DayZ Server Guide
This article sets out some key basic information for running a DayZ server on AMP.
1. Server versions
AMP has two templates for DayZ:
  • Stable - for running the original server (Steam AppID 223350)
  • Experimental - for running the experimental server (Steam AppID 1042420)
Use the client type that matches the server.
2. Dependencies on Windows
DayZ requires the following dependencies on Windows to be installed:
You will also need X86 Visual C++ Redistributable Packages for Visual Studio 2015-2022 to run SteamCMD in AMP to install the server.
3. Ports
DayZ uses (or reserves) a number of ports, which are allocated accordingly in AMP:
  • Game Port: 2302 UDP by default
  • Reserved Port: 2303 UDP by default
  • BattlEye Port: 2304 UDP by default
  • RCON Port: 2305 UDP by default
  • Query Port: 27016 UDP by default
At least the game port and query port need to be port forwarded (if you’re on a NAT network). Also forward the BattlEye port if using BattlEye on the server. Note the reserved port is not currently used by the server.
Check what ports are actually allocated to your instance by clicking on the “Edit Ports” button for the instance.
The query port is used for finding and connecting to the server in Steam. The game port is used for finding and connecting to the server in-game.
You can use the RCON port to connect to the server’s RCON by an external RCON client if needed.
Note that the reserved port and the BattlEye port are configured by the server as relative to the game port. So the reserved port is game port + 1 and the BattlEye port is game port + 2. Make sure that the relevant ports are sequential in AMP.
4. Settings
All settings that can be configured in the server’s config file, as listed here, are included in AMP’s UI.
You can search for a setting using its formal name (eg allowFilePatching) using AMP’s search bar to find it in AMP’s UI.
Any settings that are not handled by AMP directly can be added if needed to the Additional Server Settings box. These will be added directly to the end of serverDZ.cfg.
5. Mods
5.1 Installing/updating
The “Steam workshop items” option under the Updates menu is used to download and update mods on the server.
Specify the mods to be downloaded and updated by adding its mod ID, such as 1819514788. Each mod ID has to be added separately (or placed on a separate line if using the edit function). Order doesn’t matter.
The mods will be downloaded and updated whenever the server is updated.
The mod files are downloaded to the directory steamapps/workshop/content/221100, in separate directories. They are also linked by mod ID or name (depending on whether “Enable Named Mod Directory Links” is enabled) to the server base directory.
SteamCMD might time out downloading larger mods. If that happens, you can try working around it by repeating the relevant mod ID on successive lines - usually one repeated line is enough but for very large mods you may need two or more repeats.
Note that the Steam account that you use in AMP must own the game for SteamCMD to download mods on the server.
5.2 Loading
To load mods, they need to be specified either under “Load Mods” or “Load Server Mods” in the DayZ Server menu, depending on the mod type:
  • Load Mods: mods required on both server and client (mostly what you want)
  • Load Server Mods: mods that are for the server only
(The “Client Mods” setting is for mods that are for the client only (use this only to have the bikeys automatically managed on the server. The mod still needs to be on the server for that purpose but won’t be loaded).)
The mod lists must be separated by semi-colons. Make sure your mod lists are just one line - no line breaks or carriage returns.
For mods downloaded under Updates (see 3.1 above), do the following to load them:
  • If you didn’t select “Enable Named Mod Directory Links” under Updates, specify the mod IDs , such as:
    1559212036;2471347750;1819514788
  • If you selected “Enable Named Mod Directory Links” under Updates (ensure you update the server after doing so), specify the mod names prefixed by @ , such as:
    @CF;@DayZ-Dog;@Ear-Plugs
(Check the File Manager in the instance to get the names right.)
On Linux, AMP also ensures that all the mod directories and files are in lowercase, to prevent loading issues.
Note that, for some mods, order of loading is important. Any mods (like CF) that are dependencies of other mods should come first in the list.
5.3 Signature verification
DayZ requires addon signature verification, meaning that clients cannot connect if they are using mods not allowed by the server. This is a cheating protection.
To permit mods, the relevant .bikey file needs to be added to the keys directory in the server base directory. For mods installed on your server that clients are also intended to use, copy the .bikey files from the keys or key directory inside each mod directory. Also add the .bikey files of other mods (ie client-only mods) that you wish to allow.
AMP can do this automatically for you for any mods listed in “Load Mods” and/or “Client Mods”, by enabling the “Manage Bikeys” setting. The relevant .bikey files will be copied across when the server is started (assuming the mods are installed on the server, including client-only mods). Note that this will remove the .bikey files for any other mods, other than the default dayz.bikey.
6. Server binding
By default the DayZ server is bound to the application IP binding set for the instance. This is normally 0.0.0.0 (all interfaces) unless it has been changed under New Instance Defaults.
If you have multiple IPs on your host, you may wish to bind the server to one of them. You can do this by changing the Application IP Binding for the instance.
The IP binding set in this way must be one that AMP itself can reach. Otherwise AMP will not be able to connect to the server’s RCON, and therefore won’t detect when the server is started. As well, logging output to the console, and input from the console, will not be enabled. This can particularly be an issue if the server is bound to a public IP (such as on a VPS). Generally it is better to keep the binding as 0.0.0.0.
