| Product | AMP ‘Decadeus’ v2.4.7.0 (Mainline) |
| Virtualization | Docker |
| Application | Palworld |
| Module | GenericModule |
| Current State | PreStart |
error on start , and instance does nothing. also no start stop is displayed anymore.
AMP was unable to start the application. Possible causes may include insufficient permissions to load the executable, or the file not being correctly flagged as being an executable file. Check AMPs logs for more information.
[12:10:52] [Generic:admin Info] : Merging config file ./palworld/2394010/Pal/Saved/Config/WindowsServer/PalWorldSettings.ini (Template) using Unicode (UTF-8) encoding.
[12:10:52] [Core:admin Error] : ArgumentNullException
[12:10:52] [Core:admin Error] : [0] (ArgumentNullException) : Value cannot be null.
Parameter name: input
[12:10:52] [Core:admin Error] : at Text.RegularExpressions.Regex.Replace (String input, Text.RegularExpressions.MatchEvaluator evaluator)
at GenericModule.GenericModuleConfig+ApplicationConfig.SubstituteTemplates (String input, Collections.Generic.Dictionary`2[TKey,TValue] variables)
at GenericModule.GenericModuleConfig+ApplicationConfig.GetValue (String input)
at GenericModule.ModuleMain.b__36_0 (Text.RegularExpressions.Match m)
at Text.RegularExpressions.Regex.Replace (Text.RegularExpressions.MatchEvaluator evaluator, Text.RegularExpressions.Regex regex, String input, Int32 count, Int32 startat)
at Text.RegularExpressions.Regex.Replace (String input, Text.RegularExpressions.MatchEvaluator evaluator, Int32 count, Int32 startat)
at GenericModule.ModuleMain.MergeTemplate (String finalPath, GenericModule.MetaConfigFile fileInfo)
at GenericModule.ModuleMain.MergeConfigFile (String finalPath, GenericModule.MetaConfigFile fileInfo)
at GenericModule.ModuleMain.WriteMetaconfigs ()
at GenericModule.ModuleMain.SaveChanges (String key, String value)
at GenericModule.GenericApp.DoAppStartup (Boolean IsUpdating)
at GenericModule.GenericApp.Start ()
start palworld server by hand , all works fine.
best regards
- debian 12 fresh install
- amp fresh install
- palworld server reinstall
- testing palworld server start by hand works
partial fixed for me , and thanks for the tip @ zaraki1311
i changed after instanz setup the metaconfig.json , type to ini
now the server can start and work,but displays “Application State: Starting” infinite
source:
