Field
Value
Operating System
Linux - Debian GNU/Linux 13 on x86_64
Product
AMP ‘Proteus’ v2.8.0.4 (Mainline)
Virtualization
Docker
Application
Minecraft
Module
MinecraftModule
Running in Container
Yes
Current State
Failed
I am trying to put Sunlit society cobblemon on and everytime i have tried it says something is missing or we load in to a world covered in water and signs.
made server
changed to forge and the correct version for Sunlit:society to run
updated and started
Bodrew
August 23, 2026, 6:00pm
2
How did you install the modpack? Using the Store? Did you follow the Modded Minecraft Guide?
Preamble
Minecraft is a bit notorious for being difficult to mod, given there’s oodles of different modloaders and versions to work with, there’s edge cases galore.
If you’re new to the Minecraft modding scene and you’d like to know more about each modding platform and how they differ, check out this post here .
0. Create a new Minecraft Java Instance in AMP
Easy as that, press the Create Instance button, then select Minecraft Java Edition from the drop-down. Feel free to use an existing instan…
