Mike
20 December 2023 11:40
1
We need some samples of lscpu from a variety of systems. We’d be really grateful for samples with the following information:
Linux Distribution and Version (e.g. Ubuntu 22.04)
Virtualization in use if any (Bare metal, Proxmox, HyperV, ESXi, etc)
For virtualized setups, the number of virtual CPU sockets+cores assigned to the VM
Please leave your responses below using code tags - so that’s three backticks at the start and three at the end.
#If you've done it properly, it should look like this in a box with a monospace font.
Thank you kindly!
debian 12, not running it in virtualization.
Architecture: x86_64
CPU op-mode(s): 32-bit, 64-bit
Address sizes: 48 bits physical, 48 bits virtual
Byte Order: Little Endian
CPU(s): 16
On-line CPU(s) list: 0-15
Vendor ID: AuthenticAMD
Model name: AMD Ryzen 7 5800X 8-Core Processor
CPU family: 25
Model: 33
Thread(s) per core: 2
Core(s) per socket: 8
Socket(s): 1
Stepping: 0
Frequency boost: enabled
CPU(s) scaling MHz: 57%
CPU max MHz: 4850.1948
CPU min MHz: 2200.0000
BogoMIPS: 7600.64
Flags: fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 ht syscall nx mmxext fxsr_opt pdpe1gb rdtscp lm constant_tsc rep_good nopl nonstop_tsc cpuid extd_apicid aperfmperf rapl pni pclmulqdq monitor ssse3 fma cx16 sse4_1 sse4_2 x2apic movbe popcnt aes xsave avx f16c rdrand lahf_lm cmp_legacy svm extapic cr8_legacy abm sse4a misalignsse 3dnowprefetch osvw ibs skinit wdt tce topoext perfctr_core perfctr_nb bpext perfctr_llc mwaitx cpb cat_l3 cdp_l3 hw_pstate ssbd mba ibrs ibpb stibp vmmcall fsgsbase bmi1 avx2 smep bmi2 erms invpcid cqm rdt_a rdseed adx smap clflushopt clwb sha_ni xsaveopt xsavec xgetbv1 xsaves cqm_llc cqm_occup_llc cqm_mbm_total cqm_mbm_local clzero irperf xsaveerptr rdpru wbnoinvd arat npt lbrv svm_lock nrip_save tsc_scale vmcb_clean flushbyasid decodeassists pausefilter pfthreshold avic v_vmsave_vmload vgif v_spec_ctrl umip pku ospke vaes vpclmulqdq rdpid overflow_recov succor smca fsrm
Virtualization: AMD-V
L1d cache: 256 KiB (8 instances)
L1i cache: 256 KiB (8 instances)
L2 cache: 4 MiB (8 instances)
L3 cache: 32 MiB (1 instance)
NUMA node(s): 1
NUMA node0 CPU(s): 0-15
Vulnerability Gather data sampling: Not affected
Vulnerability Itlb multihit: Not affected
Vulnerability L1tf: Not affected
Vulnerability Mds: Not affected
Vulnerability Meltdown: Not affected
Vulnerability Mmio stale data: Not affected
Vulnerability Retbleed: Not affected
Vulnerability Spec rstack overflow: Mitigation; safe RET, no microcode
Vulnerability Spec store bypass: Mitigation; Speculative Store Bypass disabled via prctl
Vulnerability Spectre v1: Mitigation; usercopy/swapgs barriers and __user pointer sanitization
Vulnerability Spectre v2: Mitigation; Retpolines, IBPB conditional, IBRS_FW, STIBP always-on, RSB filling, PBRSB-eIBRS Not affected
Vulnerability Srbds: Not affected
Vulnerability Tsx async abort: Not affected
mar3ld
20 December 2023 11:48
3
Sample #1 , AMP Target:
Linux Distribution: Debian 12.3 (as per 2023-dec-20)
Virtualisation: None
Bare metal + games hosted in Docker containers
Address sizes: 46 bits physical, 48 bits virtual
CPU(s): 64
On-line CPU(s) list: 0-63
Vendor ID: GenuineIntel
Model name: Intel(R) Xeon(R) CPU E5-2697A v4 @ 2.60GHz
CPU family: 6
Model: 79
Core(s) per socket: 16
Socket(s): 2
Stepping: 1
CPU(s) scaling MHz: 34%
CPU max MHz: 3600.0000
CPU min MHz: 1200.0000
BogoMIPS: 5193.96
Flags: fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtsc
p lm constant_tsc arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc cpuid aperfmperf pni pclmulqdq dtes64 monitor ds_cpl vmx smx est tm2
ssse3 sdbg fma cx16 xtpr pdcm pcid dca sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx f16c rdrand lahf_lm abm 3dnowprefetch
cpuid_fault epb cat_l3 cdp_l3 invpcid_single pti intel_ppin ssbd ibrs ibpb stibp tpr_shadow vnmi flexpriority ept vpid ept_ad fsgsbase tsc_adju
st bmi1 hle avx2 smep bmi2 erms invpcid rtm cqm rdt_a rdseed adx smap intel_pt xsaveopt cqm_llc cqm_occup_llc cqm_mbm_total cqm_mbm_local dtherm
ida arat pln pts md_clear flush_l1d
Virtualization features:
Virtualization: VT-x
Caches (sum of all):
L1d: 1 MiB (32 instances)
L1i: 1 MiB (32 instances)
L2: 8 MiB (32 instances)
L3: 80 MiB (2 instances)
NUMA:
NUMA node(s): 2
NUMA node0 CPU(s): 0-15,32-47
NUMA node1 CPU(s): 16-31,48-63
Vulnerabilities:
Itlb multihit: KVM: Mitigation: VMX disabled
L1tf: Mitigation; PTE Inversion; VMX conditional cache flushes, SMT vulnerable
Mds: Mitigation; Clear CPU buffers; SMT vulnerable
Meltdown: Mitigation; PTI
Mmio stale data: Mitigation; Clear CPU buffers; SMT vulnerable
Spec rstack overflow: Not affected
Spectre v2: Mitigation; Retpolines, IBPB conditional, IBRS_FW, STIBP conditional, RSB filling, PBRSB-eIBRS Not affected
Srbds: Not affected
Tsx async abort: Mitigation; Clear CPU buffers; SMT vulnerable
Sample #2 , AMP Controller:
Linux Distribution: Debian 11.8 (as per 2023-dec-20)
Virtualisation: XCP-ng 8.2.1, 2 sockets, 4 cores total
CPU(s): 4
On-line CPU(s) list: 0-3
Thread(s) per core: 1
Core(s) per socket: 2
Socket(s): 2
NUMA node(s): 1
CPU family: 6
Model: 79
Model name: Intel(R) Xeon(R) CPU E5-2667 v4 @ 3.20GHz
Stepping: 1
CPU MHz: 3196.108
BogoMIPS: 6392.60
Hypervisor vendor: Xen
Virtualization type: full
L1d cache: 128 KiB
L1i cache: 128 KiB
L2 cache: 1 MiB
L3 cache: 100 MiB
NUMA node0 CPU(s): 0-3
Vulnerability Itlb multihit: KVM: Mitigation: VMX unsupported
Vulnerability L1tf: Mitigation; PTE Inversion
Vulnerability Mds: Mitigation; Clear CPU buffers; SMT Host state unknown
Vulnerability Meltdown: Mitigation; PTI
Vulnerability Mmio stale data: Mitigation; Clear CPU buffers; SMT Host state unknown
Vulnerability Spec rstack overflow: Not affected
Vulnerability Spec store bypass: Mitigation; Speculative Store Bypass disabled via prctl and seccomp
Vulnerability Spectre v2: Mitigation; Retpolines, IBPB conditional, IBRS_FW, STIBP disabled, RSB filling, PBRSB-eIBRS Not affected
Vulnerability Tsx async abort: Mitigation; Clear CPU buffers; SMT Host state unknown
Flags: fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush acpi mmx fxsr sse sse2 ss ht syscall nx pdpe1gb rdtsc
p lm constant_tsc rep_good nopl cpuid tsc_known_freq pni pclmulqdq ssse3 fma cx16 pcid sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline
_timer aes xsave avx f16c rdrand hypervisor lahf_lm abm 3dnowprefetch cpuid_fault invpcid_single pti intel_ppin ssbd ibrs ibpb stibp
fsgsbase tsc_adjust bmi1 avx2 smep bmi2 erms invpcid rtm rdseed adx smap xsaveopt md_clear flush_l1d
ryeera
20 December 2023 11:49
4
Heya!
My AMP-installation runs on a virtualized Debian 12 system on top of Proxmox 8.1.3 with 12 CPU-Cores on 1 Socket assigned to it.
Here’s the output of lscpu:
CPU(s): 12
On-line CPU(s) list: 0-11
BIOS Vendor ID: QEMU
Model name: AMD Ryzen 9 3900 12-Core Processor
BIOS Model name: pc-i440fx-8.1 CPU @ 2.0GHz
BIOS CPU family: 1
CPU family: 23
Model: 113
Core(s) per socket: 12
Socket(s): 1
Stepping: 0
BogoMIPS: 6188.37
Flags: fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 ht syscall nx mmxext fxsr_opt pdpe1gb rdtscp lm rep_good nopl cpuid extd_apicid tsc_known_freq pni p
clmulqdq ssse3 fma cx16 sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx f16c rdrand hypervisor lahf_lm cmp_legacy svm cr8_legacy abm sse4a misalignsse 3dnowprefetch osvw perfctr_c
ore ssbd ibpb stibp vmmcall fsgsbase tsc_adjust bmi1 avx2 smep bmi2 rdseed adx smap clflushopt clwb sha_ni xsaveopt xsavec xgetbv1 clzero xsaveerptr wbnoinvd arat npt lbrv nrip_save tsc_scale vmcb_c
lean flushbyasid pausefilter pfthreshold v_vmsave_vmload vgif umip rdpid arch_capabilities
Hypervisor vendor: KVM
L1d: 768 KiB (12 instances)
L1i: 768 KiB (12 instances)
L2: 6 MiB (12 instances)
L3: 192 MiB (12 instances)
NUMA:
NUMA node(s): 1
NUMA node0 CPU(s): 0-11
Vulnerabilities:
L1tf: Not affected
Mds: Not affected
Retbleed: Mitigation; untrained return thunk; SMT disabled
Spec rstack overflow: Mitigation; SMT disabled
Spectre v2: Mitigation; Retpolines, IBPB conditional, STIBP disabled, RSB filling, PBRSB-eIBRS Not affected
Srbds: Not affected
Cheers!
Ryeera
zoez
5
Debian 11
Virtualized LXC in Proxmox
6 Cores
Address sizes: 39 bits physical, 48 bits virtual
CPU(s): 16
On-line CPU(s) list: 2-5,9,10
Off-line CPU(s) list: 0,1,6-8,11-15
Thread(s) per core: 0
Socket(s): 1
NUMA node(s): 1
CPU family: 6
Model: 158
Model name: Intel(R) Core(TM) i9-9900K CPU @ 3.60GHz
Stepping: 12
CPU MHz: 4798.247
CPU max MHz: 5000,0000
CPU min MHz: 800,0000
BogoMIPS: 7200.00
L1d cache: 128 KiB
L1i cache: 128 KiB
L2 cache: 1 MiB
Vulnerability Gather data sampling: Vulnerable: No microcode
Vulnerability Itlb multihit: KVM: Mitigation: Split huge pages
Vulnerability Mds: Mitigation; Clear CPU buffers; SMT vulnerable
Vulnerability Mmio stale data: Mitigation; Clear CPU buffers; SMT vulnerable
Vulnerability Retbleed: Mitigation; IBRS
Vulnerability Spectre v2: Mitigation; IBRS, IBPB conditional, STIBP conditional, RSB filling, PBRSB-eIBRS Not affected
Vulnerability Srbds: Mitigation; Microcode
Vulnerability Tsx async abort: Mitigation; Clear CPU buffers; SMT vulnerable
Flags: fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr s se sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp lm constant_tsc art arch_perfmon pebs bts rep_good n opl xtopology nonstop_tsc cpuid aperfmperf pni pclmulqdq dtes64 monitor ds_cpl vmx smx est tm2 ssse 3 sdbg fma cx16 xtpr pdcm pcid sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx f 16c rdrand lahf_lm abm 3dnowprefetch cpuid_fault invpcid_single ssbd ibrs ibpb stibp tpr_shadow fle xpriority ept vpid ept_ad fsgsbase tsc_adjust bmi1 hle avx2 smep bmi2 erms invpcid rtm mpx rdseed a dx smap clflushopt intel_pt xsaveopt xsavec xgetbv1 xsaves dtherm ida arat pln pts hwp hwp_notify h wp_act_window hwp_epp vnmi md_clear flush_l1d arch_capabilities
Joly0
20 December 2023 11:52
6
For my Controller instance running in the amp docker container on unraid:
CPU(s): 32
On-line CPU(s) list: 0-31
Model name: AMD Ryzen 9 7950X 16-Core Processor
CPU family: 25
Model: 97
Socket(s): 1
Stepping: 2
CPU(s) scaling MHz: 51%
CPU max MHz: 5881.0000
CPU min MHz: 400.0000
BogoMIPS: 8999.70
lm constant_tsc rep_good amd_lbr_v2 nopl nonstop_tsc cpuid extd_apicid aperfmperf rapl pni pclmulqdq monitor ssse3 fma cx16 sse4_1 sse4_2 x2a
ce topoext perfctr_core perfctr_nb bpext perfctr_llc mwaitx cpb cat_l3 cdp_l3 hw_pstate ssbd mba perfmon_v2 ibrs ibpb stibp vmmcall fsgsbase b
mi1 avx2 smep bmi2 erms invpcid cqm rdt_a avx512f avx512dq rdseed adx smap avx512ifma clflushopt clwb avx512cd sha_ni avx512bw avx512vl xsaveo
pt xsavec xgetbv1 xsaves cqm_llc cqm_occup_llc cqm_mbm_total cqm_mbm_local avx512_bf16 clzero irperf xsaveerptr rdpru wbnoinvd cppc arat npt l
brv svm_lock nrip_save tsc_scale vmcb_clean flushbyasid decodeassists pausefilter pfthreshold avic v_vmsave_vmload vgif x2avic v_spec_ctrl avx
512vbmi umip pku ospke avx512_vbmi2 gfni vaes vpclmulqdq avx512_vnni avx512_bitalg avx512_vpopcntdq rdpid overflow_recov succor smca fsrm flus
h_l1d
L1d: 512 KiB (16 instances)
L1i: 512 KiB (16 instances)
L2: 16 MiB (16 instances)
L3: 64 MiB (2 instances)
NUMA:
NUMA node(s): 1
NUMA node0 CPU(s): 0-31
For my first target instance running on the same host in an ubuntu lxc container:
CPU(s): 32
CPU family: 25
Model: 97
Socket(s): 1
Stepping: 2
BogoMIPS: 8999.70
sr_opt pdpe1gb rdtscp lm constant_tsc rep_good amd_lbr_v2 nopl nonstop_tsc cpuid extd_apicid aperfmperf rapl pni pclmulqd
x cpb cat_l3 cdp_l3 hw_pstate ssbd mba perfmon_v2 ibrs ibpb stibp vmmcall fsgsbase bmi1 avx2 smep bmi2 erms invpcid cqm r
dt_a avx512f avx512dq rdseed adx smap avx512ifma clflushopt clwb avx512cd sha_ni avx512bw avx512vl xsaveopt xsavec xgetbv
gif x2avic v_spec_ctrl avx512vbmi umip pku ospke avx512_vbmi2 gfni vaes vpclmulqdq avx512_vnni avx512_bitalg avx512_vpopc
ntdq rdpid overflow_recov succor smca fsrm flush_l1d
NUMA:
NUMA node(s): 1
And for my second target running on a netcup root server:
CPU(s): 10
On-line CPU(s) list: 0-9
Model name: AMD EPYC 7702P 64-Core Processor
CPU family: 23
Model: 49
Core(s) per socket: 10
Socket(s): 1
Stepping: 0
BogoMIPS: 3992.49
Flags: fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 ht syscall nx mmxext fxsr_opt pdpe1gb rdtscp lm rep_good nopl cpuid extd_apicid tsc_known_freq pni pclmulqdq ssse3 fma cx16 sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx f 16c rdrand hypervisor lahf_lm cmp_legacy cr8_legacy abm sse4a misalignsse 3dnowprefetch osvw perfctr_core ssbd ibrs ibpb stibp vmmcall fsgsbase t sc_adjust bmi1 avx2 smep bmi2 rdseed adx smap clflushopt clwb sha_ni xsaveopt xsavec xgetbv1 clzero xsaveerptr wbnoinvd arat umip rdpid arch_capa bilities
L1d: 640 KiB (10 instances)
L1i: 640 KiB (10 instances)
L2: 5 MiB (10 instances)
L3: 160 MiB (10 instances)
NUMA:
NUMA node(s): 1
NUMA node0 CPU(s): 0-9
Gamehost Debian 12 LXC + Docker Proxmox
Address sizes: 43 bits physical, 48 bits virtual
CPU(s): 12
On-line CPU(s) list: 1-4,6-11
Off-line CPU(s) list: 0,5
Model name: AMD Ryzen 5 3600 6-Core Processor
CPU family: 23
Model: 113
Core(s) per socket: 6
Socket(s): 1
Stepping: 0
CPU(s) scaling MHz: 98%
CPU max MHz: 4208.2031
BogoMIPS: 7200.41
Flags: fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 ht syscall nx mmxext fxsr_opt pdpe1gb rdtscp lm constant_tsc rep_good nopl nonstop_tsc cpuid extd_apicid aperfmperf rapl pni pclmulqdq monitor ssse3 fma cx16 sse4_1 sse4_2 movbe popcnt aes xsave
avx f16c rdrand lahf_lm cmp_legacy svm extapic cr8_legacy abm sse4a misalignsse 3dnowprefetch osvw ibs skinit wdt tce topoext perfctr_core perfctr_nb bpext perfctr_llc mwaitx cpb cat_l3 cdp_l3 hw_pstate ssbd mba ibpb stibp vmmcall fsgsbase bmi1 avx2 smep bmi2 cqm rdt_a rdseed adx smap clflush
opt clwb sha_ni xsaveopt xsavec xgetbv1 xsaves cqm_llc cqm_occup_llc cqm_mbm_total cqm_mbm_local clzero irperf xsaveerptr rdpru wbnoinvd arat npt lbrv svm_lock nrip_save tsc_scale vmcb_clean flushbyasid decodeassists pausefilter pfthreshold avic v_vmsave_vmload vgif v_spec_ctrl umip rdpid ove
rflow_recov succor smca sme sev sev_es
L1d: 192 KiB (6 instances)
L1i: 192 KiB (6 instances)
L2: 3 MiB (6 instances)
L3: 32 MiB (2 instances)
NUMA:
NUMA node(s): 1
Vulnerabilities:
L1tf: Not affected
Mds: Not affected
Retbleed: Mitigation; untrained return thunk; SMT enabled with STIBP protection
Spectre v2: Mitigation; Retpolines, IBPB conditional, STIBP always-on, RSB filling, PBRSB-eIBRS Not affected
Srbds: Not affected
AMP Controler Debian 12 full VM - VMWARE
CPU(s): 12
CPU family: 23
Model: 113
Socket(s): 1
Stepping: 0
BogoMIPS: 7200.41
NUMA:
NUMA node(s): 1
Vulnerabilities:
L1tf: Not affected
Mds: Not affected
Srbds: Not affected
CPU(s): 16
Model name: 13th Gen Intel(R) Core(TM) i5-13400
CPU family: 6
Model: 183
Socket(s): 1
Stepping: 1
CPU(s) scaling MHz: 19%
CPU max MHz: 4600.0000
CPU min MHz: 800.0000
BogoMIPS: 4992.00
sr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp lm constant_tsc art arch_perfmon pebs bts re
p_good nopl xtopology nonstop_tsc cpuid aperfmperf tsc_known_freq pni pclmulqdq dtes64 monitor
ds_cpl vmx est tm2 ssse3 sdbg fma cx16 xtpr pdcm sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline
_timer aes xsave avx f16c rdrand lahf_lm abm 3dnowprefetch cpuid_fault ssbd ibrs ibpb stibp ibr
s_enhanced tpr_shadow vnmi flexpriority ept vpid ept_ad fsgsbase tsc_adjust bmi1 avx2 smep bmi2
erms invpcid rdseed adx smap clflushopt clwb intel_pt sha_ni xsaveopt xsavec xgetbv1 xsaves sp
lit_lock_detect avx_vnni dtherm ida arat pln pts hwp hwp_notify hwp_act_window hwp_epp hwp_pkg_
req hfi umip pku ospke waitpkg gfni vaes vpclmulqdq rdpid movdiri movdir64b fsrm md_clear seria
lize arch_lbr ibt flush_l1d arch_capabilities
L1d: 416 KiB (10 instances)
L1i: 448 KiB (10 instances)
L2: 9.5 MiB (7 instances)
L3: 20 MiB (1 instance)
NUMA:
NUMA node(s): 1
Vulnerabilities:
L1tf: Not affected
Mds: Not affected
Spectre v2: Mitigation; Enhanced IBRS, IBPB conditional, RSB filling, PBRSB-eIBRS SW sequence
Srbds: Not affected
In a Docker container on unRAID (I know…)
CPU(s): 24
On-line CPU(s) list: 0-23
Model name: AMD Ryzen 9 3900X 12-Core Processor
CPU family: 23
Model: 113
Socket(s): 1
Stepping: 0
CPU(s) scaling MHz: 59%
CPU max MHz: 4672.0698
BogoMIPS: 7600.35
e3 fma cx16 sse4_1 sse4_2 movbe popcnt aes xsave avx f16c rdrand lahf_lm cmp_legacy svm extapic cr8_legacy abm sse4a misal
_pstate ssbd mba ibpb stibp vmmcall fsgsbase bmi1 avx2 smep bmi2 cqm rdt_a rdseed adx smap clflushopt clwb sha_ni xsaveopt
xsavec xgetbv1 cqm_llc cqm_occup_llc cqm_mbm_total cqm_mbm_local clzero irperf xsaveerptr rdpru wbnoinvd arat npt lbrv sv
trl umip rdpid overflow_recov succor smca sev sev_es
L1d: 384 KiB (12 instances)
L1i: 384 KiB (12 instances)
L3: 64 MiB (4 instances)
NUMA:
NUMA node(s): 1
NUMA node0 CPU(s): 0-23
Vulnerabilities:
L1tf: Not affected
Mds: Not affected
Srbds: Not affected
Linux Distribution : Debian GNU/Linux 11.3 (bullseye) x86_64
Virtualization : KVM/QEMU with 8 vCPU
Hosted in a VPS
CPU(s): 8
On-line CPU(s) list: 0-7
Socket(s): 1
NUMA node(s): 1
CPU family: 6
Model: 79
Model name: Intel(R) Xeon(R) CPU E5-2680 v4 @ 2.40GHz
Stepping: 1
CPU MHz: 2399.998
BogoMIPS: 4799.99
L1d cache: 256 KiB
L1i cache: 256 KiB
L2 cache: 32 MiB
L3 cache: 16 MiB
NUMA node0 CPU(s): 0-7
Vulnerability L1tf: Mitigation; PTE Inversion; VMX flush not necessary, SMT disabled
Vulnerability Mmio stale data: Vulnerable: Clear CPU buffers attempted, no microcode; SMT Host state unknown
Flags: fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 ss ht syscall nx pdpe1gb rdtscp lm constant_tsc arch_perfmon rep_good nopl xtopology cpuid tsc_known_freq pni pclmulqdq vmx ssse3 fma cx16 pdcm pcid sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx f16c rdrand hypervisor lahf_lm abm 3dnowprefetch cpuid_fault invpcid_single pti ssbd ibrs ibpb stibp tpr_shadow vnmi flexpriority ept vpid ept_ad fsgsbase tsc_adjust bmi1 hle avx2 smep bmi2 erms invpcid rtm rdseed adx smap xsaveopt arat umip md_clear arch_capabilities
Debian 11 LXC container on ProxMox 8 with all 12 cores assigned
lscpu:
CPU(s): 12
Socket(s): 1
NUMA node(s): 1
CPU family: 23
Model: 1
Model name: AMD Ryzen 5 1600 Six-Core Processor
Stepping: 1
CPU MHz: 2723.269
CPU max MHz: 3200.0000
CPU min MHz: 1550.0000
BogoMIPS: 6400.06
L1d cache: 192 KiB
L1i cache: 384 KiB
L2 cache: 3 MiB
L3 cache: 16 MiB
Vulnerability Retbleed: Mitigation; untrained return thunk; SMT vulnerable
Vulnerability Spectre v2: Mitigation; Retpolines, IBPB conditional, STIBP disabled, RSB filling, PBRSB-eIBRS Not affected
c rep_good nopl nonstop_tsc cpuid extd_apicid aperfmperf rapl pni pclmulqdq monitor ssse3 fma cx16 sse4_1 sse4_2 movbe popcnt aes xsave avx f16c rdrand lahf_
lm cmp_legacy svm extapic cr8_legacy abm sse4a misalignsse 3dnowprefetch osvw skinit wdt tce topoext perfctr_core perfctr_nb bpext perfctr_llc mwaitx cpb hw_
pstate ssbd ibpb vmmcall fsgsbase bmi1 avx2 smep bmi2 rdseed adx smap clflushopt sha_ni xsaveopt xsavec xgetbv1 clzero irperf xsaveerptr arat npt lbrv svm_lo
ck nrip_save tsc_scale vmcb_clean flushbyasid decodeassists pausefilter pfthreshold avic v_vmsave_vmload vgif overflow_recov succor smca sev
Distributor ID: Debian
Description: Debian GNU/Linux 11 (bullseye)
Release: 11
Codename: bullseye
CPU(s): 8
Core(s) per socket: 4
Socket(s): 1
NUMA node(s): 1
CPU family: 6
Model: 158
Model name: Intel(R) Core(TM) i7-7700 CPU @ 3.60GHz
Stepping: 9
CPU MHz: 4000.521
CPU max MHz: 4200.0000
BogoMIPS: 7200.00
L1d cache: 128 KiB
L1i cache: 128 KiB
L2 cache: 1 MiB
L3 cache: 8 MiB
Vulnerability Itlb multihit: KVM: Mitigation: VMX disabled
Vulnerability L1tf: Mitigation; PTE Inversion; VMX conditional cache flushes, SMT vulnerable
Flags: fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp lm constant_tsc art arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc cpuid aperfmperf pni pclmulqdq
dtes64 monitor ds_cpl vmx smx est tm2 ssse3 sdbg fma cx16 xtpr pdcm pcid sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx f16c rdrand lahf_lm abm 3dnowprefetch cpuid_fault epb invpcid_single pti ssbd ibrs ibpb stibp tpr_shadow vnmi flexp
riority ept vpid ept_ad fsgsbase tsc_adjust bmi1 hle avx2 smep bmi2 erms invpcid rtm mpx rdseed adx smap clflushopt intel_pt xsaveopt xsavec xgetbv1 xsaves dtherm ida arat pln pts hwp hwp_notify hwp_act_window hwp_epp md_clear flush_l1d arch_capabilities
Ubuntu 23.10
Virtualization: None (bare metal)
CPU(s): 16
Model name: AMD Ryzen 7 5700G with Radeon Graphics
CPU family: 25
Model: 80
Socket(s): 1
Stepping: 0
CPU(s) scaling MHz: 37%
CPU max MHz: 4673.0000
BogoMIPS: 7585.76
Flags: fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 ht syscall nx mmxext fxsr_opt pdpe1gb rdtscp lm constant_tsc rep_good nopl nonstop_tsc cpuid extd_apicid aperfmperf rapl pni pclmulqdq monitor ssse3 fma cx16 sse4_1 sse4_2 x2apic movbe popcnt aes xsave avx f16c rdrand lahf_lm cmp_legacy svm extapic cr8_legacy abm sse4a misalignsse 3dnowprefetch osvw ibs skinit wdt tce topoext perfctr_core perfctr_nb bpext perfctr_llc mwaitx cpb cat_l3 cdp_l3 hw_pstate ssbd mba ibrs ibpb stibp vmmcall fsgsbase bmi1 avx2 smep bmi2 erms invpcid cqm rdt_a rdseed adx smap clflushopt clwb sha_ni xsaveopt xsavec xgetbv1 xsaves cqm_llc cqm_occup_llc cqm_mbm_total cqm_mbm_local clzero irperf xsaveerptr rdpru wbnoinvd cppc arat npt lbrv svm_lock nrip_save tsc_scale vmcb_clean flushbyasid decodeassists pausefilter pfthreshold avic v_vmsave_vmload vgif v_spec_ctrl umip pku ospke vaes vpclmulqdq rdpid overflow_recov succor smca fsrm
L3 cache: 16 MiB (1 instance)
NUMA node(s): 1
Vulnerability Tsx async abort: Not affected```
OS: Ubuntu 24.04.6 LTS
Virtualized on Digital Ocean
Currently has 4 vCPUs on one socket
Address sizes: 40 bits physical, 48 bits virtual
CPU(s): 4
Socket(s): 1
NUMA node(s): 1
CPU family: 6
Model: 85
Model name: DO-Premium-Intel
Stepping: 7
CPU MHz: 2494.138
BogoMIPS: 4988.27
L1d cache: 128 KiB
L1i cache: 128 KiB
L2 cache: 16 MiB
Vulnerability Gather data sampling: Unknown: Dependent on hypervisor status
Vulnerability Retbleed: Mitigation; Enhanced IBRS
Vulnerability Spectre v2: Mitigation; Enhanced IBRS, IBPB conditional, RSB filling, PBRSB-eIBRS SW sequence
Flags: fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 ht syscall nx pdpe1gb rdtscp lm constant_tsc rep_good nopl xtopology c
puid tsc_known_freq pni pclmulqdq vmx ssse3 fma cx16 pcid sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx f16c rdrand hypervisor lahf_lm abm 3dnowpre
fetch cpuid_fault invpcid_single ssbd ibrs ibpb ibrs_enhanced tpr_shadow vnmi flexpriority ept vpid ept_ad fsgsbase bmi1 avx2 smep bmi2 erms invpcid rdseed adx smap clf
lushopt clwb xsaveopt xsavec xgetbv1 arat pku ospke arch_capabilities
Main Production Server:
OS: Ubuntu 22.04.3
Virtualization: Bare-Metal
CPU(s): 24
Model name: Intel(R) Xeon(R) CPU X5690 @ 3.47GHz
CPU family: 6
Model: 44
Socket(s): 2
Stepping: 2
CPU max MHz: 3459.0000
CPU min MHz: 1596.0000
BogoMIPS: 6931.60
a cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ht
tm pbe syscall nx pdpe1gb rdtscp lm constant_tsc arch_p
mx est tm2 ssse3 cx16 xtpr pdcm pcid dca sse4_1 sse4_2
popcnt aes lahf_lm epb pti ssbd ibrs ibpb stibp tpr_sha
dow vnmi flexpriority ept vpid dtherm ida arat flush_l1
d
L2: 3 MiB (12 instances)
L3: 24 MiB (2 instances)
NUMA:
NUMA node(s): 2
NUMA node0 CPU(s): 0,2,4,6,8,10,12,14,16,18,20,22
NUMA node1 CPU(s): 1,3,5,7,9,11,13,15,17,19,21,23
Vulnerabilities:
s, SMT vulnerable
Mds: Vulnerable: Clear CPU buffers attempted, no microcode;
SMT vulnerable
Mmio stale data: Unknown: No mitigations
and seccomp
sanitization
Srbds: Not affected
Secondary production Server:
OS: Ubuntu 22.04.3
CPU(s): 24
Model name: Intel(R) Xeon(R) CPU X5680 @ 3.33GHz
CPU family: 6
Model: 44
Socket(s): 2
Stepping: 2
CPU max MHz: 3326.0000
BogoMIPS: 6649.97
Flags: fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ht tm pbe syscall nx pdpe1gb rdtscp lm constant_tsc arch_perfmon pebs bts rep_good nopl xtopology nonstop
_tsc cpuid aperfmperf pni pclmulqdq dtes64 monitor ds_cpl vmx smx est tm2 ssse3 cx16 xtpr pdcm pcid dca sse4_1 sse4_2 popcnt aes lahf_lm epb pti ssbd ibrs ibpb stibp tpr_shadow vnmi flexpriority ept vpid dtherm i
da arat flush_l1d
NUMA:
NUMA node(s): 2
Vulnerabilities:
Mds: Vulnerable: Clear CPU buffers attempted, no microcode; SMT vulnerable
Srbds: Not affected
Linux Distribution : Ubuntu 22.04
Virtualization : Proxmox v8.1.3
1 Socket 40 Cores
CPU(s): 40
On-line CPU(s) list: 0-39
Model name: Intel(R) Xeon(R) CPU E5-2670 v2 @ 2.50GHz
CPU family: 6
Model: 62
Core(s) per socket: 40
Socket(s): 1
Stepping: 4
BogoMIPS: 4987.97
rch_perfmon rep_good nopl xtopology cpuid tsc_known_freq pni pclmulqdq vmx ssse3 cx16 pdcm pcid sse4_1 sse4_2 x2apic popcnt tsc_deadline_timer aes
xsave avx f16c rdrand hypervisor lahf_lm cpuid_fault pti ssbd ibrs ibpb stibp tpr_shadow vnmi flexpriority ept vpid fsgsbase tsc_adjust smep erms x
saveopt arat umip md_clear flush_l1d arch_capabilities
L1d: 1.3 MiB (40 instances)
L1i: 1.3 MiB (40 instances)
L2: 160 MiB (40 instances)
L3: 16 MiB (1 instance)
NUMA:
NUMA node(s): 1
NUMA node0 CPU(s): 0-39
Vulnerabilities:
Srbds: Not affected
Ubuntu 22.04
ProxMox
8 cores allocated
CPU(s): 8
Model name: AMD EPYC 7443P 24-Core Processor
CPU family: 25
Model: 1
Socket(s): 1
Stepping: 1
BogoMIPS: 5689.31
fxsr_opt pdpe1gb rdtscp lm rep_good nopl cpuid extd_apicid tsc_known_freq pni pclmulqdq ssse3 fma cx16 pcid sse4_1 ss
sse4a misalignsse 3dnowprefetch osvw perfctr_core invpcid_single ssbd ibrs ibpb stibp vmmcall fsgsbase tsc_adjust bmi
1 avx2 smep bmi2 erms invpcid rdseed adx smap clflushopt clwb sha_ni xsaveopt xsavec xgetbv1 xsaves clzero xsaveerptr
wbnoinvd arat npt lbrv nrip_save tsc_scale vmcb_clean pausefilter pfthreshold v_vmsave_vmload vgif umip pku ospke vaes
vpclmulqdq rdpid fsrm arch_capabilities
L1d: 512 KiB (8 instances)
L1i: 512 KiB (8 instances)
L2: 4 MiB (8 instances)
L3: 128 MiB (8 instances)
NUMA:
NUMA node(s): 1
Vulnerabilities:
L1tf: Not affected
Mds: Not affected
Srbds: Not affected
Production mainline server
Address sizes: 36 bits physical, 48 bits virtual
CPU(s): 4
Model name: Intel(R) Xeon(R) CPU E3-1225 V2 @ 3.20GHz
CPU family: 6
Model: 58
Socket(s): 1
Stepping: 9
CPU min MHz: 1600.0000
BogoMIPS: 6385.67
Flags: fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx rdtscp lm constant_tsc arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc
cpuid aperfmperf pni pclmulqdq dtes64 monitor ds_cpl vmx smx est tm2 ssse3 cx16 xtpr pdcm pcid sse4_1 sse4 _2 x2apic popcnt tsc_deadline_timer aes xsave avx f16c rdrand lahf_lm cpuid_fault epb pti ssbd ibrs ibpb s tibp tpr_shadow vnmi flexpriority ept vpid fsgsbase smep erms xsaveopt dtherm ida arat pln pts md_clear fl ush_l1d
L1d: 128 KiB (4 instances)
L1i: 128 KiB (4 instances)
L2: 1 MiB (4 instances)
L3: 8 MiB (1 instance)
NUMA:
NUMA node(s): 1
Vulnerabilities:
L1tf: Mitigation; PTE Inversion; VMX conditional cache flushes, SMT disabled
Mds: Mitigation; Clear CPU buffers; SMT disabled
Srbds: Vulnerable: No microcode
VPS Test Server (dev branch)
CPU(s): 4
Model name: AMD EPYC-Milan Processor
CPU family: 25
Model: 1
Socket(s): 4
Stepping: 1
BogoMIPS: 5290.06
Flags: fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 syscall
nx mmxext fxsr_opt pdpe1gb rdtscp lm rep_good nopl cpuid extd_apicid tsc_known_freq pni pclmulqdq ssse3 fm a cx16 pcid sse4_1 sse4_2 x2apic movbe popcnt aes xsave avx f16c rdrand hypervisor lahf_lm svm cr8_legacy
abm sse4a misalignsse 3dnowprefetch osvw topoext perfctr_core ssbd ibrs ibpb stibp vmmcall fsgsbase bmi1 a vx2 smep bmi2 erms rdseed adx smap clflushopt clwb sha_ni xsaveopt xsavec xgetbv1 xsaves clzero xsaveerptr wbnoinvd arat npt nrip_save umip rdpid
L2: 2 MiB (4 instances)
L3: 128 MiB (4 instances)
NUMA:
NUMA node(s): 1
Vulnerabilities:
L1tf: Not affected
Mds: Not affected
Srbds: Not affected
