OS Name/Version: Ubuntu 22.04.1 LTS
Product Name/Version: AMP 2.4.0.10 - Rust module
Problem Description: I am trying to start a Rust server with Oxide, and the program hangs while in the “starting” phase, and doesn’t ever start. The CPU and RAM graphs show no usage of either resource, so I think the instance might not be starting. I am new to this, so any help would be appreciated!
provides syntax highlighting.
Platform | Ubuntu 22.04.1 LTS |
System Type | aarch64 |
Virtualization | QEMU_KVM |
Module | RustModule |
Loaded Plugins | FileManagerPlugin, EmailSenderPlugin, WebRequestPlugin, LocalFileBackupPlugin, CommonCorePlugin |
Application Name | AMP |
Application Version | 2.4.0.10 |
Release Stream | Release (aarch64) |
Build Date | 27/10/2022 18:55 |
InstanceID | 06ed4ea3-1540-4563-aed8-5adbdd85ea96 |
Last Executable | ./rust/258550/RustDedicated |
Last Arguments | -batchmode -nographics +rcon.password ********** +server.port 28015 +rcon.port 5678 +app.port 28082 +server.ip 0.0.0.0 +server.seed 6738 +server.tickrate 30 +server.hostname My Rust server |
Last Process ID | 30436 |
- Create a new Instance of Rust
- Try to start the server
Actions taken to resolve so far: Tried starting multiple times, looked into config files
Update: I now have the application running, but Steam shows that there is no connection to the server when I hit ‘connect to Server’. I have ports 28015 and 28016 open on TCP going in for Rust.
