Startup Issue with StarRupture - StarRupture doesnt start
Application StarRupture
Installed New StarRupture Instance. Startup failed. Try to Update Instance and Missing the usual Update Percent counter in the logs. Startup failed. Seems Game ist Not correctly installed via Steam.
  • Create a new StarRupture Instance
  • Waiting for creation ist done
  • Watching logs. See Error Message and a Not starting StarRupture
  • Hit the “Update Instance” Button. Seeing, that Something went wrong while downloading App via steam
  • Still No starting
My crystal ball is not working today
Hi,
tried to install it several times new. Restarting the whole Server, Hitting the “update” Button sometimes. But it doesnt work.
First Error Message when creating the new Instance.
SteamCMD
[----] Installing update...
[----] Cleaning up...
[----] Update complete, launching...
[  0%] Checking for available updates...
[  0%] Downloading update...
[----] Download complete.
[----] Extracting package...
[----] Update complete, launching Steamcmd...
UpdateUI: skip show logo
Steam Console Client (c) Valve Corporation - version 1766451518
-- type 'quit' to exit --
Loading Steam API...OK
force_install_dir "3809400"
Waiting for user info...OK
"@sSteamCmdForcePlatformType" = "windows"
app_update 3809400 validate
ERROR! Failed to install app '3809400' (Missing configuration)
quit
Unloading Steam API...OK
I had the same issue.
I just rebooted the machine and clicked on update again and watched the console.
I also checked to ensure the license was not the issue.
Click update again, it’s a steamcmd bug
It seems, it doesn’t help.
Tried:
  • Hit “Upgrade this instance” just below the “Currently running version 2.6.4.2 - 20251210.2” in “Main Menu → Support and Updates”. Machine is restarting. Result is the same Error Message as before.
  • Hit “Upgrade this instance” just below the “Currently running version 2.6.4.2 - 20251210.2” in the Instance “Support and Updates” Menu. I automaticly exit the Instance in the Main Menu. Took a while for the instance to switch from “Idle” to “Update” and then “Starting”. Result is the same Error Message as before.
  • Just restarted three times AMP in “Main Menu → Support and Updates” an the bottom of the Menu. Every time i get the “Website is not available” from my browser. First time, the can’t be a restart, because one other (running Enshrouded) instance was at “17 Minutes running” what shouldn’t be right after a restart. Second time, the Enshrouded instance was restartet, but the log in the StarRupture instance had no update in log. Just hanging on “Error”, the log was ~5 Minutes old. Third time the exact same behaviour as the second restart.
  • Stopping all instances and reboot the proxmox VM completely new. The Enshrouded instance came back just normal. The StarRupture instance hat some fresh (but same) Error Messages (“Error! App ‘3809400’ state is 0x202 after update job.”)
  • In the Console for the StarRupture App hitting the orange “Update instance” Button on top of the screen also three times. All ending with the same log: Error on update, App couldn’t start.
  • Just hitting the green “Start” Button right next to this orange Update-Button in the instance-console. Seeing in the console: “wine: failed to open “StarRupture/Binaries/Win64/StarRuptureServerEOS-Win64-Shipping.exe”: c0000135” every i hit that button twice.
  • Stopped all instances in AMP. Stopped all VMs on the Proxmox Machine. Shutting down the whole Proxmox Server for ~ 30 seconds. Just the same result: Enshrouded instance starting without problems, StarRupture with the same error message.
  • Deleting the not-running-StarRupture instance and creating a total new one. Same issue:
SteamCMD08:19:04
ILocalize::AddFile() failed to load file "public/steambootstrapper_english.txt".
[  0%] Checking for available update...
08:19:05
[----] Downloading update (0 of 36,113 KB)...
[  0%] Downloading update (0 of 36,113 KB)...
[  0%] Downloading update (3,329 of 36,113 KB)...
08:19:06
[  9%] Downloading update (7,398 of 36,113 KB)...
[ 20%] Downloading update (10,979 of 36,113 KB)...
[ 30%] Downloading update (13,674 of 36,113 KB)...
08:19:07
[ 37%] Downloading update (16,389 of 36,113 KB)...
[ 45%] Downloading update (19,372 of 36,113 KB)...
[ 53%] Downloading update (22,088 of 36,113 KB)...
[ 61%] Downloading update (24,779 of 36,113 KB)...
08:19:08
[ 68%] Downloading update (26,373 of 36,113 KB)...
[ 73%] Downloading update (27,927 of 36,113 KB)...
[ 77%] Downloading update (29,352 of 36,113 KB)...
[ 81%] Downloading update (30,913 of 36,113 KB)...
08:19:09
[ 85%] Downloading update (32,341 of 36,113 KB)...
[ 89%] Downloading update (33,767 of 36,113 KB)...
[ 93%] Downloading update (35,326 of 36,113 KB)...
[ 97%] Downloading update (36,113 of 36,113 KB)...
[100%] Download Complete.
[----] Applying update...
08:19:11
08:19:12
08:19:14
08:19:15
08:19:16
08:19:19
08:19:20
08:19:23
08:19:24
quit
  • Hitting the orange “upgrade instance” button on top of the console:
08:20:17
08:20:18
08:20:19
08:20:22
08:20:24
08:20:26
08:20:28
08:20:30
08:20:32
 Update state (0x0) unknown, progress: 0.00 (0 / 0)
Error! App '3809400' state is 0x202 after update job.
quit
08:20:33
bash08:20:35
wine: created the configuration directory '/AMP/star-rupture/.wine'
  • Creating just another instance (Astroneer). Same issue: “ERROR! Failed to install app ‘728470’ (Missing configuration)”
  • Creating just another instance (Enshrouded). Same issue: “ERROR! Failed to install app ‘2278520’ (Missing configuration)”
  • Creating just another instance (Valheim). Same issue: (“ERROR! Failed to install app ‘896660’ (Missing configuration)”
It seems, that @Greelan is absolutly right about this steamcmd bug. But it isn’t fixed for me.
What is interesting: on all of my “old” instances (Valheim, Enshrouded, Satisfactory), the update - also with a download from steam - just worked fine.
Just another thing: Followed the How to update AMP to the latest version to update the ubuntu system itself. nothing changed, still the same error message from steamcmd.
The last error you posted means you don’t have enough disk space to install the server
That’s embarrassing :see_no_evil_monkey:
It was just not enough space. Sorry for that. I changed the disk size and now everything is working well.
Thank you!!
