Restarted my server and AMP is not starting: active (exited)
OS Name/Version: Ubuntu Server 24.04 LTS
Product Name/Version: AMP Instance Manager v2.5.0.12 built 31/05/2024 14:46
I restarted my server and AMP is not starting (it’s active but exited). I don’t know what the error is because it was working 4h ago. I updated AMP few days ago but don’t think that’s the problem since it has been working flawlessly.
$ systemctl status ampinstmgr
● ampinstmgr.service - AMP Instance Manager
     Loaded: loaded (/etc/systemd/system/ampinstmgr.service; enabled; preset: enabled)
     Active: active (exited) since Wed 2024-11-06 13:47:42 UTC; 12min ago
       Docs: https://github.com/CubeCoders/AMP/wiki/AMP-systemd-script-(Linux)
    Process: 13535 ExecStart=/opt/cubecoders/amp/ampinstmgr startboot true (code=exited, status=0/SUCCESS)
   Main PID: 13535 (code=exited, status=0/SUCCESS)
        CPU: 316ms
nov 06 13:47:42 miarma ampinstmgr[13535]:   at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.CreateList (Newtonsoft.Json.JsonReader reader, System.Type objectType, Newtonsoft.Json.Serialization.J>
nov 06 13:47:42 miarma ampinstmgr[13535]:   at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.CreateValueInternal (Newtonsoft.Json.JsonReader reader, System.Type objectType, Newtonsoft.Json.Serial>
nov 06 13:47:42 miarma ampinstmgr[13535]:   at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.Deserialize (Newtonsoft.Json.JsonReader reader, System.Type objectType, System.Boolean checkAdditional>
nov 06 13:47:42 miarma ampinstmgr[13535]:   at Newtonsoft.Json.JsonSerializer.DeserializeInternal (Newtonsoft.Json.JsonReader reader, System.Type objectType) [0x00054] in <dd21e08747d94bcebed8b56112226337>:0
nov 06 13:47:42 miarma ampinstmgr[13535]:   at Newtonsoft.Json.JsonSerializer.Deserialize (Newtonsoft.Json.JsonReader reader, System.Type objectType) [0x00000] in <dd21e08747d94bcebed8b56112226337>:0
nov 06 13:47:42 miarma ampinstmgr[13535]:   at Newtonsoft.Json.JsonConvert.DeserializeObject (System.String value, System.Type type, Newtonsoft.Json.JsonSerializerSettings settings) [0x0002d] in <dd21e08747d9>
nov 06 13:47:42 miarma ampinstmgr[13535]:   at Newtonsoft.Json.JsonConvert.DeserializeObject[T] (System.String value, Newtonsoft.Json.JsonSerializerSettings settings) [0x00000] in <dd21e08747d94bcebed8b561122>
nov 06 13:47:42 miarma ampinstmgr[13535]:   at InstanceManagerPlugin.LocalInstanceManager.GetLocalInstances (System.String AlternateDefsPath) [0x00096] in <fa5cbfd73769428ea6bffea6109b4f4b>:0
nov 06 13:47:42 miarma ampinstmgr[13535]: [Info/1] No AMP instances are currently set to start automatically on boot.
nov 06 13:47:42 miarma systemd[1]: Finished ampinstmgr.service - AMP Instance Manager.
  • Update to latest AMP version
  • Restart Ubuntu
I’ve tried looking at the logs, but there are no logs from today
EDIT
SOLVED
For those who are struggling with this the solution was update the ampinstmgr package with apt as explained here:
