Instance problems after updating
OS Name/Version: Debian GNU/Linux 12 (bookworm)
Minecraft Bedrock server doesn’t error out but it fails to display statistics users/cpu/mem , and Satisfactory won’t start at all.
  • Step 1
    Updated Amp controller, amp01 and amp02 instance servers.
  • Step 2
    Updated all game instances on AMP01 and AMP02
  • Step 3
    AMP01 instances seem to work normally. AMP02 instances are failing.
tried start / stop and update again repeatedly, no change.
Make sure you’ve updated your CLI tools, and don’t forget to clear your browser’s cache.
https://discourse.cubecoders.com/t/how-to-update-amp-to-the-latest-version/2297
Then if things still aren’t working right, read the instance(s) logs to see what’s going on.
(File icon on the effected instance → AMP_Logs)
root@amp02:~# sudo su -l
sudo: unable to resolve host amp02: Name or service not known
The log is too large to paste all of it but Here is the tail end of it:
LogLinux: Selected Device Profile: [LinuxServer]
LogDeviceProfileManager: Available device profiles:
LogDeviceProfileManager: [0x7f09626d4e60][0x7f09e59a4930 66] Linux,
LogDeviceProfileManager: [0x7f09626d4ca0][0x7f09e59a6dc0 66] LinuxServer,
LogDeviceProfileManager: Active device profile: [0x7f09626d4ca0][0x7f09e59a6dc0 66] LinuxServer
LogTextureEncodingSettings: Display: Texture Encode Speed: Final (cook).
LogTextureEncodingSettings: Display: Oodle Texture Encode Speed settings: Fast: RDO Off Lambda=0, Effort=Normal Final: RDO Off Lambda=0, Effort=Normal
LogTextureEncodingSettings: Display: Shared linear texture encoding: Disabled
LogPackageLocalizationCache: Processed 60 localized package path(s) for 2 prioritized culture(s) in 0.000204 seconds
LogAudio: Display: Registering Engine Module Parameter Interfaces…
LogMetasoundEngine: MetaSound Engine Initialized
LogWwiseNiagara: Display: Initializing default Niagara.
LogStringTable: Warning: Failed to find string table entry for ‘Menus_UI’ ‘Players/Messages/YouGotKicked’. Did you forget to add a string table redirector?
LogConsoleManager: Warning: Console object named ‘SigMan.server.tickrate’ already exists but is being registered again, but we weren’t expected it to be! (FConsoleManager::AddConsoleObject)
LogStringTable: Warning: Failed to find string table entry for ‘Menus_UI’ ‘Sessions/JoinSession/Header’. Did you forget to add a string table redirector?
LogStringTable: Warning: Failed to find string table entry for ‘Menus_UI’ ‘Sessions/JoinSession/Body’. Did you forget to add a string table redirector?
LogStringTable: Warning: Failed to find string table entry for ‘Messages_UI’ ‘Warnings/JoinSession/FailedToDestroyOldSession’. Did you forget to add a string table redirector?
LogStringTable: Warning: Failed to find string table entry for ‘Messages_UI’ ‘Warnings/JoinSession/FailedToLookupFriendsId’. Did you forget to add a string table redirector?
LogStringTable: Warning: Failed to find string table entry for ‘Messages_UI’ ‘Warnings/JoinSession/FailedToLookupHostId’. Did you forget to add a string table redirector?
LogStringTable: Warning: Failed to find string table entry for ‘Messages_UI’ ‘Warnings/JoinSession/FailedToJoinSession’. Did you forget to add a string table redirector?
LogStringTable: Warning: Failed to find string table entry for ‘Menus_UI’ ‘Sessions/Errors/OfflineFallback/aTitle’. Did you forget to add a string table redirector?
LogStringTable: Warning: Failed to find string table entry for ‘Menus_UI’ ‘Sessions/Errors/OfflineFallback/Body’. Did you forget to add a string table redirector?
LogStats: UGameplayTagsManager::InitializeManager - 0.001 s
LogLocaTools: Loading up all available csv stringtables at: Localization/StringTables
LogLocaTools: Loading up stringtable as Architecture_Data at: ../../../FactoryGame/Content/Localization/StringTables/Architecture_Data.csv
LogLocaTools: Loading up stringtable: Content/Localization/StringTables/Architecture_Data.csv
LogLocaTools: Loading up stringtable as AWESOME_Data at: ../../../FactoryGame/Content/Localization/StringTables/AWESOME_Data.csv
LogLocaTools: Loading up stringtable: Content/Localization/StringTables/AWESOME_Data.csv
LogLocaTools: Loading up stringtable as AWESOME_UI at: ../../../FactoryGame/Content/Localization/StringTables/AWESOME_UI.csv
LogLocaTools: Loading up stringtable: Content/Localization/StringTables/AWESOME_UI.csv
LogLocaTools: Loading up stringtable as Buildables_Data at: ../../../FactoryGame/Content/Localization/StringTables/Buildables_Data.csv
LogLocaTools: Loading up stringtable: Content/Localization/StringTables/Buildables_Data.csv
LogLocaTools: Loading up stringtable as Buildables_UI at: ../../../FactoryGame/Content/Localization/StringTables/Buildables_UI.csv
LogLocaTools: Loading up stringtable: Content/Localization/StringTables/Buildables_UI.csv
LogLocaTools: Loading up stringtable as Codex_UI at: ../../../FactoryGame/Content/Localization/StringTables/Codex_UI.csv
LogLocaTools: Loading up stringtable: Content/Localization/StringTables/Codex_UI.csv
LogLocaTools: Loading up stringtable as Credits_UI at: ../../../FactoryGame/Content/Localization/StringTables/Credits_UI.csv
LogLocaTools: Loading up stringtable: Content/Localization/StringTables/Credits_UI.csv
LogLocaTools: Loading up stringtable as Customization_Data at: ../../../FactoryGame/Content/Localization/StringTables/Customization_Data.csv
LogLocaTools: Loading up stringtable: Content/Localization/StringTables/Customization_Data.csv
LogLocaTools: Loading up stringtable as Customization_UI at: ../../../FactoryGame/Content/Localization/StringTables/Customization_UI.csv
LogLocaTools: Loading up stringtable: Content/Localization/StringTables/Customization_UI.csv
LogLocaTools: Loading up stringtable as Emotes_Data at: ../../../FactoryGame/Content/Localization/StringTables/Emotes_Data.csv
LogLocaTools: Loading up stringtable: Content/Localization/StringTables/Emotes_Data.csv
LogLocaTools: Loading up stringtable as Equipment_Data at: ../../../FactoryGame/Content/Localization/StringTables/Equipment_Data.csv
LogLocaTools: Loading up stringtable: Content/Localization/StringTables/Equipment_Data.csv
LogLocaTools: Loading up stringtable as FICSMAS_Data at: ../../../FactoryGame/Content/Localization/StringTables/FICSMAS_Data.csv
LogLocaTools: Loading up stringtable: Content/Localization/StringTables/FICSMAS_Data.csv
LogLocaTools: Loading up stringtable as FICSMAS_UI at: ../../../FactoryGame/Content/Localization/StringTables/FICSMAS_UI.csv
LogLocaTools: Loading up stringtable: Content/Localization/StringTables/FICSMAS_UI.csv
LogLocaTools: Loading up stringtable as Gamepads_UI at: ../../../FactoryGame/Content/Localization/StringTables/Gamepads_UI.csv
LogLocaTools: Loading up stringtable: Content/Localization/StringTables/Gamepads_UI.csv
LogLocaTools: Loading up stringtable as GamepadsMappings_UI at: ../../../FactoryGame/Content/Localization/StringTables/GamepadsMappings_UI.csv
LogLocaTools: Loading up stringtable: Content/Localization/StringTables/GamepadsMappings_UI.csv
LogLocaTools: Loading up stringtable as General_UI at: ../../../FactoryGame/Content/Localization/StringTables/General_UI.csv
LogLocaTools: Loading up stringtable: Content/Localization/StringTables/General_UI.csv
LogLocaTools: Loading up stringtable as HUB_UI at: ../../../FactoryGame/Content/Localization/StringTables/HUB_UI.csv
LogLocaTools: Loading up stringtable: Content/Localization/StringTables/HUB_UI.csv
LogLocaTools: Loading up stringtable as IconLibrary_Data at: ../../../FactoryGame/Content/Localization/StringTables/IconLibrary_Data.csv
LogLocaTools: Loading up stringtable: Content/Localization/StringTables/IconLibrary_Data.csv
LogLocaTools: Loading up stringtable as Items_Data at: ../../../FactoryGame/Content/Localization/StringTables/Items_Data.csv
LogLocaTools: Loading up stringtable: Content/Localization/StringTables/Items_Data.csv
LogLocaTools: Loading up stringtable as MAM_Data at: ../../../FactoryGame/Content/Localization/StringTables/MAM_Data.csv
LogLocaTools: Loading up stringtable: Content/Localization/StringTables/MAM_Data.csv
LogLocaTools: Loading up stringtable as MAM_UI at: ../../../FactoryGame/Content/Localization/StringTables/MAM_UI.csv
LogLocaTools: Loading up stringtable: Content/Localization/StringTables/MAM_UI.csv
LogLocaTools: Loading up stringtable as Map_UI at: ../../../FactoryGame/Content/Localization/StringTables/Map_UI.csv
LogLocaTools: Loading up stringtable: Content/Localization/StringTables/Map_UI.csv
LogLocaTools: Loading up stringtable as Menus_UI at: ../../../FactoryGame/Content/Localization/StringTables/Menus_UI.csv
LogLocaTools: Loading up stringtable: Content/Localization/StringTables/Menus_UI.csv
LogLocaTools: Loading up stringtable as Messages_UI at: ../../../FactoryGame/Content/Localization/StringTables/Messages_UI.csv
LogLocaTools: Loading up stringtable: Content/Localization/StringTables/Messages_UI.csv
LogLocaTools: Loading up stringtable as Minigame_UI at: ../../../FactoryGame/Content/Localization/StringTables/Minigame_UI.csv
LogLocaTools: Loading up stringtable: Content/Localization/StringTables/Minigame_UI.csv
LogLocaTools: Loading up stringtable as Onboarding at: ../../../FactoryGame/Content/Localization/StringTables/Onboarding.csv
LogLocaTools: Loading up stringtable: Content/Localization/StringTables/Onboarding.csv
LogLocaTools: Loading up stringtable as Options_Data at: ../../../FactoryGame/Content/Localization/StringTables/Options_Data.csv
LogLocaTools: Loading up stringtable: Content/Localization/StringTables/Options_Data.csv
LogLocaTools: Loading up stringtable as OptionsInputs_Data at: ../../../FactoryGame/Content/Localization/StringTables/OptionsInputs_Data.csv
LogLocaTools: Loading up stringtable: Content/Localization/StringTables/OptionsInputs_Data.csv
LogLocaTools: Loading up stringtable as Player_UI at: ../../../FactoryGame/Content/Localization/StringTables/Player_UI.csv
LogLocaTools: Loading up stringtable: Content/Localization/StringTables/Player_UI.csv
LogLocaTools: Loading up stringtable as Schematics_Data at: ../../../FactoryGame/Content/Localization/StringTables/Schematics_Data.csv
LogLocaTools: Loading up stringtable: Content/Localization/StringTables/Schematics_Data.csv
LogLocaTools: Loading up stringtable as Transportation_UI at: ../../../FactoryGame/Content/Localization/StringTables/Transportation_UI.csv
LogLocaTools: Loading up stringtable: Content/Localization/StringTables/Transportation_UI.csv
LogLocaTools: Loading up stringtable as Units_UI at: ../../../FactoryGame/Content/Localization/StringTables/Units_UI.csv
LogLocaTools: Loading up stringtable: Content/Localization/StringTables/Units_UI.csv
LogLocaTools: Loading up stringtable as World_Data at: ../../../FactoryGame/Content/Localization/StringTables/World_Data.csv
LogLocaTools: Loading up stringtable: Content/Localization/StringTables/World_Data.csv
LogAudioCaptureCore: Display: No Audio Capture implementations found. Audio input will be silent.
LogSlateStyle: Warning: Missing Resource from ‘CoreStyle’ Style: ‘Unable to find Brush ‘Sequencer.Timeline.VanillaScrubHandleDown’.’
LogUObjectArray: 36903 objects as part of root set at end of initial load.
LogUObjectArray: 1262 objects are not in the root set, but can never be destroyed because they are in the DisregardForGC set.
LogUObjectAllocator: 11394656 out of 0 bytes used by permanent object pool.
LogUObjectArray: CloseDisregardForGC: 36903/36903 objects in disregard for GC pool
LogStreaming: Display: AsyncLoading2 - NotifyRegistrationComplete: Registered 33382 public script object entries (917.80 KB)
LogStreaming: Display: AsyncLoading2 - Thread Started: true, IsInitialLoad: false
LogEngine: Initializing Engine…
LogAssetManager: Display: Ignoring PrimaryAssetType Profiling - Conflicts with Map - Asset: Map_UI-Profile
LogInit: Initializing FReadOnlyCVARCache
LogNetVersion: Set ProjectVersion to 0.0.1.0. Version Checksum will be recalculated on next use.
LogInit: Texture streaming: Disabled
LogUserSetting: Initializing user settings
LogLoad: Loading WwiseSoundEngine module: WwiseSoundEngine
LogWwiseSoundEngine: Display: Loading Wwise Sound Engine version 2022.1
LogAkAudio: FAkAudioModule::StartupModule: Couldn’t initialize FAkAudioDevice. AkAudioModule will not be fully initialized.
LogChaos: FPhysicsSolverBase::AsyncDt:-1.000000
LogOnlineSchema: Error: Invalid schema category lobby: Service descriptor id lobby not found.
LogOnlineSchema: Error: Invalid schema category lobbymember: Service descriptor id lobbymember not found.
LogOnlineServices: Error: [FLobbiesCommon::Initialize] Failed to initialize schema registry
LogOnlineIntegration: Initialized ‘NULL’ online backend
LogCommonUser: HandleNetworkConnectionStatusChanged(Context:Offline, ServiceName:, OldStatus:NotConnected, NewStatus:Connected)
LogHttpServerModule: Starting all listeners…
LogHttpServerModule: All listeners started
Assertion failed: InListenPort > 0 [File:.\Runtime/Online/HTTPServer/Private/HttpListener.cpp] [Line: 19]
LogCore: Error: appError called: Assertion failed: InListenPort > 0 [File:.\Runtime/Online/HTTPServer/Private/HttpListener.cpp] [Line: 19]
Signal 11 caught.
Malloc Size=262146 LargeMemoryPoolOffset=262162
CommonUnixCrashHandler: Signal=11
LogCore: === Critical error: ===
Unhandled Exception: SIGSEGV: invalid attempt to write memory at address 0x0000000000000003
LogCore: Assertion failed: InListenPort > 0 [File:.\Runtime/Online/HTTPServer/Private/HttpListener.cpp] [Line: 19]
0x00007f09617cfa64 libFactoryServer-HTTPServer-Linux-Shipping.so!FHttpServerModule::GetHttpRouter(unsigned int, bool) [C:/BuildAgent2/work/9fc8da665efb5ffd/UE4/Engine/Source/./Runtime/Online/HTTPServer/Private/HttpServerModule.cpp:136]
0x00007f09613c2878 libFactoryServer-FactoryDedicatedServer-Linux-Shipping.so!UFGServerAPIManager::Initialize(TArray<TSharedRef<FInternetAddr, (ESPMode)1>, TSizedDefaultAllocator<32> > const&) [C:/BuildAgent2/work/9fc8da665efb5ffd/UE4/Engine/Source/./../../FactoryGame/Source/FactoryDedicatedServer/Private/Networking/FGServerAPIManager.cpp:218]
0x00007f09613c1dba libFactoryServer-FactoryDedicatedServer-Linux-Shipping.so!UFGServerSubsystem::Initialize(FSubsystemCollectionBase&) [C:/BuildAgent2/work/9fc8da665efb5ffd/UE4/Engine/Source/./../../FactoryGame/Source/FactoryDedicatedServer/Private/FGServerSubsystem.cpp:136]
0x00007f0a67fbe04f libFactoryServer-Engine-Linux-Shipping.so!FSubsystemCollectionBase::AddAndInitializeSubsystem(UClass*) [C:/BuildAgent2/work/9fc8da665efb5ffd/UE4/Engine/Source/./Runtime/Engine/Private/Subsystems/SubsystemCollection.cpp:259]
0x00007f0a67fbd1cc libFactoryServer-Engine-Linux-Shipping.so!FSubsystemCollectionBase::Initialize(UObject*) [C:/BuildAgent2/work/9fc8da665efb5ffd/UE4/Engine/Source/./Runtime/Engine/Private/Subsystems/SubsystemCollection.cpp:148]
0x00007f0a67604bfb libFactoryServer-Engine-Linux-Shipping.so!UGameInstance::Init() [C:/BuildAgent2/work/9fc8da665efb5ffd/UE4/Engine/Source/./Runtime/Engine/Private/GameInstance.cpp:127]
0x00007f0954a9b7a6 libFactoryServer-FactoryGame-Linux-Shipping.so!UFGGameInstance::Init() [C:/BuildAgent2/work/9fc8da665efb5ffd/UE4/Engine/Source/./../../FactoryGame/Source/FactoryGame/Private/FGGameInstance.cpp:102]
0x00007f0a675e5419 libFactoryServer-Engine-Linux-Shipping.so!UGameEngine::Init(IEngineLoop*) [C:/BuildAgent2/work/9fc8da665efb5ffd/UE4/Engine/Source/./Runtime/Engine/Private/GameEngine.cpp:1164]
0x00007f0954a9b585 libFactoryServer-FactoryGame-Linux-Shipping.so!UFGGameEngine::Init(IEngineLoop*) [C:/BuildAgent2/work/9fc8da665efb5ffd/UE4/Engine/Source/./../../FactoryGame/Source/FactoryGame/Private/FGGameEngine.cpp:39]
0x0000000000218663 FactoryServer-Linux-Shipping!FEngineLoop::Init() [C:/BuildAgent2/work/9fc8da665efb5ffd/UE4/Engine/Source/./Runtime/Launch/Private/LaunchEngineLoop.cpp:4844]
0x000000000021a2b8 FactoryServer-Linux-Shipping!GuardedMain(char16_t const*) [C:/BuildAgent2/work/9fc8da665efb5ffd/UE4/Engine/Source/./Runtime/Launch/Private/Launch.cpp:166]
0x00007f0a69c7bd47 libFactoryServer-UnixCommonStartup-Linux-Shipping.so!CommonUnixMain(int, char**, int ()(char16_t const), void ()()) [C:/BuildAgent2/work/9fc8da665efb5ffd/UE4/Engine/Source/./Runtime/Unix/UnixCommonStartup/Private/UnixCommonStartup.cpp:269]
0x00007f0a6484624a libc.so.6!UnknownFunction(0x27249)
0x00007f0a64846305 libc.so.6!__libc_start_main(+0x84)
0x0000000000217f09 FactoryServer-Linux-Shipping!_start()
0x00007f0a69c7bd47 libFactoryServer-UnixCommonStartup-Linux-Shipping.so!CommonUnixMain(int, char**, int ()(char16_t const), void (*)()) [C:/BuildAgent2/work/9fc8da665efb5ffd/UE4/Engine/Source/./Runtime/Unix/UnixCommonStartup/Private/UnixCommonStartup.cpp:269]
LogExit: Executing StaticShutdownAfterError
Malloc Size=131160 LargeMemoryPoolOffset=393352
Malloc Size=131160 LargeMemoryPoolOffset=524536
Malloc Size=61037 LargeMemoryPoolOffset=585597
LogPakFile: Initializing PakPlatformFile
LogPakFile: Display: Found Pak file ../../../Engine/Programs/CrashReportClient/Content/Paks/CrashReportClient.pak attempting to mount.
LogPakFile: Display: Mounting pak file ../../../Engine/Programs/CrashReportClient/Content/Paks/CrashReportClient.pak.
LogPakFile: Display: Mounted Pak file ‘../../../Engine/Programs/CrashReportClient/Content/Paks/CrashReportClient.pak’, mount point: ‘../../../Engine/’
LogICUInternationalization: ICU TimeZone Detection - Raw Offset: +0:00, Platform Override: ‘’
LogInit: ExecutableName: CrashReportClient
LogInit: Build: ++FactoryGame+rel-main-ficsmas-2024-CL-385279
LogInit: Engine Version: 5.3.2-385279+++FactoryGame+rel-main-ficsmas-2024
LogInit: Compatible Engine Version: 5.3.2-385279+++FactoryGame+rel-main-ficsmas-2024
LogInit: Net CL: 385279
LogInit: OS: Debian GNU/Linux 12 (bookworm) (6.1.0-31-amd64), CPU: Intel(R) Xeon(R) CPU E5-2660 v3 @ 2.60GHz, GPU: UnknownVendor PCI-id: 15ad-0405 (15ad-0405)
LogInit: Compiled (64-bit): Dec 17 2024 16:48:23
LogInit: Architecture: x64
LogInit: Compiled with Clang: 15.0.1 (GitHub - llvm/llvm-project: The LLVM Project is a collection of modular and reusable compiler and toolchain technologies. b73d2c8c720a8c8e6e73b11be4e27afa6cb75bdf)
LogInit: Build Configuration: Shipping
LogInit: Branch Name: ++FactoryGame+rel-main-ficsmas-2024
LogInit: Command Line: -Abslog=“/AMP/satisfactory/1690800/FactoryGame/Saved/Logs/FactoryGame-CRC.log” -Unattended -ImplicitSend “/AMP/satisfactory/1690800/FactoryGame/Saved/Crashes/crashinfo-FactoryGame-pid-736-6B77615317DC4D8289FD5B3C96644A95/” -unattended
LogInit: Base Directory: /AMP/satisfactory/1690800/Engine/Binaries/Linux/
LogInit: Allocator: Mimalloc
LogInit: Installed Engine Build: 1
LogInit: This binary is optimized with LTO: no, PGO: no, instrumented for PGO data collection: no
LogInit: Launcher File: /AMP/satisfactory/1690800/launcher_id
LogInit: Launcher ID:
LogInit: Launcher Artifact:
LogInit: Presizing for max 100000 objects, including 0 objects not considered by GC, pre-allocating 0 bytes for permanent pool.
LogInit: Object subsystem initialized
LogConfig: Applying CVar settings from Section [ConsoleVariables] File [Engine]
LogInit: Unix hardware info:
LogInit: - we are the first instance of this executable
LogInit: - this process’ id (pid) is 820, parent process’ id (ppid) is 736
LogInit: - we are not running under debugger
LogInit: - machine network name is ‘amp02’
LogInit: - user name is ‘amp’ (amp)
LogInit: - we’re logged in locally
LogInit: - we’re running with rendering
LogInit: - CPU: GenuineIntel ‘Intel(R) Xeon(R) CPU E5-2660 v3 @ 2.60GHz’ (signature: 0x306F2)
LogInit: - Number of physical cores available for the process: 24
LogInit: - Number of logical cores available for the process: 24
LogInit: - GPU Brand Info: UnknownVendor PCI-id: 15ad-0405 (15ad-0405)
LogInit: - Memory allocator used: Mimalloc
LogInit: - This is a licensee build.
LogCore: Skipped benchmarking clocks because the engine is running in a standalone program mode - CLOCK_MONOTONIC will be used.
LogInit: Unix-specific commandline switches:
LogInit: -ansimalloc - use malloc()/free() from libc (useful for tools like valgrind and electric fence)
LogInit: -jemalloc - use jemalloc for all memory allocation
LogInit: -binnedmalloc - use binned malloc for all memory allocation
LogInit: -filemapcachesize=NUMBER - set the size for case-sensitive file mapping cache
LogInit: -useksm - uses kernel same-page mapping (KSM) for mapped memory (OFF)
LogInit: -ksmmergeall - marks all mmap’d memory pages suitable for KSM (OFF)
LogInit: -preloadmodulesymbols - Loads the main module symbols file into memory (OFF)
LogInit: -sigdfl=SIGNAL - Allows a specific signal to be set to its default handler rather then ignoring the signal
LogInit: -crashhandlerstacksize - Allows setting crash handler stack sizes (204800)
LogInit: -noexclusivelockonwrite - disables marking files created by the engine as exclusive locked while the engine has them opened
LogInit: -httpproxy=ADDRESS:PORT - redirects HTTP requests to a proxy (only supported if compiled with libcurl)
LogInit: -reuseconn - allow libcurl to reuse HTTP connections (only matters if compiled with libcurl)
LogInit: -virtmemkb=NUMBER - sets process virtual memory (address space) limit (overrides VirtualMemoryLimitInKB value from .ini)
LogInit: -allowsyscallfilterfile=PATH_TO_FILE - sets up a system call filter allow list. any invalid syscall in this list will cause a crash
LogInit: - Physical RAM available (not considering process quota): 63 GB (64394 MB, 65940096 KB, 67522658304 bytes)
LogInit: - VirtualMemoryAllocator pools will grow at scale 1.4
LogInit: - MemoryRangeDecommit() will be a no-op (re-run with -vmapoolevict to change)
LogInit: - PageSize 4096
LogInit: - BinnedPageSize 65536
LogUObjectArray: 439 objects as part of root set at end of initial load.
LogUObjectAllocator: 91568 out of 0 bytes used by permanent object pool.
LogUObjectArray: CloseDisregardForGC: 0/0 objects in disregard for GC pool
LogPaths: Warning: No paths for game localization data were specifed in the game configuration.
LogInit: Using OS detected language (en-US-POSIX).
LogInit: Using OS detected locale (en-US-POSIX).
LogInit: Warning: No paths for engine localization data were specifed in the engine configuration.
LogTextLocalizationManager: No localization for ‘en-US-POSIX’ exists, so ‘en’ will be used for the language.
LogTextLocalizationManager: No localization for ‘en-US-POSIX’ exists, so ‘en’ will be used for the locale.
LogPackageLocalizationCache: Processed 2 localized package path(s) for 1 prioritized culture(s) in 0.000863 seconds
CrashReportCoreLog: CrashReportClientVersion=1.0
CrashReportCoreLog: CrashReportReceiver disabled
CrashReportCoreLog: DataRouter disabled
CrashReportCoreLog: CustomDataRouterUrl: https://us-central1-satisfactory.cloudfunctions.net/crashReceipt
CrashReportCoreLog: Initial state = Unknown UploadState value
LogCrashDebugHelper: DepotName: //FactoryGame/rel-main-ficsmas-2024
LogCrashDebugHelper: BuiltFromCL: 385279
LogCrashDebugHelper: EngineVersion: 5.3.2-385279+++FactoryGame+rel-main-ficsmas-2024
LogCrashDebugHelper: BuildVersion: ++FactoryGame+rel-main-ficsmas-2024-CL-385279
CrashReportCoreLog: Got 4 pending files to upload from ‘crashinfo-FactoryGame-pid-736-6B77615317DC4D8289FD5B3C96644A95’
CrashReportCoreLog: State change from Ready to InitialSendData
CrashReportCoreLog: Initial request: cl 385279, usercomment: yes, errormsg: yes, callstack: yes, log: yes, minidump: yes
LogInit: Using libcurl 8.4.0
LogInit: - built for x86_64-unknown-linux-gnu
LogInit: - supports SSL with OpenSSL/1.1.1t
LogInit: - supports HTTP deflate (compression) using libz 1.2.13
LogInit: - other features:
LogInit: CURL_VERSION_SSL
LogInit: CURL_VERSION_LIBZ
LogInit: CURL_VERSION_IPV6
LogInit: CURL_VERSION_ASYNCHDNS
LogInit: CURL_VERSION_LARGEFILE
LogInit: CURL_VERSION_TLSAUTH_SRP
LogInit: CurlRequestOptions (configurable via config and command line):
LogInit: - bVerifyPeer = false - Libcurl will NOT verify peer certificate
LogInit: - bUseHttpProxy = false - Libcurl will NOT use HTTP proxy
LogInit: - bDontReuseConnections = false - Libcurl will reuse connections
LogInit: - MaxHostConnections = 16 - Libcurl will limit the number of connections to a host
LogInit: - LocalHostAddr = Default
LogInit: - BufferSize = 65536
CrashReportCoreLog: Sending HTTP request: https://us-central1-satisfactory.cloudfunctions.net/crashReceipt
CrashReportCoreLog: OnProcessRequestComplete(), State=InitialSendData bSucceeded=1
CrashReportCoreLog: Warning: Bad initial response from server, invalid response url
CrashReportCoreLog: State change from InitialSendData to Cancelled
CrashReportCoreLog: Final state (Receiver) = Cancelled
CrashReportCoreLog: Final state (Receiver) = Unknown UploadState value
LogCore: Engine exit requested (reason: CrashReportClientApp RequestExit)
LogExit: Preparing to exit.
LogExit: Object subsystem successfully closed.
LogModuleManager: Shutting down and abandoning module HTTP (12)
LogModuleManager: Shutting down and abandoning module SSL (11)
LogModuleManager: Shutting down and abandoning module CrashDebugHelper (8)
LogModuleManager: Shutting down and abandoning module CoreUObject (6)
LogModuleManager: Shutting down and abandoning module PakFile (4)
LogPakFile: Destroying PakPlatformFile
LogModuleManager: Shutting down and abandoning module RSA (3)
LogExit: Exiting.
Engine crash handling finished; re-raising signal 11 for the default handler. Good bye.
[18:44:58] [System Warning/23] : The application stopped unexpectedly. Exit code 139
[18:44:58] [System Warning/23] : Application failed to start 5 times, not restarting.
That’s not very readable, it’s better to use a site meant for pasting, or use backticks (``` words go here ```) to create code snippets.
As far as I can see, AMP is fine, but the game server itself won’t start. Looks to be segfaulting when starting it’s HTTP server, so maybe double check that the server’s ports aren’t already in use by something else.
Also double check that you’ve followed section 4 in the update guide to ensure that your templates are up to date.
updates aren’t working, but if I SSH in:
Blockquote
CONTAINER ID IMAGE COMMAND CREATED
STATUS PORTS NAMES
5a8092378b35 cubecoders/ampbase “/ampstart.sh +Core.…” About a
minute ago Up About a minute AMP_Satisfactory-Xanthus01
Blockquote
It doesn’t show anything under ports in docker, but I didn’t change
anything in the configuration, all I did was install the latest
update.
I checked my working satisfactory on AMP01 and its not showing ports in docker either, which is strange so I guess thats not it.
There are no other instances on AMP02 that could be using the ports.
Also I spun up a new satisfactory and it works.. I am just disappointed that updating the servers and the instances caused it to break so easily and its not correctable without moving the save files
Docker doesn’t show the ports since the container is using host-networking.
To clarify, you followed the entire update guide and pressed the update button for the instance in the panel as well? (part 4 of the update guide)
What ports are shown in AMP for the two servers? From the Status page in each instance
port for the other server, on a different IP was 7778, and the one on the non working secondary server was 7777 (since they share an external IP, unrelated) … I fixed this by copying out the save file from the game and removing it, then recreating a new instance and loading the save file in… This is not an optimal way to recover it though, and it should be able to fix corruption with a redeploy and keep server settings / map saves…
