Here the full log file from the Instance.
On the way i tested Rust Instance and the same the Instance stays in Waiting Status and nothing happend but we see that the instance are downloading the image etc… but my log are flooded with the same error from the Enshrouded Instance.
[13:41:12] [Core Info/1] : Starting AMP version 2.5.1.0 (Callisto), built 06/07/2024 22:13
[13:41:12] [Core Info/1] : Stream: Mainline / Release - built by CUBECODERS/buildbot on CCL-DEV
[13:41:13] [Core Info/1] : Running in a Docker environment.
[13:41:13] [Core Info/1] : OS: Linux / x86_64
[13:41:13] [Core Info/1] : CPU: AMD EPYC-Milan Processor (16C/16T)
[13:41:13] [Core Info/1] : RAM: 15608MB
[13:41:13] [Core Info/1] : AMP Instance ID: 916ca07f-8ba1-4cff-a9d1-ffbbe33589f1
[13:41:13] [Loader Info/1] : Loaded GenericModule version 1.0.0.0 by CubeCoders Limited
[13:41:13] [Core Info/1] : Metrics publishing is enabled at udp://localhost:12820.
[13:41:13] [Loader Info/1] : Loaded FileManagerPlugin by CubeCoders Limited
[13:41:13] [Loader Info/1] : Loaded EmailSenderPlugin by CubeCoders Limited
[13:41:13] [Loader Info/1] : Loaded WebRequestPlugin by CubeCoders Limited
[13:41:13] [Loader Info/1] : Loaded LocalFileBackupPlugin by CubeCoders Limited
[13:41:13] [Loader Info/1] : Loaded CommonCorePlugin by CubeCoders Limited
[13:41:13] [Loader Info/1] : Loaded AnalyticsPlugin by CubeCoders Limited
[13:41:13] [Loader Info/1] : GenericModule requests dependency steamcmdplugin...
[13:41:13] [Loader Info/1] : Loaded steamcmdplugin by CubeCoders Limited
[13:41:13] [Loader Info/1] : GenericModule requests dependency RCONPlugin...
[13:41:13] [Loader Info/1] : Loaded RCONPlugin by CubeCoders Limited
[13:41:13] [Core Info/1] : Licence Present: AMP Enterprise Edition - Expires 2024-08-16
[13:41:13] [FileManager Notice/1] : No SSH keypair available for embedded server, generating new keypair...
[13:41:14] [FileManager Notice/1] : Generated new keypair with fingerprint jR2D7wZxHaf1sK/leuYN+g3shocjGnid4tWWm7ZzGaQ=
[13:41:14] [FileManager Notice/1] : Using keypair with fingerprint jR2D7wZxHaf1sK/leuYN+g3shocjGnid4tWWm7ZzGaQ=
[13:41:14] [FileManager Info/1] : SFTP Server started on 0.0.0.0:2224
[13:41:14] [Webserver Info/1] : Websockets are enabled.
[13:41:14] [Webserver Info/1] : Webserver started on http://127.0.0.1:8081
[13:41:14] [Logger Info/14] : RouterTimer@10Hz with 2 jobs started
[13:41:14] [Core Info/1] : Checking for AMP updates...
[13:41:14] [Core Info/7] : AMP is up to date.
[13:41:23] [Core Error/12] : SocketException
[13:41:23] [Core Error/12] : [0] (SocketException) : Connection refused
[13:41:23] [Core Error/12] : at Net.Sockets.Socket.Send (Byte[] buffer, Int32 offset, Int32 size, Net.Sockets.SocketFlags socketFlags)
at Net.Sockets.UdpClient.Send (Byte[] dgram, Int32 bytes)
at ModuleShared.MetricsInfoPublisher.UpdateMetrics ()
[13:41:33] [Core Error/12] : SocketException
[13:41:33] [Core Error/12] : [0] (SocketException) : Connection refused
[13:41:33] [Core Error/12] : at Net.Sockets.Socket.Send (Byte[] buffer, Int32 offset, Int32 size, Net.Sockets.SocketFlags socketFlags)
[13:41:43] [Core Error/7] : SocketException
[13:41:43] [Core Error/7] : [0] (SocketException) : Connection refused
[13:41:43] [Core Error/7] : at Net.Sockets.Socket.Send (Byte[] buffer, Int32 offset, Int32 size, Net.Sockets.SocketFlags socketFlags)
[13:41:53] [Core Error/9] : SocketException
[13:41:53] [Core Error/9] : [0] (SocketException) : Connection refused
[13:41:53] [Core Error/9] : at Net.Sockets.Socket.Send (Byte[] buffer, Int32 offset, Int32 size, Net.Sockets.SocketFlags socketFlags)
[13:42:03] [Core Error/7] : SocketException
[13:42:03] [Core Error/7] : [0] (SocketException) : Connection refused
[13:42:03] [Core Error/7] : at Net.Sockets.Socket.Send (Byte[] buffer, Int32 offset, Int32 size, Net.Sockets.SocketFlags socketFlags)
[13:42:13] [Core Error/5] : SocketException
[13:42:13] [Core Error/5] : [0] (SocketException) : Connection refused
[13:42:13] [Core Error/5] : at Net.Sockets.Socket.Send (Byte[] buffer, Int32 offset, Int32 size, Net.Sockets.SocketFlags socketFlags)
[13:42:23] [Core Error/7] : SocketException
[13:42:23] [Core Error/7] : [0] (SocketException) : Connection refused
[13:42:23] [Core Error/7] : at Net.Sockets.Socket.Send (Byte[] buffer, Int32 offset, Int32 size, Net.Sockets.SocketFlags socketFlags)
[13:42:33] [Core Error/7] : SocketException
[13:42:33] [Core Error/7] : [0] (SocketException) : Connection refused
[13:42:33] [Core Error/7] : at Net.Sockets.Socket.Send (Byte[] buffer, Int32 offset, Int32 size, Net.Sockets.SocketFlags socketFlags)
[13:42:43] [Core Error/4] : SocketException
[13:42:43] [Core Error/4] : [0] (SocketException) : Connection refused
[13:42:43] [Core Error/4] : at Net.Sockets.Socket.Send (Byte[] buffer, Int32 offset, Int32 size, Net.Sockets.SocketFlags socketFlags)
[13:42:53] [Core Error/10] : SocketException
[13:42:53] [Core Error/10] : [0] (SocketException) : Connection refused
[13:42:53] [Core Error/10] : at Net.Sockets.Socket.Send (Byte[] buffer, Int32 offset, Int32 size, Net.Sockets.SocketFlags socketFlags)
[13:43:03] [Core Error/5] : SocketException
[13:43:03] [Core Error/5] : [0] (SocketException) : Connection refused
[13:43:03] [Core Error/5] : at Net.Sockets.Socket.Send (Byte[] buffer, Int32 offset, Int32 size, Net.Sockets.SocketFlags socketFlags)
[13:43:13] [Core Error/9] : SocketException
[13:43:13] [Core Error/9] : [0] (SocketException) : Connection refused
[13:43:13] [Core Error/9] : at Net.Sockets.Socket.Send (Byte[] buffer, Int32 offset, Int32 size, Net.Sockets.SocketFlags socketFlags)
[13:43:23] [Core Error/5] : SocketException
[13:43:23] [Core Error/5] : [0] (SocketException) : Connection refused
[13:43:23] [Core Error/5] : at Net.Sockets.Socket.Send (Byte[] buffer, Int32 offset, Int32 size, Net.Sockets.SocketFlags socketFlags)
[13:43:33] [Core Error/5] : SocketException
[13:43:33] [Core Error/5] : [0] (SocketException) : Connection refused
[13:43:33] [Core Error/5] : at Net.Sockets.Socket.Send (Byte[] buffer, Int32 offset, Int32 size, Net.Sockets.SocketFlags socketFlags)
[13:43:43] [Core Error/9] : SocketException
[13:43:43] [Core Error/9] : [0] (SocketException) : Connection refused
[13:43:43] [Core Error/9] : at Net.Sockets.Socket.Send (Byte[] buffer, Int32 offset, Int32 size, Net.Sockets.SocketFlags socketFlags)
[13:43:53] [Core Error/4] : SocketException
[13:43:53] [Core Error/4] : [0] (SocketException) : Connection refused
[13:43:53] [Core Error/4] : at Net.Sockets.Socket.Send (Byte[] buffer, Int32 offset, Int32 size, Net.Sockets.SocketFlags socketFlags)
[13:44:03] [Core Error/10] : SocketException
[13:44:03] [Core Error/10] : [0] (SocketException) : Connection refused
[13:44:03] [Core Error/10] : at Net.Sockets.Socket.Send (Byte[] buffer, Int32 offset, Int32 size, Net.Sockets.SocketFlags socketFlags)
[13:44:13] [Core Error/12] : SocketException
[13:44:13] [Core Error/12] : [0] (SocketException) : Connection refused
[13:44:13] [Core Error/12] : at Net.Sockets.Socket.Send (Byte[] buffer, Int32 offset, Int32 size, Net.Sockets.SocketFlags socketFlags)
[13:44:23] [Core Error/5] : SocketException
[13:44:23] [Core Error/5] : [0] (SocketException) : Connection refused
[13:44:23] [Core Error/5] : at Net.Sockets.Socket.Send (Byte[] buffer, Int32 offset, Int32 size, Net.Sockets.SocketFlags socketFlags)
[13:44:33] [Core Error/10] : SocketException
[13:44:33] [Core Error/10] : [0] (SocketException) : Connection refused
[13:44:33] [Core Error/10] : at Net.Sockets.Socket.Send (Byte[] buffer, Int32 offset, Int32 size, Net.Sockets.SocketFlags socketFlags)
[13:44:43] [Core Error/9] : SocketException
[13:44:43] [Core Error/9] : [0] (SocketException) : Connection refused
[13:44:43] [Core Error/9] : at Net.Sockets.Socket.Send (Byte[] buffer, Int32 offset, Int32 size, Net.Sockets.SocketFlags socketFlags)
[13:44:53] [Core Error/7] : SocketException
[13:44:53] [Core Error/7] : [0] (SocketException) : Connection refused
[13:44:53] [Core Error/7] : at Net.Sockets.Socket.Send (Byte[] buffer, Int32 offset, Int32 size, Net.Sockets.SocketFlags socketFlags)
[13:45:03] [Core Error/9] : SocketException
[13:45:03] [Core Error/9] : [0] (SocketException) : Connection refused
[13:45:03] [Core Error/9] : at Net.Sockets.Socket.Send (Byte[] buffer, Int32 offset, Int32 size, Net.Sockets.SocketFlags socketFlags)
[13:45:13] [Core Error/12] : SocketException
[13:45:13] [Core Error/12] : [0] (SocketException) : Connection refused
[13:45:13] [Core Error/12] : at Net.Sockets.Socket.Send (Byte[] buffer, Int32 offset, Int32 size, Net.Sockets.SocketFlags socketFlags)
[13:45:23] [Core Error/5] : SocketException
[13:45:23] [Core Error/5] : [0] (SocketException) : Connection refused
[13:45:23] [Core Error/5] : at Net.Sockets.Socket.Send (Byte[] buffer, Int32 offset, Int32 size, Net.Sockets.SocketFlags socketFlags)
[13:45:33] [Core Error/7] : SocketException
[13:45:33] [Core Error/7] : [0] (SocketException) : Connection refused
[13:45:33] [Core Error/7] : at Net.Sockets.Socket.Send (Byte[] buffer, Int32 offset, Int32 size, Net.Sockets.SocketFlags socketFlags)
[13:45:43] [Core Error/9] : SocketException
[13:45:43] [Core Error/9] : [0] (SocketException) : Connection refused
[13:45:43] [Core Error/9] : at Net.Sockets.Socket.Send (Byte[] buffer, Int32 offset, Int32 size, Net.Sockets.SocketFlags socketFlags)
[13:45:53] [Core Error/10] : SocketException
[13:45:53] [Core Error/10] : [0] (SocketException) : Connection refused
[13:45:53] [Core Error/10] : at Net.Sockets.Socket.Send (Byte[] buffer, Int32 offset, Int32 size, Net.Sockets.SocketFlags socketFlags)
[13:46:03] [Core Error/12] : SocketException
[13:46:03] [Core Error/12] : [0] (SocketException) : Connection refused
[13:46:03] [Core Error/12] : at Net.Sockets.Socket.Send (Byte[] buffer, Int32 offset, Int32 size, Net.Sockets.SocketFlags socketFlags)
[13:46:13] [Core Error/7] : SocketException
[13:46:13] [Core Error/7] : [0] (SocketException) : Connection refused
[13:46:13] [Core Error/7] : at Net.Sockets.Socket.Send (Byte[] buffer, Int32 offset, Int32 size, Net.Sockets.SocketFlags socketFlags)
[13:46:23] [Core Error/5] : SocketException
[13:46:23] [Core Error/5] : [0] (SocketException) : Connection refused
[13:46:23] [Core Error/5] : at Net.Sockets.Socket.Send (Byte[] buffer, Int32 offset, Int32 size, Net.Sockets.SocketFlags socketFlags)
[13:46:33] [Core Error/5] : SocketException
[13:46:33] [Core Error/5] : [0] (SocketException) : Connection refused
[13:46:33] [Core Error/5] : at Net.Sockets.Socket.Send (Byte[] buffer, Int32 offset, Int32 size, Net.Sockets.SocketFlags socketFlags)
[13:46:43] [Core Error/10] : SocketException
[13:46:43] [Core Error/10] : [0] (SocketException) : Connection refused
[13:46:43] [Core Error/10] : at Net.Sockets.Socket.Send (Byte[] buffer, Int32 offset, Int32 size, Net.Sockets.SocketFlags socketFlags)
[13:46:53] [Core Error/5] : SocketException
[13:46:53] [Core Error/5] : [0] (SocketException) : Connection refused
[13:46:53] [Core Error/5] : at Net.Sockets.Socket.Send (Byte[] buffer, Int32 offset, Int32 size, Net.Sockets.SocketFlags socketFlags)
[13:47:03] [Core Error/10] : SocketException
[13:47:03] [Core Error/10] : [0] (SocketException) : Connection refused
[13:47:03] [Core Error/10] : at Net.Sockets.Socket.Send (Byte[] buffer, Int32 offset, Int32 size, Net.Sockets.SocketFlags socketFlags)
[13:47:13] [Core Error/12] : SocketException
[13:47:13] [Core Error/12] : [0] (SocketException) : Connection refused
[13:47:13] [Core Error/12] : at Net.Sockets.Socket.Send (Byte[] buffer, Int32 offset, Int32 size, Net.Sockets.SocketFlags socketFlags)
[13:47:23] [Core Error/7] : SocketException
[13:47:23] [Core Error/7] : [0] (SocketException) : Connection refused
[13:47:23] [Core Error/7] : at Net.Sockets.Socket.Send (Byte[] buffer, Int32 offset, Int32 size, Net.Sockets.SocketFlags socketFlags)
[13:47:33] [Core Error/7] : SocketException
[13:47:33] [Core Error/7] : [0] (SocketException) : Connection refused
[13:47:33] [Core Error/7] : at Net.Sockets.Socket.Send (Byte[] buffer, Int32 offset, Int32 size, Net.Sockets.SocketFlags socketFlags)
[13:47:43] [Core Error/12] : SocketException
[13:47:43] [Core Error/12] : [0] (SocketException) : Connection refused
[13:47:43] [Core Error/12] : at Net.Sockets.Socket.Send (Byte[] buffer, Int32 offset, Int32 size, Net.Sockets.SocketFlags socketFlags)
[13:47:53] [Core Error/10] : SocketException
[13:47:53] [Core Error/10] : [0] (SocketException) : Connection refused
[13:47:53] [Core Error/10] : at Net.Sockets.Socket.Send (Byte[] buffer, Int32 offset, Int32 size, Net.Sockets.SocketFlags socketFlags)
[13:48:03] [Core Error/12] : SocketException
[13:48:03] [Core Error/12] : [0] (SocketException) : Connection refused
[13:48:03] [Core Error/12] : at Net.Sockets.Socket.Send (Byte[] buffer, Int32 offset, Int32 size, Net.Sockets.SocketFlags socketFlags)
[13:48:13] [Core Error/10] : SocketException
[13:48:13] [Core Error/10] : [0] (SocketException) : Connection refused
[13:48:13] [Core Error/10] : at Net.Sockets.Socket.Send (Byte[] buffer, Int32 offset, Int32 size, Net.Sockets.SocketFlags socketFlags)
[13:48:23] [Core Error/7] : SocketException
[13:48:23] [Core Error/7] : [0] (SocketException) : Connection refused
[13:48:23] [Core Error/7] : at Net.Sockets.Socket.Send (Byte[] buffer, Int32 offset, Int32 size, Net.Sockets.SocketFlags socketFlags)
[13:48:33] [Core Error/7] : SocketException
[13:48:33] [Core Error/7] : [0] (SocketException) : Connection refused
[13:48:33] [Core Error/7] : at Net.Sockets.Socket.Send (Byte[] buffer, Int32 offset, Int32 size, Net.Sockets.SocketFlags socketFlags)
[13:48:43] [Core Error/5] : SocketException
[13:48:43] [Core Error/5] : [0] (SocketException) : Connection refused
[13:48:43] [Core Error/5] : at Net.Sockets.Socket.Send (Byte[] buffer, Int32 offset, Int32 size, Net.Sockets.SocketFlags socketFlags)
[13:48:53] [Core Error/12] : SocketException
[13:48:53] [Core Error/12] : [0] (SocketException) : Connection refused
[13:48:53] [Core Error/12] : at Net.Sockets.Socket.Send (Byte[] buffer, Int32 offset, Int32 size, Net.Sockets.SocketFlags socketFlags)
[13:49:03] [Core Error/9] : SocketException
[13:49:03] [Core Error/9] : [0] (SocketException) : Connection refused
[13:49:03] [Core Error/9] : at Net.Sockets.Socket.Send (Byte[] buffer, Int32 offset, Int32 size, Net.Sockets.SocketFlags socketFlags)
[13:49:13] [Core Error/7] : SocketException
[13:49:13] [Core Error/7] : [0] (SocketException) : Connection refused
[13:49:13] [Core Error/7] : at Net.Sockets.Socket.Send (Byte[] buffer, Int32 offset, Int32 size, Net.Sockets.SocketFlags socketFlags)
[13:49:23] [Core Error/5] : SocketException
[13:49:23] [Core Error/5] : [0] (SocketException) : Connection refused
[13:49:23] [Core Error/5] : at Net.Sockets.Socket.Send (Byte[] buffer, Int32 offset, Int32 size, Net.Sockets.SocketFlags socketFlags)
[13:49:33] [Core Error/9] : SocketException
[13:49:33] [Core Error/9] : [0] (SocketException) : Connection refused
[13:49:33] [Core Error/9] : at Net.Sockets.Socket.Send (Byte[] buffer, Int32 offset, Int32 size, Net.Sockets.SocketFlags socketFlags)
[13:49:43] [Core Error/7] : SocketException
[13:49:43] [Core Error/7] : [0] (SocketException) : Connection refused
[13:49:43] [Core Error/7] : at Net.Sockets.Socket.Send (Byte[] buffer, Int32 offset, Int32 size, Net.Sockets.SocketFlags socketFlags)
[13:49:53] [Core Error/12] : SocketException
[13:49:53] [Core Error/12] : [0] (SocketException) : Connection refused
[13:49:53] [Core Error/12] : at Net.Sockets.Socket.Send (Byte[] buffer, Int32 offset, Int32 size, Net.Sockets.SocketFlags socketFlags)
[13:50:03] [Core Error/5] : SocketException
[13:50:03] [Core Error/5] : [0] (SocketException) : Connection refused
[13:50:03] [Core Error/5] : at Net.Sockets.Socket.Send (Byte[] buffer, Int32 offset, Int32 size, Net.Sockets.SocketFlags socketFlags)
[13:50:13] [Core Error/12] : SocketException
[13:50:13] [Core Error/12] : [0] (SocketException) : Connection refused
[13:50:13] [Core Error/12] : at Net.Sockets.Socket.Send (Byte[] buffer, Int32 offset, Int32 size, Net.Sockets.SocketFlags socketFlags)
[13:50:23] [Core Error/7] : SocketException
[13:50:23] [Core Error/7] : [0] (SocketException) : Connection refused
[13:50:23] [Core Error/7] : at Net.Sockets.Socket.Send (Byte[] buffer, Int32 offset, Int32 size, Net.Sockets.SocketFlags socketFlags)
[13:50:33] [Core Error/7] : SocketException
[13:50:33] [Core Error/7] : [0] (SocketException) : Connection refused
[13:50:33] [Core Error/7] : at Net.Sockets.Socket.Send (Byte[] buffer, Int32 offset, Int32 size, Net.Sockets.SocketFlags socketFlags)
[13:50:43] [Core Error/9] : SocketException
[13:50:43] [Core Error/9] : [0] (SocketException) : Connection refused
[13:50:43] [Core Error/9] : at Net.Sockets.Socket.Send (Byte[] buffer, Int32 offset, Int32 size, Net.Sockets.SocketFlags socketFlags)
[13:50:53] [Core Error/10] : SocketException
[13:50:53] [Core Error/10] : [0] (SocketException) : Connection refused
[13:50:53] [Core Error/10] : at Net.Sockets.Socket.Send (Byte[] buffer, Int32 offset, Int32 size, Net.Sockets.SocketFlags socketFlags)
[13:51:03] [Core Error/12] : SocketException
[13:51:03] [Core Error/12] : [0] (SocketException) : Connection refused
[13:51:03] [Core Error/12] : at Net.Sockets.Socket.Send (Byte[] buffer, Int32 offset, Int32 size, Net.Sockets.SocketFlags socketFlags)
[13:51:13] [Core Error/5] : SocketException
[13:51:13] [Core Error/5] : [0] (SocketException) : Connection refused
[13:51:13] [Core Error/5] : at Net.Sockets.Socket.Send (Byte[] buffer, Int32 offset, Int32 size, Net.Sockets.SocketFlags socketFlags)
[13:51:23] [Core Error/7] : SocketException
[13:51:23] [Core Error/7] : [0] (SocketException) : Connection refused
[13:51:23] [Core Error/7] : at Net.Sockets.Socket.Send (Byte[] buffer, Int32 offset, Int32 size, Net.Sockets.SocketFlags socketFlags)
[13:51:33] [Core Error/7] : SocketException
[13:51:33] [Core Error/7] : [0] (SocketException) : Connection refused
[13:51:33] [Core Error/7] : at Net.Sockets.Socket.Send (Byte[] buffer, Int32 offset, Int32 size, Net.Sockets.SocketFlags socketFlags)
[13:51:43] [Core Error/12] : SocketException
[13:51:43] [Core Error/12] : [0] (SocketException) : Connection refused
[13:51:43] [Core Error/12] : at Net.Sockets.Socket.Send (Byte[] buffer, Int32 offset, Int32 size, Net.Sockets.SocketFlags socketFlags)
[13:51:53] [Core Error/10] : SocketException
[13:51:53] [Core Error/10] : [0] (SocketException) : Connection refused
[13:51:53] [Core Error/10] : at Net.Sockets.Socket.Send (Byte[] buffer, Int32 offset, Int32 size, Net.Sockets.SocketFlags socketFlags)
[13:52:03] [Core Error/5] : SocketException
[13:52:03] [Core Error/5] : [0] (SocketException) : Connection refused
[13:52:03] [Core Error/5] : at Net.Sockets.Socket.Send (Byte[] buffer, Int32 offset, Int32 size, Net.Sockets.SocketFlags socketFlags)
[13:52:13] [Core Error/12] : SocketException
[13:52:13] [Core Error/12] : [0] (SocketException) : Connection refused
[13:52:13] [Core Error/12] : at Net.Sockets.Socket.Send (Byte[] buffer, Int32 offset, Int32 size, Net.Sockets.SocketFlags socketFlags)
[13:52:23] [Core Error/10] : SocketException
[13:52:23] [Core Error/10] : [0] (SocketException) : Connection refused
[13:52:23] [Core Error/10] : at Net.Sockets.Socket.Send (Byte[] buffer, Int32 offset, Int32 size, Net.Sockets.SocketFlags socketFlags)
[13:52:33] [Core Error/10] : SocketException
[13:52:33] [Core Error/10] : [0] (SocketException) : Connection refused
[13:52:33] [Core Error/10] : at Net.Sockets.Socket.Send (Byte[] buffer, Int32 offset, Int32 size, Net.Sockets.SocketFlags socketFlags)
[13:52:43] [Core Error/5] : SocketException
[13:52:43] [Core Error/5] : [0] (SocketException) : Connection refused
[13:52:43] [Core Error/5] : at Net.Sockets.Socket.Send (Byte[] buffer, Int32 offset, Int32 size, Net.Sockets.SocketFlags socketFlags)
[13:52:53] [Core Error/9] : SocketException
[13:52:53] [Core Error/9] : [0] (SocketException) : Connection refused
[13:52:53] [Core Error/9] : at Net.Sockets.Socket.Send (Byte[] buffer, Int32 offset, Int32 size, Net.Sockets.SocketFlags socketFlags)
[13:53:03] [Core Error/5] : SocketException
[13:53:03] [Core Error/5] : [0] (SocketException) : Connection refused
[13:53:03] [Core Error/5] : at Net.Sockets.Socket.Send (Byte[] buffer, Int32 offset, Int32 size, Net.Sockets.SocketFlags socketFlags)
[13:53:13] [Core Error/5] : SocketException
[13:53:13] [Core Error/5] : [0] (SocketException) : Connection refused
[13:53:13] [Core Error/5] : at Net.Sockets.Socket.Send (Byte[] buffer, Int32 offset, Int32 size, Net.Sockets.SocketFlags socketFlags)
[13:53:23] [Core Error/10] : SocketException
[13:53:23] [Core Error/10] : [0] (SocketException) : Connection refused
[13:53:23] [Core Error/10] : at Net.Sockets.Socket.Send (Byte[] buffer, Int32 offset, Int32 size, Net.Sockets.SocketFlags socketFlags)
And Flood all the time the same error message...
