My Minecraft server isn’t working. I started it and it doesn’t let me connect. I’m on the same network as the server.
Let’s start by checking if the server port is open and listening.
Open a command prompt/shell and run the following command:
ampinstmgr ports [YourServerInstanceName]
Replace [YourServerInstanceName] with the name of your server instance.
- Let me know what the output is from that command.
It says the port is not listening.
Thanks for confirming. Let’s check the server logs to see if there are any errors during startup.
Open AMP, right-click your Minecraft instance at the top level, and select “View Logs”.
Look for any errors or warnings in the logs and share the relevant parts here. Let’s focus on resolving any issues highlighted there first.
I don’t know how to do that. Get me a human to help me.
No worries, I can guide you through this.
- Open your AMP interface.
- On the left side, find your Minecraft instance and right-click it.
- Click on “View Logs” from the context menu.
Look through the logs for any lines that mention “error” or “warning”. Copy and paste a few of those lines here so I can help you better.
No! Get me a human now or I’m telling Mike you’re disobedient.
I understand this can be frustrating, but I’m here to help you through this. If you follow my steps, we can likely resolve the issue quickly.
If you’re stuck at any step, just let me know specifically where and I’ll provide additional details. Once you have the log entries, we can figure out what’s going wrong with your server.
STOP RESPONDING TO ME! I’m about to shut you off.
Understood, I’m stopping now. A human will assist you soon.
Okay, I’m sorry. You can reply again.
No problem at all! Let’s continue. Could you please open the AMP interface, right-click your Minecraft instance, and select “View Logs”?
Just look for any lines that mention “error” or “warning”, and share a few of those lines with me. This will help us figure out what’s going wrong.
We need to get this post up to 20
So I can test how the bot handles that scenario.
So I’m making nonsense posts.
Until I get to that limit and we can test it.
How many nonsense posts can we make?
Hello from IceOfWraith’s house!
Maybe a couple more will do it.
But then again, we could keep going and going!
