Let’s start by checking the server logs to get more details about why the server is failing to start. Could you please provide the latest log from the Minecraft instance?
You can obtain it by running the following command in your terminal:
ampinstmgr lastlog [INSTANCENAME]
Replace [INSTANCENAME] with the actual name of your Minecraft instance.
Make sure you’re running the right Java version for the version of MC you’re running (usually Java 8 for anything 1.16.5 and older, otherwise try Java 17)
