| Field |
Value |
| Operating System |
| Product |
AMP ‘Phobos’ v2.6.4.2 (Mainline) |
| Virtualization |
Docker |
| Application |
Minecraft |
| Module |
MinecraftModule |
| Running in Container |
Yes |
| Current State |
Failed |
The server fails to start after following a couple guides online, I have ensured the correct forge and java version, added the additional java options and set the correct server jar.
- Create new instance
- Upload GTNH Server files
- Follow steps provided by ThePotatoKing in his article
- Server fail to start
Can i please have the console log pretty please with a cherry on top
I apologies i forgot to add the console log!
OpenJDK 64-Bit Server VM warning: Archived non-system classes are disabled because the java.system.class.loader property is specified (value = “com.gtnewhorizons.retrofuturabootstrap.RfbSystemClassLoader”). To use archived non-system classes, this property must not be set
Error occurred during initialization of VM
java.lang.Error: com.gtnewhorizons.retrofuturabootstrap.RfbSystemClassLoader
at java.lang.ClassLoader.initSystemClassLoader(java.base@17.0.17/ClassLoader.java:2000)
at java.lang.System.initPhase3(java.base@17.0.17/System.java:2263)
Caused by: java.lang.ClassNotFoundException: com.gtnewhorizons.retrofuturabootstrap.RfbSystemClassLoader
at jdk.internal.loader.BuiltinClassLoader.loadClass(java.base@17.0.17/BuiltinClassLoader.java:641)
at jdk.internal.loader.ClassLoaders$AppClassLoader.loadClass(java.base@17.0.17/ClassLoaders.java:188)
at java.lang.ClassLoader.loadClass(java.base@17.0.17/ClassLoader.java:525)
at java.lang.Class.forName0(java.base@17.0.17/Native Method)
at java.lang.Class.forName(java.base@17.0.17/Class.java:469)
at java.lang.ClassLoader.initSystemClassLoader(java.base@17.0.17/ClassLoader.java:1986)
Thanks for any help lads
