Startup Issue with ARK: Survival Evolved and CoreKeeper- error: XDG_RUNTIME_DIR is invalid or not set in the environment
Product AMP ‘Phobos’ v2.6.2.6 (Mainline)
Application ARK: Survival Evolved
rror: XDG_RUNTIME_DIR is invalid or not set in the environment.
  • Start the instance
  • Received error: error: XDG_RUNTIME_DIR is invalid or not set in the environment.
  • Rebooted the entired amp server with the same result
Can be ignored, doesn’t affect anything
Hi Greenlan thanks for the quick response. Unfortunately, I am not able to start my instances. It is all failing
Check AMP’s logs for the instances
Hi Greenlan,
Please see the below errors. Thanks
This task could not be completed: Starting Core Keeper… - - State: 3.
Application stopped unexpectedly with exit code 139.
:Anonymous
10:13:07
Exception in API call Core/GetUpdates
UnauthorizedAccessException
[0] (UnauthorizedAccessException) : You do not have permission to use this method (GSMyAdmin.WebServer.GetUpdates) at this time. This method requires the Session.Exists permission.
at GSMyAdmin.WebServer.WebAttributes.InvokeMethod(String MethodName, JObject Data, HttpContext context, IWebSession Session, WebMethodsBase MethodsClass, IPAddress RealIP) at GSMyAdmin.WebServer.ApiService.InvokeAPI(HttpContext context, IWebSession session, JObject data, String requestModule, String requestMethod)
10:14:07
10:15:07
Click on the folder icon on the instance, go to AMP_Logs, look at the relevant logs
(Who is Greenlan, btw?)
Hello,
Apologies, your name is showing as Greenlan from my end :slight_smile:
Please see the logs below for your reference. Greatly appreciate your help for checking on this
[02:20:46] [Program Info/1] : Starting AMP version 2.6.2.6 (Phobos), built 04/08/2025 23:38
[02:20:46] [Program Info/1] : Stream: Mainline / Release - built by CUBECODERS/buildbot on CCL-DEV
[02:20:46] [Program Info/1] : Running in a Docker environment.
[02:20:46] [Program Info/1] : OS: Linux / x86_64
[02:20:46] [Program Info/1] : CPU: Intel(R) Core™ i7-9700 CPU @ 3.00GHz (8C/8T)
[02:20:46] [Program Info/1] : RAM: 48019MB
[02:20:46] [Program Info/1] : AMP Instance ID: d25bf955-1c5d-477a-8eff-7d764cf3af98
[02:20:47] [Core Info/1] : Loaded GenericModule version 2.6.2.6 by CubeCoders Limited
[02:20:47] [Core Info/1] : Metrics publishing is enabled at udp://localhost:12820.
[02:20:47] [Loader Info/1] : Loaded FileManagerPlugin by CubeCoders Limited
[02:20:47] [Loader Info/1] : Loaded EmailSenderPlugin by CubeCoders Limited
[02:20:47] [Loader Info/1] : Loaded WebRequestPlugin by CubeCoders Limited
[02:20:47] [Loader Info/1] : Loaded LocalFileBackupPlugin by CubeCoders Limited
[02:20:47] [Loader Info/1] : Loaded CommonCorePlugin by CubeCoders Limited
[02:20:47] [Loader Info/1] : Loaded AnalyticsPlugin by CubeCoders Limited
[02:20:47] [System Error/10] : Missing plugin/assembly: MaxMind.Db (/AMP/Plugins/MaxMind.Db/MaxMind.Db.dll) for
[02:20:47] [Loader Info/1] : GenericModule requests dependency steamcmdplugin…
[02:20:47] [Loader Info/1] : Loaded steamcmdplugin by CubeCoders Limited
[02:20:47] [Loader Info/1] : GenericModule requests dependency RCONPlugin…
[02:20:47] [Loader Info/1] : Loaded RCONPlugin by CubeCoders Limited
[02:20:47] [Core Info/1] : Licence Present: AMP Professional Edition - Lifetime Licence
[02:20:48] [Loader Info/1] : SFTP Server started on 0.0.0.0:2226
[02:20:49] [Core Info/1] : Webserver started on http://127.0.0.1:8084
[02:20:49] [System Info/10] : Checking for AMP updates…
[02:20:49] [System Info/9] : Startup mode is UpdateAndStart.
[02:20:49] [System Info/12] : AMP is up to date.
UpdateUI: skip show logo
Steam Console Client (c) Valve Corporation - version 1751406682
– type ‘quit’ to exit –
Loading Steam API…OK
force_install_dir “376030”
Waiting for client config…OK
Waiting for user info…OK
@sSteamCmdForcePlatformType” = “windows”
app_update 376030 -beta public validate
IPC function call IClientAppManager::GetUpdateInfo took too long: 714 msec
IPC function call IClientAppManager::GetUpdateInfo took too long: 283 msec
IPC function call IClientAppManager::GetUpdateInfo took too long: 293 msec
IPC function call IClientAppManager::GetUpdateInfo took too long: 167 msec
Update state (0x41) staging, progress: 0.00 (0 / 0)
IPC function call IClientAppManager::GetUpdateInfo took too long: 113 msec
IPC function call IClientAppManager::GetUpdateInfo took too long: 62 msec
Success! App ‘376030’ fully installed.
quit
Unloading Steam API…OK
[02:21:00] [System Info/15] : SteamCMD Update successful
[02:21:00] [System Info/15] : Downloading steam workshop items…
[02:21:00] [System Info/15] : Downloading items 731604991,1609138312,936959483,924933745,2594067220…
workshop_download_item 346110 731604991 validate
Downloading item 731604991 …
Success. Downloaded item 731604991 to “/AMP/arkse/376030/steamapps/workshop/content/346110/731604991” (60998180 bytes) workshop_download_item 346110 1609138312 validate
Downloading item 1609138312 …
Success. Downloaded item 1609138312 to “/AMP/arkse/376030/steamapps/workshop/content/346110/1609138312” (42924599 bytes) workshop_download_item 346110 936959483 validate
Downloading item 936959483 …
Success. Downloaded item 936959483 to “/AMP/arkse/376030/steamapps/workshop/content/346110/936959483” (35640845 bytes) workshop_download_item 346110 924933745 validate
Downloading item 924933745 …
Success. Downloaded item 924933745 to “/AMP/arkse/376030/steamapps/workshop/content/346110/924933745” (4156936 bytes) workshop_download_item 346110 2594067220 validate
Downloading item 2594067220 …
Success. Downloaded item 2594067220 to “/AMP/arkse/376030/steamapps/workshop/content/346110/2594067220” (1758264 bytes) quit
[02:21:09] [System Info/9] : SteamCMD Update successful
[02:21:09] [System Info/9] : Downloading items 741203089,812655342,1445181373,895711211,1645346094…
workshop_download_item 346110 741203089 validate
Downloading item 741203089 …
Success. Downloaded item 741203089 to “/AMP/arkse/376030/steamapps/workshop/content/346110/741203089” (539877481 bytes) workshop_download_item 346110 812655342 validate
Downloading item 812655342 …
Success. Downloaded item 812655342 to “/AMP/arkse/376030/steamapps/workshop/content/346110/812655342” (218151540 bytes) workshop_download_item 346110 1445181373 validate
[02:21:15] [System Activity/12] : Authentication attempt for user mochi from 127.0.0.1
[02:21:16] [System Activity/12] : Authentication success
Downloading item 1445181373 …
Success. Downloaded item 1445181373 to “/AMP/arkse/376030/steamapps/workshop/content/346110/1445181373” (728066200 bytes) workshop_download_item 346110 895711211 validate
Downloading item 895711211 …
Success. Downloaded item 895711211 to “/AMP/arkse/376030/steamapps/workshop/content/346110/895711211” (80860267 bytes) workshop_download_item 346110 1645346094 validate
Downloading item 1645346094 …
Success. Downloaded item 1645346094 to “/AMP/arkse/376030/steamapps/workshop/content/346110/1645346094” (59449711 bytes) quit
[02:21:20] [System Info/9] : SteamCMD Update successful
Installing/updating workshop items …
Workshop item installation/update process finished
Summary:
Total items attempted: 0
Successfully processed: 0
Failed to process: 0
[02:21:23] [System Info/20] : Extracting /AMP/arkse/376030/ShooterGame/Binaries/Win64/ArkApi_3.56.zip to /AMP/arkse/376030/ShooterGame/Binaries/Win64/…
[02:21:26] [System Info/9] : Skipping download - target already exists (/AMP/arkse/376030/.backupExclude)
[02:21:27] [System Info/18] : Skipping download - target already exists (/AMP/arkse/376030/ShooterGame/.backupExclude)
[02:21:59] [System Error/9] : Source RCON failed to connect:
Connection refused.
[02:21:59] [RCON Info/15] : Source RCON disconnecting…
[02:22:00] [RCON Info/15] : Source RCON disconnected
[02:22:05] [System Error/20] : Source RCON failed to connect:
Connection refused.
[02:22:05] [RCON Info/20] : Source RCON disconnecting…
[02:22:06] [RCON Info/20] : Source RCON disconnected
[02:22:11] [System Error/10] : Source RCON failed to connect:
Connection refused.
[02:22:11] [RCON Info/10] : Source RCON disconnecting…
[02:22:12] [RCON Info/10] : Source RCON disconnected
[02:22:17] [System Error/9] : Source RCON failed to connect:
Connection refused.
[02:22:17] [RCON Info/9] : Source RCON disconnecting…
[02:22:18] [RCON Info/9] : Source RCON disconnected
[02:22:23] [System Error/10] : Source RCON failed to connect:
Connection refused.
[02:22:23] [RCON Info/10] : Source RCON disconnecting…
[02:22:24] [RCON Info/10] : Source RCON disconnected
[02:22:29] [System Error/9] : Source RCON failed to connect:
Connection refused.
[02:22:29] [RCON Info/9] : Source RCON disconnecting…
[02:22:30] [RCON Info/9] : Source RCON disconnected
[02:22:30] [System Activity/22] : Authentication attempt for user mochi from 127.0.0.1
[02:22:31] [System Activity/10] : Authentication success
[02:22:35] [System Error/22] : Source RCON failed to connect:
Connection refused.
[02:22:35] [RCON Info/10] : Source RCON disconnecting…
[02:22:36] [RCON Info/10] : Source RCON disconnected
[02:22:41] [System Error/16] : Source RCON failed to connect:
Connection refused.
[02:22:41] [RCON Info/16] : Source RCON disconnecting…
[02:22:42] [RCON Info/16] : Source RCON disconnected
[02:22:47] [System Error/9] : Source RCON failed to connect:
Connection refused.
[02:22:47] [RCON Info/9] : Source RCON disconnecting…
[02:22:48] [RCON Info/9] : Source RCON disconnected
[02:22:48] [System Warning/16] : The application stopped unexpectedly. Exit code 3
[02:22:53] [System Error/10] : Source RCON failed to connect:
Connection refused.
[02:22:53] [RCON Info/9] : Source RCON disconnecting…
[02:22:54] [RCON Info/9] : Source RCON disconnected
[02:22:59] [System Error/9] : Source RCON failed to connect:
Connection refused.
[02:22:59] [RCON Info/16] : Source RCON disconnecting…
[02:23:00] [RCON Info/16] : Source RCON disconnected
[02:23:04] [System Error/22] : Source RCON failed to connect:
Connection refused.
[02:23:04] [RCON Info/16] : Source RCON disconnecting…
[02:23:05] [RCON Info/16] : Source RCON disconnected
[02:23:09] [System Error/9] : Source RCON failed to connect:
Connection refused.
[02:23:09] [RCON Info/9] : Source RCON disconnecting…
[02:23:10] [RCON Info/9] : Source RCON disconnected
[02:23:14] [System Error/9] : Source RCON failed to connect:
Connection refused.
[02:23:14] [RCON Info/22] : Source RCON disconnecting…
[02:23:15] [RCON Info/22] : Source RCON disconnected
[02:23:19] [System Error/22] : Source RCON failed to connect:
Connection refused.
[02:23:19] [RCON Info/9] : Source RCON disconnecting…
[02:23:20] [RCON Info/9] : Source RCON disconnected
[02:23:24] [System Error/9] : Source RCON failed to connect:
Connection refused.
[02:23:24] [RCON Info/22] : Source RCON disconnecting…
[02:23:25] [RCON Info/22] : Source RCON disconnected
[02:23:29] [System Error/22] : Source RCON failed to connect:
Connection refused.
[02:23:29] [RCON Info/9] : Source RCON disconnecting…
[02:23:30] [RCON Info/9] : Source RCON disconnected
[02:23:34] [System Error/22] : Source RCON failed to connect:
Connection refused.
[02:23:34] [RCON Info/16] : Source RCON disconnecting…
[02:23:35] [RCON Info/16] : Source RCON disconnected
[02:23:39] [System Error/16] : Source RCON failed to connect:
Connection refused.
[02:23:39] [RCON Info/9] : Source RCON disconnecting…
[02:23:40] [RCON Info/9] : Source RCON disconnected
[02:23:44] [System Error/16] : Source RCON failed to connect:
Connection refused.
[02:23:44] [RCON Info/16] : Source RCON disconnecting…
[02:23:45] [RCON Info/16] : Source RCON disconnected
[02:23:49] [System Error/9] : Source RCON failed to connect:
Connection refused.
[02:23:49] [RCON Info/16] : Source RCON disconnecting…
[02:23:50] [RCON Info/16] : Source RCON disconnected
[02:23:51] [System Warning/16] : The application stopped unexpectedly. Exit code 3
[02:23:51] [System Warning/16] : Application failed to start 2 times, not restarting.
[02:23:54] [System Error/16] : Source RCON failed to connect:
Connection refused.
[02:23:54] [RCON Info/9] : Source RCON disconnecting…
[02:23:55] [RCON Info/9] : Source RCON disconnected
[02:23:59] [System Error/22] : Source RCON failed to connect:
Connection refused.
[02:23:59] [RCON Info/9] : Source RCON disconnecting…
[02:24:00] [RCON Info/9] : Source RCON disconnected
[02:24:04] [System Error/9] : Source RCON failed to connect:
Connection refused.
[02:24:04] [RCON Info/22] : Source RCON disconnecting…
[02:24:05] [RCON Info/22] : Source RCON disconnected
[02:24:09] [System Error/22] : Source RCON failed to connect:
Connection refused.
[02:24:09] [RCON Info/9] : Source RCON disconnecting…
[02:24:10] [RCON Info/9] : Source RCON disconnected
[02:24:14] [System Error/9] : Source RCON failed to connect:
Connection refused.
[02:24:14] [RCON Info/22] : Source RCON disconnecting…
[02:24:15] [RCON Info/22] : Source RCON disconnected
[02:24:19] [System Error/22] : Source RCON failed to connect:
Connection refused.
[02:24:19] [RCON Info/9] : Source RCON disconnecting…
[02:24:20] [RCON Info/9] : Source RCON disconnected
[02:24:24] [System Error/22] : Source RCON failed to connect:
Connection refused.
[02:24:24] [RCON Info/9] : Source RCON disconnecting…
[02:24:25] [RCON Info/9] : Source RCON disconnected
[02:24:29] [System Error/16] : Source RCON failed to connect:
Connection refused.
[02:24:29] [RCON Info/9] : Source RCON disconnecting…
[02:24:30] [RCON Info/9] : Source RCON disconnected
[02:24:34] [System Error/22] : Source RCON failed to connect:
Connection refused.
[02:24:34] [RCON Info/9] : Source RCON disconnecting…
[02:24:35] [RCON Info/9] : Source RCON disconnected
[02:24:39] [System Error/22] : Source RCON failed to connect:
Connection refused.
[02:24:39] [RCON Info/9] : Source RCON disconnecting…
[02:24:40] [RCON Info/9] : Source RCON disconnected
[02:24:44] [System Error/16] : Source RCON failed to connect:
Connection refused.
[02:24:44] [RCON Info/9] : Source RCON disconnecting…
[02:24:45] [RCON Info/9] : Source RCON disconnected
[02:24:49] [System Error/9] : Source RCON failed to connect:
Connection refused.
[02:24:49] [RCON Info/22] : Source RCON disconnecting…
[02:24:50] [RCON Info/22] : Source RCON disconnected
[02:24:54] [System Error/16] : Source RCON failed to connect:
Connection refused.
[02:24:54] [RCON Info/22] : Source RCON disconnecting…
[02:24:55] [RCON Info/22] : Source RCON disconnected
[02:24:57] [System Activity/16] : Authentication attempt for user mochi from 127.0.0.1
[02:24:57] [System Activity/22] : Authentication success
[02:24:59] [System Error/9] : Source RCON failed to connect:
Connection refused.
[02:24:59] [RCON Info/25] : Source RCON disconnecting…
[02:25:00] [RCON Info/25] : Source RCON disconnected
[02:25:04] [System Error/25] : Source RCON failed to connect:
Connection refused.
[02:25:04] [RCON Info/23] : Source RCON disconnecting…
[02:25:05] [RCON Info/23] : Source RCON disconnected
[02:25:09] [System Error/25] : Source RCON failed to connect:
Connection refused.
[02:25:09] [RCON Info/23] : Source RCON disconnecting…
[02:25:10] [RCON Info/23] : Source RCON disconnected
[02:25:14] [System Error/9] : Source RCON failed to connect:
Connection refused.
[02:25:14] [RCON Info/23] : Source RCON disconnecting…
[02:25:15] [RCON Info/23] : Source RCON disconnected
[02:25:19] [System Error/23] : Source RCON failed to connect:
Connection refused.
[02:25:19] [RCON Info/9] : Source RCON disconnecting…
[02:25:20] [RCON Info/9] : Source RCON disconnected
[02:25:24] [System Error/9] : Source RCON failed to connect:
Connection refused.
[02:25:24] [RCON Info/23] : Source RCON disconnecting…
[02:25:25] [RCON Info/23] : Source RCON disconnected
[02:25:29] [System Error/16] : Source RCON failed to connect:
Connection refused.
[02:25:29] [RCON Info/16] : Source RCON disconnecting…
[02:25:30] [RCON Info/16] : Source RCON disconnected
[02:25:34] [System Error/23] : Source RCON failed to connect:
Connection refused.
[02:25:34] [RCON Info/9] : Source RCON disconnecting…
[02:25:35] [RCON Info/9] : Source RCON disconnected
[02:25:39] [System Error/23] : Source RCON failed to connect:
Connection refused.
[02:25:39] [RCON Info/9] : Source RCON disconnecting…
[02:25:40] [RCON Info/9] : Source RCON disconnected
[02:25:44] [System Error/9] : Source RCON failed to connect:
Connection refused.
[02:25:44] [RCON Info/23] : Source RCON disconnecting…
[02:25:45] [RCON Info/23] : Source RCON disconnected
[02:25:49] [System Error/23] : Source RCON failed to connect:
Connection refused.
[02:25:49] [RCON Info/9] : Source RCON disconnecting…
[02:25:50] [RCON Info/9] : Source RCON disconnected
[02:25:54] [System Error/23] : Source RCON failed to connect:
Connection refused.
[02:25:54] [RCON Info/23] : Source RCON disconnecting…
[02:25:55] [RCON Info/23] : Source RCON disconnected
[02:25:59] [System Error/23] : Source RCON failed to connect:
Connection refused.
[02:25:59] [RCON Info/9] : Source RCON disconnecting…
[02:26:00] [RCON Info/9] : Source RCON disconnected
[02:26:04] [System Error/9] : Source RCON failed to connect:
Connection refused.
[02:26:04] [RCON Info/25] : Source RCON disconnecting…
[02:26:05] [RCON Info/25] : Source RCON disconnected
[02:26:09] [System Error/9] : Source RCON failed to connect:
Connection refused.
[02:26:09] [RCON Info/25] : Source RCON disconnecting…
[02:26:10] [RCON Info/25] : Source RCON disconnected
[02:26:14] [System Error/27] : Source RCON failed to connect:
Connection refused.
[02:26:14] [RCON Info/27] : Source RCON disconnecting…
[02:26:15] [RCON Info/27] : Source RCON disconnected
[02:26:19] [System Error/25] : Source RCON failed to connect:
Connection refused.
[02:26:19] [RCON Info/27] : Source RCON disconnecting…
Er, no it ain’t, lol, given that is not my name
You don’t use the Steam workshop items setting with ARK
Mod-related settings are under Configuration > ARK SE > Server
Hello,
I tried that, but still with the same error
[02:44:56] [API:mochi Activity/28] : Changing setting Meta.GenericModule.GameModIds to 7316049911609138312
936959483
924933745
2594067220
741203089
812655342
1445181373
895711211
1645346094
[02:44:57] [API:mochi Activity/28] : Changing setting Meta.GenericModule.GameModIds to 731604991,1609138312
936959483
924933745
2594067220
741203089
812655342
1445181373
895711211
1645346094
[02:44:59] [System Error/26] : Source RCON failed to connect:
Connection refused.
[02:44:59] [RCON Info/26] : Source RCON disconnecting…
[02:45:00] [RCON Info/26] : Source RCON disconnected
[02:45:00] [API:mochi Activity/26] : Changing setting Meta.GenericModule.GameModIds to 731604991,1609138312936959483
924933745
2594067220
741203089
812655342
1445181373
895711211
1645346094
[02:45:00] [API:mochi Activity/26] : Changing setting Meta.GenericModule.GameModIds to 731604991,1609138312,936959483
924933745
2594067220
741203089
812655342
1445181373
895711211
1645346094
[02:45:03] [API:mochi Activity/25] : Changing setting Meta.GenericModule.GameModIds to 731604991,1609138312,936959483924933745
2594067220
741203089
812655342
1445181373
895711211
1645346094
[02:45:03] [API:mochi Activity/26] : Changing setting Meta.GenericModule.GameModIds to 731604991,1609138312,936959483,924933745
2594067220
741203089
812655342
1445181373
895711211
1645346094
[02:45:04] [System Error/26] : Source RCON failed to connect:
Connection refused.
[02:45:04] [RCON Info/26] : Source RCON disconnecting…
[02:45:05] [RCON Info/26] : Source RCON disconnected
[02:45:06] [API:mochi Activity/26] : Changing setting Meta.GenericModule.GameModIds to 731604991,1609138312,936959483,924933745
,2594067220
741203089
812655342
1445181373
895711211
1645346094
[02:45:08] [API:mochi Activity/26] : Changing setting Meta.GenericModule.GameModIds to 731604991,1609138312,936959483,924933745,2594067220
741203089
812655342
1445181373
895711211
1645346094
[02:45:09] [System:mochi Error/26] : Source RCON failed to connect:
Connection refused.
[02:45:09] [RCON:mochi Info/26] : Source RCON disconnecting…
[02:45:10] [RCON:mochi Info/26] : Source RCON disconnected
[02:45:12] [API:mochi Activity/25] : Changing setting Meta.GenericModule.GameModIds to 731604991,1609138312,936959483,924933745,254067220
741203089
812655342
1445181373
895711211
1645346094
[02:45:13] [API:mochi Activity/28] : Changing setting Meta.GenericModule.GameModIds to 731604991,1609138312,936959483,924933745,25,4067220
741203089
812655342
1445181373
895711211
1645346094
[02:45:14] [System:mochi Error/25] : Source RCON failed to connect:
Connection refused.
[02:45:14] [RCON:mochi Info/25] : Source RCON disconnecting…
[02:45:15] [RCON:mochi Info/25] : Source RCON disconnected
[02:45:19] [System Error/26] : Source RCON failed to connect:
Connection refused.
[02:45:19] [RCON Info/25] : Source RCON disconnecting…
[02:45:20] [RCON Info/25] : Source RCON disconnected
[02:45:20] [API:mochi Activity/25] : Changing setting Meta.GenericModule.GameModIds to 731604991,1609138312,936959483,924933745,254067220
741203089
812655342
1445181373
895711211
1645346094
[02:45:24] [System Error/25] : Source RCON failed to connect:
Connection refused.
[02:45:24] [RCON Info/25] : Source RCON disconnecting…
[02:45:24] [API:mochi Activity/26] : Changing setting Meta.GenericModule.GameModIds to 731604991,1609138312,936959483,924933745,25,4067220
741203089
812655342
1445181373
895711211
1645346094
[02:45:24] [API:mochi Activity/28] : Changing setting Meta.GenericModule.GameModIds to 731604991,1609138312,936959483,924933745,2594067220
741203089
812655342
1445181373
895711211
1645346094
[02:45:25] [API:mochi Activity/26] : Changing setting Meta.GenericModule.GameModIds to 731604991,1609138312,936959483,924933745
,2594067220
741203089
812655342
1445181373
895711211
1645346094
[02:45:25] [RCON Info/25] : Source RCON disconnected
[02:45:26] [API:mochi Activity/26] : Changing setting Meta.GenericModule.GameModIds to 731604991,1609138312,936959483,924933745
2594067220
741203089
812655342
1445181373
895711211
1645346094
[02:45:29] [System:mochi Error/25] : Source RCON failed to connect:
Connection refused.
[02:45:29] [RCON:mochi Info/25] : Source RCON disconnecting…
[02:45:30] [API:mochi Activity/26] : Changing setting Meta.GenericModule.GameModIds to 731604991,1609138312,936959483,924933745
,2594067220
741203089
812655342
1445181373
895711211
1645346094
[02:45:30] [RCON:mochi Info/25] : Source RCON disconnected
[02:45:32] [API:mochi Activity/28] : Changing setting Meta.GenericModule.GameModIds to 731604991,1609138312,936959483,924933745,2594067220
741203089
812655342
1445181373
895711211
1645346094
[02:45:34] [System:mochi Error/26] : Source RCON failed to connect:
Connection refused.
[02:45:34] [RCON:mochi Info/26] : Source RCON disconnecting…
[02:45:35] [RCON:mochi Info/26] : Source RCON disconnected
[02:45:37] [API:mochi Activity/25] : Changing setting Meta.GenericModule.GameModIds to 731604991,1609138312,936959483,924933745
,2594067220
741203089
812655342
1445181373
895711211
1645346094
[02:45:37] [API:mochi Activity/28] : Changing setting Meta.GenericModule.GameModIds to 731604991,1609138312,936959483,924933745
2594067220
741203089
812655342
1445181373
895711211
1645346094
[02:45:38] [API:mochi Activity/28] : Changing setting Meta.GenericModule.GameModIds to 731604991,1609138312,936959483
924933745
2594067220
741203089
812655342
1445181373
895711211
1645346094
[02:45:39] [System Error/25] : Source RCON failed to connect:
Connection refused.
[02:45:39] [RCON Info/25] : Source RCON disconnecting…
[02:45:40] [RCON Info/25] : Source RCON disconnected
[02:45:44] [System Error/3] : Source RCON failed to connect:
Connection refused.
[02:45:44] [RCON Info/25] : Source RCON disconnecting…
[02:45:45] [API:mochi Activity/3] : Changing setting Meta.GenericModule.GameModIds to 731604991,1609138312,936959483924933745
2594067220
741203089
812655342
1445181373
895711211
1645346094
[02:45:45] [RCON Info/25] : Source RCON disconnected
[02:45:46] [API:mochi Activity/25] : Changing setting Meta.GenericModule.GameModIds to 731604991,1609138312,936959483,924933745
2594067220
741203089
812655342
1445181373
895711211
1645346094
[02:45:48] [API:mochi Activity/25] : Changing setting Meta.GenericModule.GameModIds to 731604991,1609138312,936959483,9249337452594067220
741203089
812655342
1445181373
895711211
1645346094
[02:45:49] [System:mochi Error/25] : Source RCON failed to connect:
Connection refused.
[02:45:49] [RCON:mochi Info/25] : Source RCON disconnecting…
[02:45:49] [API:mochi Activity/16] : Changing setting Meta.GenericModule.GameModIds to 731604991,1609138312,936959483,924933745,2594067220
741203089
812655342
1445181373
895711211
1645346094
[02:45:50] [RCON:mochi Info/25] : Source RCON disconnected
[02:45:52] [API:mochi Activity/25] : Changing setting Meta.GenericModule.GameModIds to 731604991,1609138312,936959483,924933745,2594067220741203089
812655342
1445181373
895711211
1645346094
[02:45:53] [API:mochi Activity/25] : Changing setting Meta.GenericModule.GameModIds to 731604991,1609138312,936959483,924933745,2594067220,741203089
812655342
1445181373
895711211
1645346094
[02:45:54] [System:mochi Error/3] : Source RCON failed to connect:
Connection refused.
[02:45:54] [RCON:mochi Info/25] : Source RCON disconnecting…
[02:45:55] [RCON:mochi Info/25] : Source RCON disconnected
[02:45:55] [API:mochi Activity/26] : Changing setting Meta.GenericModule.GameModIds to 731604991,1609138312,936959483,924933745,2594067220,741203089812655342
1445181373
895711211
1645346094
[02:45:56] [API:mochi Activity/26] : Changing setting Meta.GenericModule.GameModIds to 731604991,1609138312,936959483,924933745,2594067220,741203089,812655342
1445181373
895711211
1645346094
[02:45:58] [API:mochi Activity/25] : Changing setting Meta.GenericModule.GameModIds to 731604991,1609138312,936959483,924933745,2594067220,741203089,8126553421445181373
895711211
1645346094
[02:45:59] [System Error/25] : Source RCON failed to connect:
Connection refused.
[02:45:59] [RCON Info/25] : Source RCON disconnecting…
[02:45:59] [API:mochi Activity/3] : Changing setting Meta.GenericModule.GameModIds to 731604991,1609138312,936959483,924933745,2594067220,741203089,812655342,1445181373
895711211
1645346094
[02:46:00] [RCON Info/25] : Source RCON disconnected
[02:46:01] [API:mochi Activity/25] : Changing setting Meta.GenericModule.GameModIds to 731604991,1609138312,936959483,924933745,2594067220,741203089,812655342,1445181373895711211
1645346094
[02:46:02] [API:mochi Activity/26] : Changing setting Meta.GenericModule.GameModIds to 731604991,1609138312,936959483,924933745,2594067220,741203089,812655342,1445181373,895711211
1645346094
[02:46:04] [System Error/25] : Source RCON failed to connect:
Connection refused.
[02:46:04] [RCON Info/25] : Source RCON disconnecting…
[02:46:05] [RCON Info/25] : Source RCON disconnected
[02:46:05] [API:mochi Activity/3] : Changing setting Meta.GenericModule.GameModIds to 731604991,1609138312,936959483,924933745,2594067220,741203089,812655342,1445181373,8957112111645346094
[02:46:06] [API:mochi Activity/3] : Changing setting Meta.GenericModule.GameModIds to 731604991,1609138312,936959483,924933745,2594067220,741203089,812655342,1445181373,895711211,1645346094
[02:46:09] [System:mochi Error/25] : Source RCON failed to connect:
Connection refused.
[02:46:09] [RCON:mochi Info/3] : Source RCON disconnecting…
[02:46:10] [RCON:mochi Info/3] : Source RCON disconnected
[02:46:12] [Core:mochi Activity/16] : Updating the application.
[02:46:14] [System:mochi Error/16] : Source RCON failed to connect:
Connection refused.
[02:46:14] [RCON:mochi Info/25] : Source RCON disconnecting…
[02:46:15] [RCON:mochi Info/25] : Source RCON disconnected
IPC function call IClientAppManager::GetUpdateInfo took too long: 468 msec
Update state (0x5) verifying install, progress: 0.45 (104013727 / 22873560602)
[02:46:19] [System Error/26] : Source RCON failed to connect:
Connection refused.
[02:46:19] [RCON Info/26] : Source RCON disconnecting…
[02:46:20] [RCON Info/26] : Source RCON disconnected
Update state (0x5) verifying install, progress: 3.10 (709566727 / 22873560602)
Update state (0x5) verifying install, progress: 5.96 (1363206061 / 22873560602)
[02:46:24] [System Error/16] : Source RCON failed to connect:
Connection refused.
[02:46:24] [RCON Info/26] : Source RCON disconnecting…
Update state (0x5) verifying install, progress: 8.29 (1896357245 / 22873560602)
[02:46:25] [RCON Info/26] : Source RCON disconnected
Update state (0x5) verifying install, progress: 11.30 (2585301602 / 22873560602)
Update state (0x5) verifying install, progress: 12.07 (2759846546 / 22873560602)
[02:46:29] [System:mochi Error/16] : Source RCON failed to connect:
Connection refused.
[02:46:29] [RCON:mochi Info/16] : Source RCON disconnecting…
[02:46:30] [RCON:mochi Info/16] : Source RCON disconnected
Update state (0x5) verifying install, progress: 12.84 (2938061348 / 22873560602)
Update state (0x5) verifying install, progress: 14.24 (3256599091 / 22873560602)
[02:46:34] [System:mochi Error/25] : Source RCON failed to connect:
Connection refused.
[02:46:34] [RCON:mochi Info/16] : Source RCON disconnecting…
Update state (0x5) verifying install, progress: 18.29 (4184570055 / 22873560602)
[02:46:35] [RCON:mochi Info/16] : Source RCON disconnected
Update state (0x5) verifying install, progress: 21.93 (5015756869 / 22873560602)
Update state (0x5) verifying install, progress: 25.89 (5921543298 / 22873560602)
[02:46:39] [System Error/16] : Source RCON failed to connect:
Connection refused.
[02:46:39] [RCON Info/26] : Source RCON disconnecting…
[02:46:40] [RCON Info/26] : Source RCON disconnected
Update state (0x5) verifying install, progress: 30.05 (6873479206 / 22873560602)
Update state (0x5) verifying install, progress: 33.06 (7561267282 / 22873560602)
[02:46:44] [System Error/26] : Source RCON failed to connect:
Connection refused.
[02:46:44] [RCON Info/26] : Source RCON disconnecting…
Update state (0x5) verifying install, progress: 36.36 (8315801063 / 22873560602)
[02:46:45] [RCON Info/26] : Source RCON disconnected
Update state (0x5) verifying install, progress: 39.15 (8955149376 / 22873560602)
Update state (0x5) verifying install, progress: 43.26 (9895727593 / 22873560602)
[02:46:49] [System:mochi Error/3] : Source RCON failed to connect:
Connection refused.
[02:46:49] [RCON:mochi Info/3] : Source RCON disconnecting…
[02:46:50] [RCON:mochi Info/3] : Source RCON disconnected
Update state (0x5) verifying install, progress: 47.42 (10845528374 / 22873560602)
Update state (0x5) verifying install, progress: 51.66 (11816509750 / 22873560602)
[02:46:54] [System:mochi Error/16] : Source RCON failed to connect:
Connection refused.
[02:46:54] [RCON:mochi Info/26] : Source RCON disconnecting…
[02:46:55] [RCON:mochi Info/26] : Source RCON disconnected
Update state (0x5) verifying install, progress: 55.87 (12778644310 / 22873560602)
Update state (0x5) verifying install, progress: 60.02 (13728673306 / 22873560602)
[02:46:59] [System Error/26] : Source RCON failed to connect:
Connection refused.
[02:46:59] [RCON Info/26] : Source RCON disconnecting…
Update state (0x5) verifying install, progress: 64.20 (14683722135 / 22873560602)
[02:47:00] [RCON Info/26] : Source RCON disconnected
Update state (0x5) verifying install, progress: 68.15 (15588102679 / 22873560602)
Update state (0x5) verifying install, progress: 72.29 (16535111720 / 22873560602)
[02:47:04] [System Error/3] : Source RCON failed to connect:
Connection refused.
[02:47:04] [RCON Info/26] : Source RCON disconnecting…
[02:47:05] [RCON Info/26] : Source RCON disconnected
Update state (0x5) verifying install, progress: 75.97 (17376730943 / 22873560602)
Update state (0x5) verifying install, progress: 80.08 (18316292510 / 22873560602)
[02:47:09] [System:mochi Error/3] : Source RCON failed to connect:
Connection refused.
[02:47:09] [RCON:mochi Info/26] : Source RCON disconnecting…
Update state (0x5) verifying install, progress: 84.24 (19269325581 / 22873560602)
[02:47:10] [RCON:mochi Info/26] : Source RCON disconnected
Update state (0x5) verifying install, progress: 87.53 (20020310572 / 22873560602)
Update state (0x5) verifying install, progress: 90.64 (20732408241 / 22873560602)
[02:47:14] [System:mochi Error/26] : Source RCON failed to connect:
Connection refused.
[02:47:14] [RCON:mochi Info/16] : Source RCON disconnecting…
[02:47:15] [RCON:mochi Info/16] : Source RCON disconnected
Update state (0x5) verifying install, progress: 93.95 (21490121088 / 22873560602)
Update state (0x5) verifying install, progress: 97.59 (22323433766 / 22873560602)
IPC function call IClientAppManager::GetUpdateInfo took too long: 47 msec
quit
[02:47:19] [System Error/16] : Source RCON failed to connect:
Connection refused.
[02:47:19] [RCON Info/7] : Source RCON disconnecting…
[02:47:19] [System:mochi Info/16] : SteamCMD Update successful
[02:47:20] [RCON Info/7] : Source RCON disconnected
[02:47:24] [System Error/16] : Source RCON failed to connect:
Connection refused.
[02:47:24] [RCON Info/7] : Source RCON disconnecting…
[02:47:25] [RCON Info/7] : Source RCON disconnected
Installing/updating item 731604991 …
[02:47:29] [System:mochi Error/16] : Source RCON failed to connect:
Connection refused.
[02:47:29] [RCON:mochi Info/3] : Source RCON disconnecting…
[02:47:30] [RCON:mochi Info/3] : Source RCON disconnected
[02:47:34] [System:mochi Error/18] : Source RCON failed to connect:
Connection refused.
[02:47:34] [RCON:mochi Info/18] : Source RCON disconnecting…
[02:47:35] [RCON:mochi Info/18] : Source RCON disconnected
Success: Installed/updated item 731604991
[02:47:39] [System Error/3] : Source RCON failed to connect:
Connection refused.
[02:47:39] [RCON Info/3] : Source RCON disconnecting…
[02:47:40] [RCON Info/3] : Source RCON disconnected
Installing/updating item 1609138312 …
[02:47:44] [System Error/7] : Source RCON failed to connect:
Connection refused.
[02:47:44] [RCON Info/16] : Source RCON disconnecting…
Success: Installed/updated item 1609138312
[02:47:45] [RCON Info/16] : Source RCON disconnected
Installing/updating item 936959483 …
Success: Installed/updated item 936959483
[02:47:49] [System:mochi Error/3] : Source RCON failed to connect:
Connection refused.
[02:47:49] [RCON:mochi Info/16] : Source RCON disconnecting…
[02:47:50] [RCON:mochi Info/16] : Source RCON disconnected
Installing/updating item 924933745 …
Success: Installed/updated item 924933745
[02:47:54] [System:mochi Error/16] : Source RCON failed to connect:
Connection refused.
[02:47:54] [RCON:mochi Info/7] : Source RCON disconnecting…
[02:47:55] [RCON:mochi Info/7] : Source RCON disconnected
Installing/updating item 2594067220 …
Success: Installed/updated item 2594067220
[02:47:59] [System Error/16] : Source RCON failed to connect:
Connection refused.
[02:47:59] [RCON Info/18] : Source RCON disconnecting…
[02:48:00] [RCON Info/18] : Source RCON disconnected
Installing/updating item 741203089 …
[02:48:04] [System Error/7] : Source RCON failed to connect:
Connection refused.
[02:48:04] [RCON Info/7] : Source RCON disconnecting…
[02:48:05] [RCON Info/7] : Source RCON disconnected
[02:48:09] [System:mochi Error/7] : Source RCON failed to connect:
Connection refused.
[02:48:09] [RCON:mochi Info/7] : Source RCON disconnecting…
[02:48:10] [RCON:mochi Info/7] : Source RCON disconnected
[02:48:14] [System:mochi Error/7] : Source RCON failed to connect:
Connection refused.
[02:48:14] [RCON:mochi Info/16] : Source RCON disconnecting…
[02:48:15] [RCON:mochi Info/16] : Source RCON disconnected
Success: Installed/updated item 741203089
[02:48:19] [System Error/18] : Source RCON failed to connect:
Connection refused.
[02:48:19] [RCON Info/16] : Source RCON disconnecting…
[02:48:20] [RCON Info/16] : Source RCON disconnected
Installing/updating item 812655342 …
[02:48:24] [System Error/7] : Source RCON failed to connect:
Connection refused.
[02:48:24] [RCON Info/7] : Source RCON disconnecting…
Success: Installed/updated item 812655342
[02:48:25] [RCON Info/7] : Source RCON disconnected
[02:48:29] [System:mochi Error/7] : Source RCON failed to connect:
Connection refused.
[02:48:29] [RCON:mochi Info/18] : Source RCON disconnecting…
Installing/updating item 1445181373 …
[02:48:29] [System Activity/16] : Authentication attempt for user mochi from 127.0.0.1
[02:48:30] [RCON:mochi Info/18] : Source RCON disconnected
[02:48:30] [System Activity/18] : Authentication success
[02:48:34] [System:mochi Error/21] : Source RCON failed to connect:
Connection refused.
[02:48:34] [RCON:mochi Info/21] : Source RCON disconnecting…
[02:48:35] [RCON:mochi Info/21] : Source RCON disconnected
Success: Installed/updated item 1445181373
[02:48:39] [System Error/21] : Source RCON failed to connect:
Connection refused.
[02:48:39] [RCON Info/21] : Source RCON disconnecting…
[02:48:40] [RCON Info/21] : Source RCON disconnected
Installing/updating item 895711211 …
[02:48:44] [System Error/27] : Source RCON failed to connect:
Connection refused.
[02:48:44] [RCON Info/27] : Source RCON disconnecting…
[02:48:45] [RCON Info/27] : Source RCON disconnected
Success: Installed/updated item 895711211
[02:48:49] [System:mochi Error/27] : Source RCON failed to connect:
Connection refused.
[02:48:49] [RCON:mochi Info/27] : Source RCON disconnecting…
Installing/updating item 1645346094 …
[02:48:50] [RCON:mochi Info/27] : Source RCON disconnected
Success: Installed/updated item 1645346094
Summary:
Total items attempted: 10
Successfully processed: 10
[02:48:54] [System:mochi Error/19] : Source RCON failed to connect:
Connection refused.
[02:48:54] [RCON:mochi Info/19] : Source RCON disconnecting…
[02:48:55] [RCON:mochi Info/19] : Source RCON disconnected
[02:48:57] [System:mochi Info/27] : Extracting /AMP/arkse/376030/ShooterGame/Binaries/Win64/ArkApi_3.56.zip to /AMP/arkse/376030/ShooterGame/Binaries/Win64/…
[02:48:59] [System Error/21] : Source RCON failed to connect:
Connection refused.
[02:48:59] [RCON Info/21] : Source RCON disconnecting…
[02:49:00] [RCON Info/21] : Source RCON disconnected
[02:49:00] [System:mochi Info/19] : Skipping download - target already exists (/AMP/arkse/376030/.backupExclude)
[02:49:01] [System:mochi Info/21] : Skipping download - target already exists (/AMP/arkse/376030/ShooterGame/.backupExclude)
[02:49:04] [System Error/16] : Source RCON failed to connect:
Connection refused.
[02:49:04] [RCON Info/16] : Source RCON disconnecting…
[02:49:05] [RCON Info/16] : Source RCON disconnected
[02:49:09] [System:mochi Error/21] : Source RCON failed to connect:
Connection refused.
[02:49:09] [RCON:mochi Info/27] : Source RCON disconnecting…
[02:49:10] [RCON:mochi Info/27] : Source RCON disconnected
[02:49:14] [System:mochi Error/27] : Source RCON failed to connect:
Connection refused.
[02:49:14] [RCON:mochi Info/27] : Source RCON disconnecting…
[02:49:15] [RCON:mochi Info/27] : Source RCON disconnected
[02:49:19] [System Error/19] : Source RCON failed to connect:
Connection refused.
[02:49:19] [RCON Info/20] : Source RCON disconnecting…
[02:49:20] [RCON Info/20] : Source RCON disconnected
[02:49:24] [System Error/21] : Source RCON failed to connect:
Connection refused.
[02:49:24] [RCON Info/19] : Source RCON disconnecting…
[02:49:25] [RCON Info/19] : Source RCON disconnected
[02:49:29] [System:mochi Error/16] : Source RCON failed to connect:
Connection refused.
[02:49:29] [RCON:mochi Info/21] : Source RCON disconnecting…
[02:49:30] [RCON:mochi Info/21] : Source RCON disconnected
[02:49:34] [System:mochi Error/21] : Source RCON failed to connect:
Connection refused.
[02:49:34] [RCON:mochi Info/16] : Source RCON disconnecting…
[02:49:35] [RCON:mochi Info/16] : Source RCON disconnected
Your mod list is clearly invalid
Don’t include line breaks / carriage returns
Read the Mods section in ARK: Survival Evolved Guide
Nevermind, I see you fixed it at the end
Go back to the main instances page, click on the folder icon on the instance, go into the arkse directory, delete .wine
Then manage the instance and update it again
Stop sending me DMs on Discord
Ok, thanks. I did the steps that you have provided but still the same
Summary:
[03:13:44] [System:mochi Info/28] : Extracting /AMP/arkse/376030/ShooterGame/Binaries/Win64/ArkApi_3.56.zip to /AMP/arkse/376030/ShooterGame/Binaries/Win64/…
[03:13:45] [System Error/26] : Source RCON failed to connect:
Connection refused.
[03:13:45] [RCON Info/26] : Source RCON disconnecting…
[03:13:46] [RCON Info/26] : Source RCON disconnected
[03:13:47] [System:mochi Info/13] : Skipping download - target already exists (/AMP/arkse/376030/.backupExclude)
[03:13:47] [System:mochi Info/29] : Skipping download - target already exists (/AMP/arkse/376030/ShooterGame/.backupExclude)
wine: created the configuration directory ‘/AMP/arkse/.wine’
[03:13:50] [System Error/13] : Source RCON failed to connect:
Connection refused.
[03:13:50] [RCON Info/28] : Source RCON disconnecting…
[03:13:51] [RCON Info/28] : Source RCON disconnected
[03:13:55] [System Error/28] : Source RCON failed to connect:
Connection refused.
[03:13:55] [RCON Info/13] : Source RCON disconnecting…
[03:13:56] [RCON Info/13] : Source RCON disconnected
[03:14:00] [System Error/28] : Source RCON failed to connect:
Connection refused.
[03:14:00] [RCON Info/26] : Source RCON disconnecting…
[03:14:01] [RCON Info/26] : Source RCON disconnected
[03:14:05] [System Error/26] : Source RCON failed to connect:
Connection refused.
[03:14:05] [RCON Info/26] : Source RCON disconnecting…
[03:14:06] [RCON Info/26] : Source RCON disconnected
[03:14:10] [System Error/29] : Source RCON failed to connect:
Connection refused.
[03:14:10] [RCON Info/26] : Source RCON disconnecting…
[03:14:11] [RCON Info/26] : Source RCON disconnected
[03:14:15] [System Error/30] : Source RCON failed to connect:
Connection refused.
[03:14:15] [RCON Info/26] : Source RCON disconnecting…
[03:14:16] [RCON Info/26] : Source RCON disconnected
[03:14:20] [System Error/26] : Source RCON failed to connect:
Connection refused.
[03:14:20] [RCON Info/29] : Source RCON disconnecting…
[03:14:21] [RCON Info/29] : Source RCON disconnected
[03:14:25] [System Error/26] : Source RCON failed to connect:
Connection refused.
[03:14:25] [RCON Info/26] : Source RCON disconnecting…
[03:14:26] [RCON Info/26] : Source RCON disconnected
[03:14:30] [System Error/29] : Source RCON failed to connect:
Connection refused.
[03:14:30] [RCON Info/13] : Source RCON disconnecting…
[03:14:31] [RCON Info/13] : Source RCON disconnected
[03:14:35] [System Error/28] : Source RCON failed to connect:
Connection refused.
[03:14:35] [RCON Info/28] : Source RCON disconnecting…
[03:14:36] [RCON Info/28] : Source RCON disconnected
[03:14:40] [System Error/13] : Source RCON failed to connect:
Connection refused.
[03:14:40] [RCON Info/28] : Source RCON disconnecting…
[03:14:41] [RCON Info/28] : Source RCON disconnected
[03:14:45] [System Error/13] : Source RCON failed to connect:
Connection refused.
[03:14:45] [RCON Info/28] : Source RCON disconnecting…
[03:14:46] [RCON Info/28] : Source RCON disconnected
Try without mods, maybe one of them is dodgy
Or it could just be that the ServerAPI hasn’t been updated to work with Aquatica yet. Aquatica also has a bunch of issues atm running mods: ARK: Survival Evolved - Aquatica DLC Issues
Switch to the Pre-Aquatica branch if you want a functioning server
I have removed all the mods, but still wouldn’t start.
This all happened to all of my ark servers. I have 3 Corekeeper server that couldn’t start as well
[03:23:42] [System Activity/10] : Authentication attempt for user mochi from 127.0.0.1
IPC function call IClientAppManager::GetUpdateInfo took too long: 495 msec
[03:23:43] [System Activity/10] : Authentication success
Update state (0x5) verifying install, progress: 0.17 (38366593 / 22873560602)
Update state (0x5) verifying install, progress: 0.90 (204772299 / 22873560602)
Update state (0x5) verifying install, progress: 4.04 (923527121 / 22873560602)
Update state (0x5) verifying install, progress: 6.55 (1498586633 / 22873560602)
Update state (0x5) verifying install, progress: 8.96 (2048494334 / 22873560602)
Update state (0x5) verifying install, progress: 11.24 (2572105461 / 22873560602)
Update state (0x5) verifying install, progress: 11.85 (2710869256 / 22873560602)
Update state (0x5) verifying install, progress: 12.57 (2874098099 / 22873560602)
Update state (0x5) verifying install, progress: 13.20 (3018415282 / 22873560602)
Update state (0x5) verifying install, progress: 14.80 (3385069096 / 22873560602)
Update state (0x5) verifying install, progress: 17.81 (4073327386 / 22873560602)
Update state (0x5) verifying install, progress: 20.93 (4786566067 / 22873560602)
Update state (0x5) verifying install, progress: 24.44 (5590543301 / 22873560602)
Update state (0x5) verifying install, progress: 28.62 (6545629632 / 22873560602)
Update state (0x5) verifying install, progress: 32.69 (7477879329 / 22873560602)
Update state (0x5) verifying install, progress: 34.97 (7998696007 / 22873560602)
Update state (0x5) verifying install, progress: 36.66 (8385194033 / 22873560602)
Update state (0x5) verifying install, progress: 39.47 (9028549696 / 22873560602)
Update state (0x5) verifying install, progress: 42.81 (9791117710 / 22873560602)
Update state (0x5) verifying install, progress: 46.33 (10597409678 / 22873560602)
Update state (0x5) verifying install, progress: 50.48 (11547025718 / 22873560602)
Update state (0x5) verifying install, progress: 54.68 (12507831591 / 22873560602)
Update state (0x5) verifying install, progress: 58.20 (13312623959 / 22873560602)
Update state (0x5) verifying install, progress: 61.96 (14172022526 / 22873560602)
Update state (0x5) verifying install, progress: 65.80 (15050640761 / 22873560602)
Update state (0x5) verifying install, progress: 68.06 (15567733363 / 22873560602)
Update state (0x5) verifying install, progress: 71.58 (16371947921 / 22873560602)
Update state (0x5) verifying install, progress: 73.32 (16770786043 / 22873560602)
Update state (0x5) verifying install, progress: 76.07 (17399211486 / 22873560602)
Update state (0x5) verifying install, progress: 79.45 (18172797782 / 22873560602)
Update state (0x5) verifying install, progress: 83.26 (19044931713 / 22873560602)
Update state (0x5) verifying install, progress: 86.12 (19699766014 / 22873560602)
Update state (0x5) verifying install, progress: 86.89 (19873951435 / 22873560602)
Update state (0x5) verifying install, progress: 87.88 (20102376119 / 22873560602)
Update state (0x5) verifying install, progress: 89.53 (20477749260 / 22873560602)
Update state (0x5) verifying install, progress: 90.43 (20684716154 / 22873560602)
Update state (0x5) verifying install, progress: 91.40 (20906057069 / 22873560602)
Update state (0x5) verifying install, progress: 92.68 (21199963249 / 22873560602)
Update state (0x5) verifying install, progress: 94.32 (21574727762 / 22873560602)
Update state (0x5) verifying install, progress: 95.96 (21948602618 / 22873560602)
Update state (0x5) verifying install, progress: 98.52 (22535767050 / 22873560602)
IPC function call IClientAppManager::GetUpdateInfo took too long: 265 msec
Update state (0x61) downloading, progress: 0.00 (0 / 2877520)
IPC function call IClientAppManager::GetUpdateInfo took too long: 71 msec
IPC function call IClientAppManager::GetUpdateInfo took too long: 77 msec
quit
[03:25:08] [System Info/18] : SteamCMD Update successful
Summary:
[03:25:12] [System Info/24] : Extracting /AMP/arkse/376030/ShooterGame/Binaries/Win64/ArkApi_3.56.zip to /AMP/arkse/376030/ShooterGame/Binaries/Win64/…
[03:25:15] [System Info/12] : Skipping download - target already exists (/AMP/arkse/376030/.backupExclude)
[03:25:16] [System Info/12] : Skipping download - target already exists (/AMP/arkse/376030/ShooterGame/.backupExclude)
[03:26:10] [System Error/7] : Source RCON failed to connect:
Connection refused.
[03:26:10] [RCON Info/25] : Source RCON disconnecting…
[03:26:11] [RCON Info/25] : Source RCON disconnected
[03:26:16] [System Error/25] : Source RCON failed to connect:
Connection refused.
[03:26:16] [RCON Info/24] : Source RCON disconnecting…
[03:26:17] [RCON Info/24] : Source RCON disconnected
[03:26:22] [System Error/25] : Source RCON failed to connect:
Connection refused.
[03:26:22] [RCON Info/25] : Source RCON disconnecting…
[03:26:23] [RCON Info/25] : Source RCON disconnected
[03:26:28] [System Error/25] : Source RCON failed to connect:
Connection refused.
[03:26:28] [RCON Info/25] : Source RCON disconnecting…
[03:26:29] [RCON Info/25] : Source RCON disconnected
[03:26:34] [System Error/25] : Source RCON failed to connect:
Connection refused.
[03:26:34] [RCON Info/10] : Source RCON disconnecting…
[03:26:35] [RCON Info/10] : Source RCON disconnected
[03:26:40] [System Error/10] : Source RCON failed to connect:
Connection refused.
[03:26:40] [RCON Info/10] : Source RCON disconnecting…
[03:26:41] [RCON Info/10] : Source RCON disconnected
[03:26:41] [System Activity/25] : Authentication attempt for user mochi from 127.0.0.1
[03:26:42] [System Activity/10] : Authentication failure for user mochi from 127.0.0.1 - TokenRejected
[03:26:46] [System Error/10] : Source RCON failed to connect:
Connection refused.
[03:26:46] [RCON Info/12] : Source RCON disconnecting…
[03:26:47] [RCON Info/12] : Source RCON disconnected
[03:26:47] [System Activity/12] : Authentication attempt for user mochi from 127.0.0.1
[03:26:47] [System Activity/12] : Authentication success
[03:26:52] [System Error/12] : Source RCON failed to connect:
Connection refused.
[03:26:52] [RCON Info/12] : Source RCON disconnecting…
[03:26:53] [RCON Info/12] : Source RCON disconnected
[03:26:58] [System Error/10] : Source RCON failed to connect:
Connection refused.
[03:26:58] [RCON Info/10] : Source RCON disconnecting…
[03:26:58] [System Warning/7] : The application stopped unexpectedly. Exit code 3
[03:26:59] [RCON Info/10] : Source RCON disconnected
[03:27:04] [System Error/12] : Source RCON failed to connect:
Connection refused.
[03:27:04] [RCON Info/12] : Source RCON disconnecting…
[03:27:05] [RCON Info/12] : Source RCON disconnected
[03:27:10] [System Error/25] : Source RCON failed to connect:
Connection refused.
[03:27:10] [RCON Info/7] : Source RCON disconnecting…
[03:27:11] [RCON Info/7] : Source RCON disconnected
[03:27:15] [System Error/12] : Source RCON failed to connect:
Connection refused.
[03:27:15] [RCON Info/7] : Source RCON disconnecting…
[03:27:16] [RCON Info/7] : Source RCON disconnected
[03:27:20] [System Error/25] : Source RCON failed to connect:
Connection refused.
[03:27:20] [RCON Info/7] : Source RCON disconnecting…
[03:27:21] [RCON Info/7] : Source RCON disconnected
[03:27:25] [System Error/7] : Source RCON failed to connect:
Connection refused.
[03:27:25] [RCON Info/25] : Source RCON disconnecting…
[03:27:26] [RCON Info/25] : Source RCON disconnected
[03:27:30] [System Error/7] : Source RCON failed to connect:
Connection refused.
[03:27:30] [RCON Info/25] : Source RCON disconnecting…
[03:27:31] [RCON Info/25] : Source RCON disconnected
[03:27:35] [System Error/25] : Source RCON failed to connect:
Connection refused.
[03:27:35] [RCON Info/12] : Source RCON disconnecting…
Tried it out here.
Core Keeper is fine for me. They did change the logging so while the server started, AMP wasn’t registering it. I’ve updated the template for that
ASE wouldn’t start, even without mods. However, Pre-Aquatica is fine, even with mods.
Clearly the issue is that the server API is not compatible yet with Aquatica. Not surprising
HI greelan,
Appreciate for checking on this. CoreKeeper works for me now.
May I know how to revert to Pre-Aquatica?
Nvermind out I found it
I found it under Config>Updates>Server Branch. Thanks!
