Field
Value
Operating System
Windows - Windows Server 2022 on x86_64
Product
AMP ‘Decadeus’ v2.4.6.0 (Mainline)
Virtualization
HyperV
Application
DayZ (Original)
Module
GenericModule
Running in Container
No
Current State
Failed
I get the following error when starting DayZ server. AMP is running on Windows Server 2022. I have a AMP users as the install guide advised. I have tested with other games and they work correctly.
Unable to complete task
This task could not be completed: Starting DayZ (Original)… - - State: 3.
Application stopped unexpectedly with exit code -1073741515
Install DayZ
Update, steam Login
Start
Make sure you have the required deps as noted in the guide: DayZ Server Guide
I have confirmed, all dependencies are installed
Right click and check the logs from when you try to start the server
Waiting for client config…OK
Waiting for user info…OK
app_update 223350 validate
Update state (0x5) verifying install, progress: 6.41 (193925307 / 3026821612)
Update state (0x5) verifying install, progress: 20.61 (623867701 / 3026821612)
Update state (0x5) verifying install, progress: 32.72 (990271205 / 3026821612)
Update state (0x5) verifying install, progress: 54.15 (1639025209 / 3026821612)
Update state (0x5) verifying install, progress: 71.05 (2150653968 / 3026821612)
Update state (0x5) verifying install, progress: 90.86 (2750080849 / 3026821612)
Update state (0x5) verifying install, progress: 97.92 (2963993681 / 3026821612)
Success! App ‘223350’ fully installed.
quit
[06:37:41] [steamcmdplugin:julien Info] : SteamCMD Update successful
[06:37:41] [Generic:julien Info] : Skipping download - target already exists (C:\AMPDatastore\Instances\DayZOriginal01\dayz\223350\AMP_serverDZ.cfg)
[06:37:41] [Generic:julien Info] : Merging config file ./dayz/223350/./serverDZ.cfg (Template) using Unicode (UTF-8) encoding.
[06:37:41] [Generic:julien Info] : Writing config file ./dayz/223350/./battleye/beserver_x64.cfg using Unicode (UTF-8) encoding.
[06:37:52] [API:julien Activity] : Starting the application.
[06:37:52] [Generic:julien Info] : Merging config file ./dayz/223350/./serverDZ.cfg (Template) using Unicode (UTF-8) encoding.
[06:37:52] [Generic:julien Info] : Writing config file ./dayz/223350/./battleye/beserver_x64.cfg using Unicode (UTF-8) encoding.
[06:37:52] [Generic:julien Warning] : The application stopped unexpectedly. Exit code -1073741515
[06:37:55] [Generic:julien Info] : Merging config file ./dayz/223350/./serverDZ.cfg (Template) using Unicode (UTF-8) encoding.
[06:37:55] [Generic:julien Info] : Writing config file ./dayz/223350/./battleye/beserver_x64.cfg using Unicode (UTF-8) encoding.
[06:37:56] [Generic:julien Warning] : The application stopped unexpectedly. Exit code -1073741515
[06:37:59] [Generic:julien Info] : Merging config file ./dayz/223350/./serverDZ.cfg (Template) using Unicode (UTF-8) encoding.
[06:37:59] [Generic:julien Info] : Writing config file ./dayz/223350/./battleye/beserver_x64.cfg using Unicode (UTF-8) encoding.
[06:37:59] [Generic:julien Warning] : The application stopped unexpectedly. Exit code -1073741515
[06:38:02] [Generic:julien Info] : Merging config file ./dayz/223350/./serverDZ.cfg (Template) using Unicode (UTF-8) encoding.
[06:38:02] [Generic:julien Info] : Writing config file ./dayz/223350/./battleye/beserver_x64.cfg using Unicode (UTF-8) encoding.
[06:38:02] [Generic:julien Warning] : The application stopped unexpectedly. Exit code -1073741515
[06:38:05] [Generic:julien Info] : Merging config file ./dayz/223350/./serverDZ.cfg (Template) using Unicode (UTF-8) encoding.
[06:38:05] [Generic:julien Info] : Writing config file ./dayz/223350/./battleye/beserver_x64.cfg using Unicode (UTF-8) encoding.
[06:38:05] [Generic:julien Warning] : The application stopped unexpectedly. Exit code -1073741515
[06:38:05] [Generic:julien Warning] : Application failed to start 5 times, not restarting.
Under DayZ Gameplay Settings, do you have a setting called “Enable Gameplay Settings File”?
Yes I do have that setting. I have used that file in the past for custom weather settings
I’m at a loss then. Normally the issue you are encountering is a deps issue. You might try a reboot if you haven’t done so after installing those deps
Maybe they are installed but 1 or more are not happy. I’ll play around with the deps. Thank you for helping, I really appreciate it.
Edit - I’m at a loss
Mike
22 August 2023 17:15
10
Have you rebooted the VM since installing the C++ runtimes?
