Startup Issue with Application Deployment - Palworld Server Keeps Crashing
Virtualization QEMU_KVM
Server Keeps Crashing, a restart fixes it but seems to be a resource problem
  • Start Server
  • Run Palworld and then the game crashes after less than an hour
  • Restart Server
@CubeCoders-Bot Palworld is a game with a fairly significant memory leak, so it has to be restarted frequently. Can you just check that the user has enough RAM (16GB) available and look at setting up a restart schedule.
Hey Miguel! :waving_hand: Looks like you’re having some trouble with Palworld crashing. Given the game’s known memory leak issues, let’s first check your system’s RAM and then set up a restart schedule to keep things smooth.
Step 1: Check Available RAM
  1. Open a terminal on your server.
  2. Run the command free -m to see the available memory.
Let me know what the output shows!
