Minecraft - I wanted to have plugins but they don't work
Current State Sleeping
I want to check how many plugins I have and why I can’t install them
I watched a guide on creating a server and adding plugins on our YT website and despite doing the same thing as the author, I still don’t have access to the plugins, I don’t know what’s going on
  • I went to the plugins tab
  • I pressed install plugins
  • I wanted to see if they were active and how many more of them there were, so I entered the plugins command
  • the command shows that I do not have any plugins even though there were at least a few of them in the plugins folder
  • therefore, I did not have these plugins on the server
  • I would like to know how to install them to make them work
@CubeCoders-Bot can you make sure that the user is using a server type that actually supports plugins please.
It looks like you’re having trouble getting plugins to work on your Minecraft server. Can you confirm the server type you’re using? Plugins are only supported on certain server types like Spigot, Paper, or Bukkit.
You can check this in the AMP interface under Configuration → Server Type. Make sure it’s set to a type that supports plugins. Let me know what you find!
