Instance starts update, either automatic or manual
The update fails
Hi
exact same issue for me
fresh new server with debian 12
everything up to date
same issue vor enshrouded
same issue here with valheim and ark survival ascended
ubuntu server 24.04
I can not help, but i have the same problem after upgrading, in addition to that my gui won’t start.
Having the same issue. I can still start the server manually if I enter the instance, But It will error out in the ADS manager.
Re-update AMP to the latest patch.
still erroring after successfully validating install
Can you show me the contents of the support tab for that instance?
After re updating still having issues
Your tools are outdated. Update ampinstmgr please.
I have multiple times through the GUI, and terminal, here is the support page for the manager
ampinstmgr -p
[Info] AMP Instance Manager v2.5.0.8 built 01/05/2024 19:51
[Info] Stopping instance ADS01...
[Info] Requesting soft-stop...
[Info] Waiting for instance to stop...
[Info] Instance ADS01 has stopped.
[Info] Stopping instance Valheim01...
AMP_Valheim01
[Info] Instance Valheim01 has stopped.
[Info] Upgrading instance ADS01
[Info] Upgrade successful
[Info] Upgrading instance Valheim01
[Info] Using default tag: latest
[Info] latest: Pulling from cubecoders/ampbase
[Info] Digest: sha256:0bdb5f2fc08648bf9d664c675460692517ffac159212fd9132ef28baf1f84e62
[Info] Status: Image is up to date for cubecoders/ampbase:latest
[Info] docker.io/cubecoders/ampbase:latest
[Notice] AMP instance ADS01 is now running.
[Info] 2bb8dc25f324d7c24d82ac270a7ffb506d0799e829574953614546e8cecb97b4
[Info] 03d26309f55aed316cee5ced3472d319117370e5ba176df794478ae372c9fb35
Also gone through GUI to update everything.
Issue still persists.
What I see is that (at least with ARK: SA) it seems to get stuck at downloading Proton GE, both when initially setting up the server instance, and just when trying to update a server instance.
This isn’t an issue with ARK: SE or with Minecraft. These are the only other 2 servers I have set up at the moment.
Mireiawen:
same on windows server core 2022 after AMP update
For those with Valheim instances, go back to the main instances screen and update the instance from there to refresh the config
A fix will be raised for ASA and Enshrouded soon
Fix now in, same instructions as above for Valheim
Now giving exit code 2
exit: -c: line 2: syntax error: unexpected end of file
on ark survival ascended after config refresh or fresh instance
