| Operating System | Windows - Windows 11 Pro on x86_64 |
| Product | AMP ‘Callisto’ v2.5.1.0 (Mainline) |
| Virtualization | None |
| Application | Minecraft |
| Module | MinecraftModule |
| Running in Container | No |
| Current State | PreparingForSleep |
Hello there!
I have noticed this issue on my Minecraft 1.21 Forge server.
Issue:
Roughly every other time the ‘Sleep’ function is initiated, it hangs in a ‘preparing to sleep’ mode which effectively kills the server and forces me to shut down the entire ‘instance’ of the minecraft server in order to bring it back up.
When the server comes back up, often times because of my current settings, it will auto-sleep. When this occurs during startup (if it occurs) it has been seen to function properly. But for some reason when it happens again, or soon after, the next sleep mode pushed will likely bring the server down once again, requiring more manual intervention. What is expected is we can simply ping the ip under port it is listening for (25565) or see someone connect before it begins starting up the server again. But for some reason, this only works every other time. The issue is with the server Starting up from Sleep Mode not being initiated fully, again this effectively ends the server and requires someone to end the whole minecraft ‘instance’, instead of what is expected. Comes back up without issue though!
What has been done?:
I checked the locale settings and the Unicode UTF-8 setting box is turned off. I clicked off my firewalls and antivirus just to test and see if that made any difference to no avail. Updated Forge to its latest version but that changed nothing. Looking at the logs, it would appear there is a listener being killed which is not coming up. If I can, I will add the server console output to this post so you can see what I do.
Ask:
Does anyone know what I could possibly do to make this process run without needing manual intervening?
- Wait for the auto sleep function or manually sleep using the ‘Sleep’ Button
- Expected Result: Sleep mode activates properly, and server falls into a low resource listening state on both 25565 ports
- What happenes: Sleep function works as expected almost exactly every other time. This can be manually reproduced or will happen with the auto-sleep function all the same
EDIT**
Here is the console output when the issue occurs:
08:44:00
Stopping the server
Stopping server
Saving players
Saving worlds
Saving chunks for level 'ServerLevel[KingdomOfBool]'/minecraft:overworld
Saving chunks for level 'ServerLevel[KingdomOfBool]'/minecraft:the_nether
Saving chunks for level 'ServerLevel[KingdomOfBool]'/minecraft:the_end
ThreadedAnvilChunkStorage (KingdomOfBool): All chunks are saved
ThreadedAnvilChunkStorage (DIM-1): All chunks are saved
ThreadedAnvilChunkStorage (DIM1): All chunks are saved
ThreadedAnvilChunkStorage: All dimensions are saved
Thread Query Listener stopped
Also, as an UPDATE:
As noted above, the state hangs in ‘Preparing to Sleep’, never activating the listener, this is why I assumed it was security related but even with all that off the automation is failing.
