OS Name/Version: 20.04.5 LTS (Focal Fossa)
Product Name/Version: AMP Release “Halimede” v2.4.0.10, built 27/10/2022 18:15
Problem Description: LDAP Authentication
I am using a Network Standard license which should support using LDAP auth.
A couple issues.
When I start the server it leaves Login.UseLDAPLogins=True, but clears Login.LDAPAuthDomain= making it blank.
I’ve setup many LDAP services before and I’ve never had one just ask for “AuthDomain”. I need to be able to set the IP, port, Bind User, and Base DN for the LDAP server. If this is meant to be installed on a Windows server that is joined to a domain the documentation needs to be updated to reflect that.
