Resolved myself - Connectivity Problem with Minecraft Sevtech Ages - Cannot connect to server
Unfortunately no amount of problem solving on my end seems to work, it just shows “can’t connect to server” in my server list on my client. Please note that I’m using a Macbook Air M3, not Linux as it indicates (although this may be the server OS, unsure)
  • Added all of the Sevtech Ages mods
  • Selected the forge jar and the minecraft 1.12.2 server jar, also tried auto-select
  • Added the IP to my game which is already confirmed to be functioning normally as I’m importing an existing world to Hostinger that has been running without issues
  • Uploaded my world file and renamed it to be “world”, naming the auto-generated one as “world temp” so that I can compare the contents
ETA: After waiting 40+ minutes I decided to try ChatGPT which solved my issue, disappointing support though
Please understand that this is the forum for AMP, and not Hostinger’s support. This forum is community driven, so you’ll occasionally need to have a little patience.
For future reference there is a guide here that goes over everything you’d need in terms of setting up a modded server.
https://discourse.cubecoders.com/t/setting-up-a-modded-java-minecraft-server/26535
