Minecraft - Won't start, doesn't say why
I’m trying to start or update the server
I’ve been trying to start the server or update it so I can continue trying to set up a modded server. However, whenever I try and start or update the server it just says there was an error for some unexpected reason or there was an error for no reason but I’m not gonna tell you what the error was or why it happened. I would like to be able to fix this but I just can’t without knowing what it is.
  • Created the instance
  • set the configuration to the proper settings
  • tried to upload modpack
Have you checked what the console says?
You should also look through this guide: Setting Up A Modded Java Minecraft Server
