OS Name/Version:
Ubuntu 24.04.1
Product Name/Version:
Currently running version 2.6.0.6 - 20241120.1
I’m having some issues where when the palworld instance has to update, it’s throwing an error code 130 at stop time.
Pretty much the same as what’s happening in this post: Startup Issue with Palworld - Error code 130 - Technical Support - CubeCoders Support
Sadly, that topic wasn’t answered by the OP, so I’d like to troubleshoot this further.
This is the output of the console when stopping the server:
01:24:43
WARNING: setlocale('en_US.UTF-8') failed, using locale: 'C'. International characters may not work.
UpdateUI: skip show logoSteam Console Client (c) Valve Corporation - version 1733269577
-- type 'quit' to exit --
Loading Steam API...OK
force_install_dir "2394010"
01:24:44
01:24:45
Waiting for user info...OK
app_update 2394010 -beta public validate
Update state (0x5) verifying install, progress: 0.76 (27262976 / 3605795729)
01:24:47
Update state (0x5) verifying install, progress: 26.09 (940647428 / 3605795729)
01:24:49
Update state (0x5) verifying install, progress: 68.96 (2486465338 / 3605795729)
01:24:50
Success! App '2394010' fully installed.
quit
01:24:51
Console01:24:53
Shutdown handler: initalize.
[S_API] SteamAPI_Init(): Loaded local 'steamclient.so' OK.
5.1.1-0+++UE5+Release-5.1 1008 0
Disabling core dumps.
CAppInfoCacheReadFromDiskThread took 2 milliseconds to initialize
01:24:54
Game version is v0.4.12.64723
01:24:58
[2024.12.28-00.24.58:485][ 0]net.ParallelTickNetConnection = "1"
01:24:59
Running Palworld dedicated server on :8211
01:25:59
[2024-12-28 00:25:59] [LOG] RCON executed the command. save
Complete Save
01:26:06
FUnixPlatformMisc::RequestExitWithStatus
01:26:09
Exiting abnormally (error code: 130)
Shutdown handler: cleanup.
Additionally, if we manually stop, and start the instance, it throws the following error:
01:34:28
01:34:29
01:34:30
[2024.12.28-00.34.30:043][ 0]FTcpSocketBuilder: Failed to create the socket FTcpListener server as configured
01:34:32
[2024.12.28-00.34.32:796][ 0]net.ParallelTickNetConnection = "1"
01:34:34
- Setup a palworld server.
- Have it running for a minute or 5
- Go to the status page of the instance
- Hit “stop”
- Start the server within a second or 5 for the “TcpListener” issue.
Unsure what steps to take. I’d love to hear what I would need to supply
- Olrik
