Startup Issue with Minecraft - Failed to Start minecraft server
Product AMP ‘Phobos’ v2.6.1.6 (Mainline)
Current State Starting
Forge: net.minecraftforge:47.4.0[21:58:45] [main/ERROR] [minecraft/Main]: Failed to start the minecraft server
net.minecraftforge.fml.LoadingFailedException: Loading errors encountered: [
  • Restarted the Server
  • Updated the server as it said Update
  • Logged A ticket to support staff
You need to share the full error, as the loading exception shares the cause/reason below that line.
Crash Report UUID: 9a618f5c-f7e5-463d-8fac-9044742408bb
FML: 47.4
Forge: net.minecraftforge:47.4.0[22:05:20] [main/ERROR] [minecraft/Main]: Failed to start the minecraft server
Oculus (oculus) has failed to load correctly
?7java.lang.RuntimeException: Attempted to load class net/minecraft/client/gui/screens/Screen for invalid dist DEDICATED_SERVER
at net.minecraftforge.fml.ModLoader.waitForTransition(ModLoader.java:246) ~[fmlcore-1.20.1-47.4.0.jar%231177!/:?] {}
at net.minecraftforge.fml.ModLoader.lambda$dispatchAndHandleError$20(ModLoader.java:210) ~[fmlcore-1.20.1-47.4.0.jar%231177!/:?] {}
at java.util.Optional.ifPresent(Optional.java:178) ~[?:?] {re:mixin}
at net.minecraftforge.fml.ModLoader.dispatchAndHandleError(ModLoader.java:210) ~[fmlcore-1.20.1-47.4.0.jar%231177!/:?] {}
at net.minecraftforge.fml.ModLoader.lambda$gatherAndInitializeMods$13(ModLoader.java:183) ~[fmlcore-1.20.1-47.4.0.jar%231177!/:?] {}
at java.lang.Iterable.forEach(Iterable.java:75) ~[?:?] {re:mixin}
at net.minecraftforge.fml.ModLoader.gatherAndInitializeMods(ModLoader.java:183) ~[fmlcore-1.20.1-47.4.0.jar%231177!/:?] {}
at net.minecraftforge.server.loading.ServerModLoader.load(ServerModLoader.java:30) ~[forge-1.20.1-47.4.0-universal.jar%231181!/:?] {re:classloading}
at net.minecraft.server.Main.main(Main.java:125) ~[server-1.20.1-20230612.114412-srg.jar%231176!/:?] {re:mixin,re:classloading,pl:mixin:A}
at jdk.internal.reflect.DirectMethodHandleAccessor.invoke(DirectMethodHandleAccessor.java:103) ~[?:?] {}
at java.lang.reflect.Method.invoke(Method.java:580) ~[?:?] {re:mixin}
at net.minecraftforge.fml.loading.targets.CommonLaunchHandler.runTarget(CommonLaunchHandler.java:111) ~[fmlloader-1.20.1-47.4.0.jar%2369!/:?] {}
at net.minecraftforge.fml.loading.targets.CommonLaunchHandler.serverService(CommonLaunchHandler.java:103) ~[fmlloader-1.20.1-47.4.0.jar%2369!/:?] {}
at net.minecraftforge.fml.loading.targets.CommonServerLaunchHandler.lambda$makeService$0(CommonServerLaunchHandler.java:27) ~[fmlloader-1.20.1-47.4.0.jar%2369!/:?] {}
at cpw.mods.modlauncher.LaunchServiceHandlerDecorator.launch(LaunchServiceHandlerDecorator.java:30) ~[modlauncher-10.0.9.jar%2355!/:?] {}
at cpw.mods.modlauncher.LaunchServiceHandler.launch(LaunchServiceHandler.java:53) ~[modlauncher-10.0.9.jar%2355!/:?] {}
at cpw.mods.modlauncher.LaunchServiceHandler.launch(LaunchServiceHandler.java:71) ~[modlauncher-10.0.9.jar%2355!/:?] {}
at cpw.mods.modlauncher.Launcher.run(Launcher.java:108) ~[modlauncher-10.0.9.jar%2355!/:?] {}
at cpw.mods.modlauncher.Launcher.main(Launcher.java:78) ~[modlauncher-10.0.9.jar%2355!/:?] {}
at cpw.mods.modlauncher.BootstrapLaunchConsumer.accept(BootstrapLaunchConsumer.java:26) ~[modlauncher-10.0.9.jar%2355!/:?] {}
at cpw.mods.modlauncher.BootstrapLaunchConsumer.accept(BootstrapLaunchConsumer.java:23) ~[modlauncher-10.0.9.jar%2355!/:?] {}
at cpw.mods.bootstraplauncher.BootstrapLauncher.main(BootstrapLauncher.java:141) ~[bootstraplauncher-1.1.2.jar:?] {}
That’s a client-only mod.
If this is not a custom modpack, see this guide here on importing an existing modpack’s server files from CurseForge.
https://discourse.cubecoders.com/t/setting-up-a-modded-java-minecraft-server/26535
If this is a custom pack, you’ll need to read the console to see what client-only mods crash the server and remove them.
Ah okay, Its ATM9 but I added mods in, grabbed the initial pack from CF and added some stuff into it.
