3rd Party AMP plugins and bots list
Note: These plugins are not reviewed or endorsed by CubeCoders. We cannot make any claim as to their quality, safety or security. Users should use them solely at their own risk. CubeCoders are not responsible for any damage caused to your system(s) as a result of using these packages.
A developer’s key is required which you can obtain from CubeCoders
Name Description Link
AMP Discord Bot A full featured Discord bot plugin for AMP that can be used to display the server status along with the ability to manage the server directly from Discord (start / stop / restart / kill / update). Instructions to install as a plugin available at the link. GitHub - winglessraven/AMP-Discord-Bot: Discord Bot plugin for AMP · GitHub
Minecraft Router A plugin that sends Minecraft players to the right server based on the address they type. It works like DiscoPanel’s proxy GitHub - jleybourne/AMP-Minecraft-Router · GitHub
OPNsense Port Sync AMP plugin that keeps your OPNsense port forwards in sync with your game server instances. Add an instance, change a port or remove one, and the matching WAN port forward on your OPNsense firewall is created, updated or removed to match. GitHub - Mecistios/AMP-OPNsense: Keeps OPNsense port-forwards in sync with AMP game server instance ports · GitHub
UniFi Port Sync An AMP plugin that keeps UniFi port-forwards in step with your game-server instances. When you add, re-port or remove an instance, the matching WAN port-forward on your UniFi gateway is created, updated or cleaned up for you. GitHub - Mecistios/AMP-Unifi · GitHub
