Startup Issue with Minecraft - Minecraft Modpack GregTech New Horizons not starting
I had the serer previously manually running and wanted to test AMP but I think I dont understand it completely. I want to make the server uploaded all files but he wont start I dont know why. I reinstalled the server, changed the java versions, tried custom method but nothing sems to work.
  • Reinstalled the server
  • Changed Java Version
  • reuploaded all files
GTNH has some extra settings you need to configure
https://discourse.cubecoders.com/t/setting-up-a-modded-java-minecraft-server/26535#p-50642-h-323-gtnh-40
Thank you but. I already did all of this : Server and Startup -> Server TypeForge
  1. Server and Startup -> Forge Version → The Forge version the pack currently uses
  2. Server and Startup -> Server Jarlwjg13ify-forgePatches.jar
  3. Java and Memory -> Java versionJava 17
  4. Java and Memory -> Additional java options-Dfml.readTimeout=180 @java9args.txt
it starts up but crashes after the server says Done and restarting it
If it’s a fresh world try deleting the world folder and see if that works.
Could be a world was accidentally generated using a newer MC version and GTNH is crashing while trying to read it.
