Confirmed. Stops on the same step as well, downloading Proton GE.
Log file for my latest attempt to update ASA… for this attempt, I manually updated AMP, and then the ASA instance, and still got the exit code 2 when it tried to download Proton.
[16:21:51] [Core Info] : Starting AMP version 2.5.0.8 (Callisto), built 02/05/2024 04:53
[16:21:51] [Core Info] : Stream: Mainline / Release - built by CUBECODERS/buildbot on CCL-DEV
[16:21:51] [Core Info] : Running in a Docker environment.
[16:21:51] [Core Info] : OS: Linux / x86_64
[16:21:51] [Core Info] : CPU: Intel(R) Xeon(R) CPU X5650 @ 2.67GHz (12C/24T)
[16:21:51] [Core Info] : RAM: 120831MB
[16:21:51] [Core Info] : AMP Instance ID: 700b9889-a232-4d6c-9f8c-f020c4d931b0
[16:21:52] [Loader Info] : Loaded GenericModule version 1.0.0.0 by CubeCoders Limited
[16:21:52] [Core Info] : Metrics publishing is enabled at udp://localhost:12820.
[16:21:52] [Loader Info] : Loaded FileManagerPlugin by CubeCoders Limited
[16:21:52] [Loader Info] : Loaded EmailSenderPlugin by CubeCoders Limited
[16:21:52] [Loader Info] : Loaded WebRequestPlugin by CubeCoders Limited
[16:21:52] [Loader Info] : Loaded LocalFileBackupPlugin by CubeCoders Limited
[16:21:52] [Loader Info] : Loaded CommonCorePlugin by CubeCoders Limited
[16:21:52] [Loader Info] : GenericModule requests dependency steamcmdplugin…
[16:21:52] [Loader Info] : Loaded steamcmdplugin by CubeCoders Limited
[16:21:52] [Loader Info] : GenericModule requests dependency RCONPlugin…
[16:21:52] [Loader Info] : Loaded RCONPlugin by CubeCoders Limited
[16:21:52] [Core Info] : Licence Present: AMP Professional Edition
[16:21:52] [FileManager Notice] : Using keypair with fingerprint GQ5bgLsSv2Kqc/7jA9KvMPwWxkOoUBsb4Tm5gUS4LtE=
[16:21:52] [FileManager Info] : SFTP Server started on 0.0.0.0:2224
[16:21:52] [Webserver Info] : Websockets are enabled.
[16:21:53] [Logger Info] : RouterTimer@10Hz with 2 jobs started
[16:21:53] [Webserver Info] : Webserver started on http://127.0.0.1:8081
[16:21:53] [Core Info] : Checking for AMP updates…
[16:21:53] [Core Info] : Startup mode is UpdateApplication.
tid(80) burning pthread_key_t == 0 so we never use it
minidumps folder is set to /tmp/dumps
[16:21:53] [Core Info] : AMP is up to date.
UpdateUI: skip show logoSteam Console Client (c) Valve Corporation - version 1709846822
– type ‘quit’ to exit –
Loading Steam API…OK
force_install_dir “2430930”
Waiting for client config…OK
Waiting for user info…OK
“@sSteamCmdForcePlatformType” = “windows”
app_update 2430930 validate
Update state (0x5) verifying install, progress: 0.02 (2097152 / 11652582489)
[16:21:56] [Core Activity] : Authentication attempt for user tbgadmin from 127.0.0.1
[16:21:56] [Core Activity] : Authentication success
Update state (0x5) verifying install, progress: 3.89 (453509099 / 11652582489)
Update state (0x5) verifying install, progress: 8.17 (951803915 / 11652582489)
Update state (0x5) verifying install, progress: 12.47 (1452706255 / 11652582489)
Update state (0x5) verifying install, progress: 16.76 (1952772031 / 11652582489)
Update state (0x5) verifying install, progress: 21.07 (2454975035 / 11652582489)
Update state (0x5) verifying install, progress: 25.33 (2951373995 / 11652582489)
Update state (0x5) verifying install, progress: 29.64 (3453858199 / 11652582489)
Update state (0x5) verifying install, progress: 33.96 (3957394327 / 11652582489)
Update state (0x5) verifying install, progress: 38.29 (4461759383 / 11652582489)
Update state (0x5) verifying install, progress: 42.55 (4958080315 / 11652582489)
Update state (0x5) verifying install, progress: 46.86 (5460105055 / 11652582489)
Update state (0x5) verifying install, progress: 51.18 (5963744159 / 11652582489)
Update state (0x5) verifying install, progress: 55.53 (6470453231 / 11652582489)
Update state (0x5) verifying install, progress: 59.85 (6974344012 / 11652582489)
Update state (0x5) verifying install, progress: 64.45 (7510115148 / 11652582489)
Update state (0x5) verifying install, progress: 69.45 (8092756844 / 11652582489)
Update state (0x5) verifying install, progress: 74.44 (8674373052 / 11652582489)
Update state (0x5) verifying install, progress: 79.40 (9252363084 / 11652582489)
Update state (0x5) verifying install, progress: 83.68 (9750574558 / 11652582489)
Update state (0x5) verifying install, progress: 87.97 (10250763353 / 11652582489)
Update state (0x5) verifying install, progress: 92.63 (10793925721 / 11652582489)
Update state (0x5) verifying install, progress: 97.23 (11329748057 / 11652582489)
Success! App ‘2430930’ fully installed.
quit
[16:22:42] [steamcmdplugin Info] : SteamCMD Update successful
[16:22:42] [Generic Info] : Skipping download - target already exists (/AMP/ark-sa/2430930/ShooterGame/Saved/Config/WindowsServer/Game.ini)
[16:22:42] [Generic Info] : Skipping download - target already exists (/AMP/ark-sa/2430930/ShooterGame/Saved/Config/WindowsServer/GameUserSettings.ini)
[16:22:42] [Generic Info] : Skipping download - target already exists (/AMP/ark-sa/2430930/.backupExclude)
[16:22:42] [Generic Info] : Skipping download - target already exists (/AMP/ark-sa/2430930/ShooterGame/.backupExclude)
exit: -c: line 2: syntax error: unexpected end of file
Hope this is helpful.
Update your instance from the main instances screen to refresh the config
This is after updating instance that it has changed the error and is now only affecting ark ascended. Valheim and Enshrouded are running as expected after updating.
Yeah, my bad, I had a typo in ASA. I shouldn’t do this stuff on mobile lmao
Fix should be in a few minutes
Fix now in. You might have to manually refresh under Config/Instance Deployment before updating the instance (AMP has a silly 5 minute timeout on instance refreshes)
Bingo! Thanks for the fix Greelan. Confirmed that worked on my ASA instance. Appreciate it!
