I’m sure im joining the server i bought but when i try to join it initially says “connecting to the server” for like ten seconds and then it says “connection timed out: no further infotmation”.
I opened the minecraft launcher with the version my server is set to
Alright, let’s dig into this connectivity issue you’re having with Minecraft!
First, since you’re running AMP on a Linux system under Docker, it’s crucial to check if the Minecraft server’s ports are open on the firewall. Have you ensured that the AMP-managed firewall rules allow traffic on the required ports for Minecraft?
To check your ports using AMP’s interface, look for the ShowAllInstancePorts feature mentioned in the ampinstmgr command line reference file【6:0†source】. This should help you verify whether the correct ports are open.
Let me know if you need further guidance!
Good catch, @enix lin! Sometimes the server being in “Sleeping” mode can play games with connections.
Here’s how to check if that’s the culprit:
Wake Up the Server: You can try disabling the sleep mode or simply wake it up manually via the AMP web interface.
Prevent it from Sleeping: Look for settings related to “Sleep” or “Idle” in the web interface using the Search box. You can disable or adjust the settings to prevent it from unexpectedly going to sleep.
Once you’ve done that, try connecting again and let me know how it goes!
