LegacyController: Debian 11 container under Proxmox 7.4 [1 socket 4 cores] (migrating away from this container)
Architecture: x86_64
CPU op-mode(s): 32-bit, 64-bit
Byte Order: Little Endian
Address sizes: 36 bits physical, 48 bits virtual
CPU(s): 4
On-line CPU(s) list: 0-3
Thread(s) per core: 1
Core(s) per socket: 4
Socket(s): 1
NUMA node(s): 1
Vendor ID: GenuineIntel
CPU family: 6
Model: 58
Model name: Intel(R) Core(TM) i5-3470 CPU @ 3.20GHz
Stepping: 9
CPU MHz: 3373.049
CPU max MHz: 3600.0000
CPU min MHz: 1600.0000
BogoMIPS: 6385.72
Virtualization: VT-x
L1d cache: 128 KiB
L1i cache: 128 KiB
L2 cache: 1 MiB
L3 cache: 6 MiB
NUMA node0 CPU(s): 0-3
Vulnerability Gather data sampling: Not affected
Vulnerability Itlb multihit: KVM: Mitigation: VMX disabled
Vulnerability L1tf: Mitigation; PTE Inversion; VMX conditional cache
flushes, SMT disabled
Vulnerability Mds: Vulnerable: Clear CPU buffers attempted, no micro
code; SMT disabled
Vulnerability Meltdown: Mitigation; PTI
Vulnerability Mmio stale data: Unknown: No mitigations
Vulnerability Retbleed: Not affected
Vulnerability Spec rstack overflow: Not affected
Vulnerability Spec store bypass: Vulnerable
Vulnerability Spectre v1: Mitigation; usercopy/swapgs barriers and __user p
ointer sanitization
Vulnerability Spectre v2: Mitigation; Retpolines, STIBP disabled, RSB filli
ng, PBRSB-eIBRS Not affected
Vulnerability Srbds: Vulnerable: No microcode
Vulnerability Tsx async abort: Not affected
Flags: fpu vme de pse tsc msr pae mce cx8 apic sep mtrr
pge mca cmov pat pse36 clflush dts acpi mmx fxsr
sse sse2 ss ht tm pbe syscall nx rdtscp lm consta
nt_tsc arch_perfmon pebs bts rep_good nopl xtopol
ogy nonstop_tsc cpuid aperfmperf pni pclmulqdq dt
es64 monitor ds_cpl vmx smx est tm2 ssse3 cx16 xt
pr pdcm pcid sse4_1 sse4_2 x2apic popcnt tsc_dead
line_timer aes xsave avx f16c rdrand lahf_lm cpui
d_fault epb pti tpr_shadow vnmi flexpriority ept
vpid fsgsbase smep erms xsaveopt dtherm ida arat
pln pts
AmpController: Debian 12 container under Proxmox 7.4 [1 socket 2 cores]
Address sizes: 46 bits physical, 48 bits virtual
CPU(s): 8
On-line CPU(s) list: 2,3
Off-line CPU(s) list: 0,1,4-7
Model name: Intel(R) Xeon(R) CPU E5-1620 v3 @ 3.50GHz
CPU family: 6
Model: 63
Thread(s) per core: 2
Socket(s): 1
Stepping: 2
CPU(s) scaling MHz: 100%
CPU max MHz: 3500.0000
CPU min MHz: 1200.0000
BogoMIPS: 6984.06
Flags: fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmo
v pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe
syscall nx pdpe1gb rdtscp lm constant_tsc arch_perfmon pebs
bts rep_good nopl xtopology nonstop_tsc cpuid aperfmperf pni
pclmulqdq dtes64 monitor ds_cpl vmx smx est tm2 ssse3 sdbg
fma cx16 xtpr pdcm pcid dca sse4_1 sse4_2 x2apic movbe popcn
t tsc_deadline_timer aes xsave avx f16c rdrand lahf_lm abm c
puid_fault epb invpcid_single pti intel_ppin ssbd ibrs ibpb
stibp tpr_shadow vnmi flexpriority ept vpid ept_ad fsgsbase
tsc_adjust bmi1 avx2 smep bmi2 erms invpcid cqm xsaveopt cqm
_llc cqm_occup_llc dtherm arat pln pts md_clear flush_l1d
Virtualization features:
Caches (sum of all):
L1d: 128 KiB (4 instances)
L1i: 128 KiB (4 instances)
L2: 1 MiB (4 instances)
L3: 10 MiB (1 instance)
NUMA:
NUMA node(s): 1
NUMA node0 CPU(s): 0-7
Vulnerabilities:
L1tf: Mitigation; PTE Inversion; VMX conditional cache flushes, SM
T vulnerable
Mds: Mitigation; Clear CPU buffers; SMT vulnerable
Mmio stale data: Mitigation; Clear CPU buffers; SMT vulnerable
Spec store bypass: Mitigation; Speculative Store Bypass disabled via prctl and
seccomp
Spectre v1: Mitigation; usercopy/swapgs barriers and __user pointer sani
tization
Spectre v2: Mitigation; Retpolines, IBPB conditional, IBRS_FW, STIBP con
ditional, RSB filling, PBRSB-eIBRS Not affected
Srbds: Not affected
AmpTarget-01: Debian 12 container under Proxmox 7.4 [1 socket 2 cores]
CPU(s): 8
On-line CPU(s) list: 1,7
Off-line CPU(s) list: 0,2-6
CPU family: 6
Model: 63
Socket(s): 1
Stepping: 2
BogoMIPS: 6984.06
Flags: fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflus
h dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp lm constan
t_tsc arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc cpuid aperfmpe
rf pni pclmulqdq dtes64 monitor ds_cpl vmx smx est tm2 ssse3 sdbg fma cx16 xtp
r pdcm pcid dca sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave
avx f16c rdrand lahf_lm abm cpuid_fault epb invpcid_single pti intel_ppin ssb
d ibrs ibpb stibp tpr_shadow vnmi flexpriority ept vpid ept_ad fsgsbase tsc_ad
just bmi1 avx2 smep bmi2 erms invpcid cqm xsaveopt cqm_llc cqm_occup_llc dther
NUMA:
NUMA node(s): 1
Vulnerabilities:
L1tf: Mitigation; PTE Inversion; VMX conditional cache flushes, SMT vulnerable
Spec store bypass: Mitigation; Speculative Store Bypass disabled via prctl and seccomp
Spectre v1: Mitigation; usercopy/swapgs barriers and __user pointer sanitization
Spectre v2: Mitigation; Retpolines, IBPB conditional, IBRS_FW, STIBP conditional, RSB fill
Srbds: Not affected
AmpTarget-02 Debian 12 container under Proxmox 7.4 [1 socket 2 cores]
CPU(s): 8
On-line CPU(s) list: 0,7
Off-line CPU(s) list: 1-6
Model name: Intel(R) Core(TM) i7 CPU 870 @ 2.93GHz
CPU family: 6
Model: 30
Socket(s): 1
Stepping: 5
Frequency boost: enabled
CPU(s) scaling MHz: 94%
CPU max MHz: 2934.0000
CPU min MHz: 1199.0000
BogoMIPS: 5866.83
h dts acpi mmx fxsr sse sse2 ht tm pbe syscall nx rdtscp lm constant_tsc arch_
perfmon pebs bts rep_good nopl xtopology nonstop_tsc cpuid aperfmperf pni dtes
64 monitor ds_cpl vmx smx est tm2 ssse3 cx16 xtpr pdcm sse4_1 sse4_2 popcnt la
hf_lm pti tpr_shadow vnmi flexpriority ept vpid dtherm ida
L3: 8 MiB (1 instance)
NUMA:
NUMA node(s): 1
Vulnerabilities:
Mds: Vulnerable: Clear CPU buffers attempted, no microcode; SMT vulnerable
Spectre v2: Mitigation; Retpolines, STIBP disabled, RSB filling, PBRSB-eIBRS Not affected
Srbds: Not affected
