Startup Issue with Minecraft - Stoneblock 4
I installed stoneblock server via ftb server installer and it crashes
  • put install.sh in /Minecraft folder
  • run it via cmd, then run ./ftb-server-installer_130_100148
  • it installed successfuly
  • cant run server, crashes
EDIT:
Found FTB server type and automatic stoneblock 4, but it installs MC version 1.21.10. Client modpack from curseforge is on 1.21.1. Changing server type to neoforge gets server to crash on startup with fml.toml writing error
See this guide here, you need to select the correct NeoForge version after installing the pack.
https://discourse.cubecoders.com/t/setting-up-a-modded-java-minecraft-server/26535#p-50642-h-2-feed-the-beast-21
