OS Name/Version: Windows Server 2016
Product Name/Version:
AMP Release “Decadeus” v2.4.3
After I reinstalled AMP, the update function apparently no longer works. The instances start and run but the servers cannot be updated and started. Nothing can be found in the folder structure of the server either, except for the folder that stands for the application. It looks like steamcmd isn’t installing any files.
start server instance
click on manage
click on update or start
reinstall AMP
reinstall Framework
reinstall Windows
try to install and update many server
Mike
26 March 2023 18:16
2
Please search before posting. The post immediately before yours is identical.
Product Name/Version: AMP version 2.4.3.0 (Decadeus), built 14/03/2023 23:15
Problem Description: After installing an instance of any SteamCMD game (example game is Rust) server states that files are installing via steamcmd and then stops…
Sry mike. I searched with some phrases but didnt find the post you show me. Thank you very much
