Product Name/Version: v2.4.3, built 14/03/2023 21:50
The game server instances automatically shut down every few days. In the console logs there is an error message that the AMP installation does not have a valid license and other error messages (see screenshots). I have already tried to reactivate the license locally in the panel.
Hello there, I am the owner of that server and somehow AMP creates several instances (shadow instances). Actually only 1 instance is active and installed “normally” but if I check my current activations it shows 9 activations in total.
Looking inside the logs there seems to be a docker issue after updating and reconnectiong to the same old container.
After I logged into the panel today I was greeted by an offline Instance. Trying to start this instance results in the following Error:
Unable to complete task
This Task could not be completed: Starting Instance - Starting Nemeseos (Nemeseos01)…- State: 3. Startup failure: Docker returned error code 125
After looking inside the logs produced today and yesterday I found the following:
[09:33:00] [Core Info] : Starting AMP version 2.4.3.0 (Decadeus), built 14/03/2023 21:50
[09:33:00] [Core Info] : Stream: Mainline (Release) - built by CUBECODERS/buildbot on CCL-DEV
[09:33:00] [Logger Info] : Deleting 7 old log files...
[09:33:00] [Core Warning] : Current time zone is set to CET - It is recommended you switch to UTC+0 to avoid time-zone related issues
[09:33:00] [Core Info] : OS: Linux / x86_64
[09:33:00] [Core Info] : CPU: 11th Gen Intel(R) Core(TM) i5-11600 @ 2.80GHz (6C/12T)
[09:33:00] [Core Info] : RAM: 64131MB
[09:33:00] [Core Info] : AMP Instance ID: cf31xxx0-bxx8-4fb9-xxxx-849xxxxxxe3
[09:33:00] [ModuleLoader Info] : Loaded ADSModule version 1.0.0.0 by CubeCoders Limited
[09:33:00] [ModuleLoader Info] : Loaded FileManagerPlugin version 1.0.0.0 by CubeCoders Limited
[09:33:00] [ModuleLoader Info] : Loaded EmailSenderPlugin version 1.0.0.0 by CubeCoders Limited
[09:33:00] [ModuleLoader Info] : Loaded WebRequestPlugin version 1.0.0.0 by CubeCoders Limited
[09:33:00] [ModuleLoader Info] : Loaded LocalFileBackupPlugin version 1.0.0.0 by CubeCoders Limited
[09:33:00] [ModuleLoader Info] : Loaded CommonCorePlugin version 1.0.0.0 by CubeCoders Limited
[09:33:00] [ModuleLoader Info] : ADSModule requests dependency InstanceManagerPlugin...
[09:33:00] [ModuleLoader Info] : Loaded InstanceManagerPlugin version 1.0.0.0 by CubeCoders Limited
[09:33:00] [ModuleLoader Info] : ADSModule requests dependency SystemUserManagerPlugin...
[09:33:00] [ModuleLoader Info] : Loaded SystemUserManagerPlugin version 1.0.0.0 by CubeCoders Limited
[09:33:00] [ModuleLoader Info] : Loaded steamcmdplugin version 1.0.0.0 by CubeCoders Limited
[09:33:00] [Core Info] : Metrics server started OK on port 12820
[09:33:00] [ADS Info] : ADS startup complete in 118ms
[09:33:00] [ADS Info] : Updating remote source CubeCoders/AMPTemplates
[09:33:00] [ADS Info] : Updating existing remote source https://github.com/CubeCoders/AMPTemplates.git...
hint: Pulling without specifying how to reconcile divergent branches is
hint: discouraged. You can squelch this message by running one of the following
hint: commands sometime before your next pull:
hint:
hint: git config pull.rebase false # merge (the default strategy)
hint: git config pull.rebase true # rebase
hint: git config pull.ff only # fast-forward only
hint:
hint: You can replace "git config" with "git config --global" to set a default
hint: preference for all repositories. You can also pass --rebase, --no-rebase,
hint: or --ff-only on the command line to override the configured default per
hint: invocation.
[09:33:00] [FileManager Notice] : Using keypair with fingerprint cpxxxxxxxj/zznxxxxEK/g4ICxxxxxtyH/xxxPu/dxx=
[09:33:01] [FileManager Info] : SFTP Server started on 0.0.0.0:2223
[09:33:01] [WebServer Info] : Websockets are enabled.
[09:33:01] [WebServer Info] : Webserver started on http://0.0.0.0:8080
[09:33:01] [Logger Warning] : RouterTimer@10Hz with 2 jobs started
[09:33:01] [Core Info] : Checking for AMP updates...
[09:33:01] [Core Info] : AMP is up-to-date.
From https://github.com/CubeCoders/AMPTemplates
89f8caf..02a5dac main -> origin/main
Updating 89f8caf..02a5dac
Fast-forward
v-risingconfig.json | 8 ++++----
1 file changed, 4 insertions(+), 4 deletions(-)
[09:33:07] [InstanceManager Info] : docker: Error response from daemon: Conflict. The container name "/AMP_Nemeseos01" is already in use by container "a1e18fa36200fc00bff619b1e30a8476193058875c2f8898fcfa53029d305550". You have to remove (or rename) that container to be able to reuse that name.
[09:33:07] [InstanceManager Info] : See 'docker run --help'.
[10:03:00] [Core Info] : Checking for AMP updates...
[10:03:00] [Core Info] : AMP is up-to-date.
If you need further information please type it below. Ochin or myself will be looking into it.
Well that’s something we try to figure out. While going through the logs I saw an activation issue as well and so I believed it was relevant too.
[Core Error] : No valid AMP licence was found. Please open a shell as the 'amp' user and run ampinstmgr reactivate Nemeseos01 to reactivate this instance.
