hyper
7 November 2025 17:38
1
Field
Value
Operating System
Linux - Ubuntu 24.04.3 on x86_64
Product
AMP ‘Phobos’ v2.6.3.2 (Mainline)
Virtualization
None
Application
Minecraft
Module
MinecraftModule
Running in Container
No
Current State
Starting
I have copied all the mods 10 and simple voice mod onto the server and have attempted to start the server, upon startup there seems to be a halt on the processes, I’m unaware of the issue at hand. Is there an issue with the modpack?
created the server
installed mods onto the server
attempted to run server
Try taking a run through this guide here:
Preamble
Minecraft is a bit notorious for being difficult to mod, given there’s oodles of different modloaders and versions to work with, there’s edge cases galore.
If you’re new to the Minecraft modding scene and you’d like to know more about each modding platform and how they differ, check out this post here .
0. Create a new Minecraft Java Instance in AMP
Easy as that, press the Create Instance button, then select Minecraft Java Edition from the drop-down. Feel free to use an existing instan…
system
Closed
7 December 2025 18:47
3
