Startup Issue with OpenRCT2 - Issue with starting new OpenRCT2 instance
Application OpenRCT2
All I did was add a new instance and it’s giving me error #3 and supposedly a 404. This is for OpenRCT2.
  • Created a new instance
  • Verified the error codes
  • Researched any solutions, found none
Post AMP’s logs from when you try to install
Also, what version of OpenRCT2 do you have selected under the Updates menu?
If you are trying to install 0.4.17 or 0.4.16, then specify v0.4.17 or v0.4.16 rather than just the number - the damns devs have now put v into the file name
Actually, given how they have changed it, I will need to rewrite how AMP gets the downloads
This has now been done. To get the change, follow section 4 here: How to update AMP to the latest version
Now you can specify the version to download, or just leave the setting blank and AMP will download the latest when the server is updated
